BT_BTM: SCO xmit Q overflow
kturanmak
Postby kturanmak » Fri May 30, 2025 11:43 am
hi forum, I am encountering this error in the hf application. I am sharing my hf handler codes below. What could be the problem? Thank you!
static uint32_t bt_app_hf_client_outgoing_cb(uint8_t *p_buf, uint32_t sz)
	//request 240 byt read per time from bt stack cb
    int32_t out_len_bytes = 0;
	if (rb_bytes_filled(ringbuf_algo_out) >= sz)
		out_len_bytes = rb_read(ringbuf_algo_out, (char*) p_buf, sz,0);
		return out_len_bytes;
	else
		return 0;
volatile char hf_pkt = 0;
uint8_t tmp[1024*4];
volatile uint8_t hf_counter=0;
static void bt_app_hf_client_incoming_cb(const uint8_t *buf, uint32_t sz)
  	// 240byt frame came forom bt stack handler
  	#define HF_IN_PCKT_COUNT	10
    if (bt_stream_reader)
        if (audio_element_get_state(bt_stream_reader) == AEL_STATE_RUNNING)
			memcpy(&tmp[hf_counter*sz], buf, sz);
			if (hf_counter >= (HF_IN_PCKT_COUNT-1))
				hf_active = true;
				audio_element_output(bt_stream_reader, (char *)tmp, HF_IN_PCKT_COUNT*sz);
				hf_counter = 0;
			else
				hf_counter++;
			esp_hf_client_outgoing_data_ready();
Users browsing this forum: Amazon [Bot], Bing [Bot], Qwantbot and 1 guest
