Hey guys
I just had a new board made with an ESP32-S3. I've tried everything practical but I keep getting
Leaving...
Hard resetting with RTC WDT...
and serial monitor is spazzing out with "no bootable app partition"
I'm completely lost at this point.
mode:DIO, clock div:1
load:0x3fce2820,len:0x118c
load:0x403c8700,len:0x4
load:0x403c8704,len:0xc20
load:0x403cb700,len:0x30e0
entry 0x403c88b8
E (26) boot: No bootable app partitions in the partition table
ESP32-S3 Hard resetting RTC WDT
Re: ESP32-S3 Hard resetting RTC WDT
Yes I flashed it multiple times and different ways. Using esptool app and online web version.Did you flash anything to the chip?
I have a feeling this is simple but I've never seen this before.
Maybe you're only flashing the app to the ESP32? You need to also flash the secondary bootloader and the partition table.
Okay so i fixed the no bootable partitions error. I'm getting a hard resetting vis RTS pin now with no code output on the serial.
I've tried various different USB-C cables with the same results.
