esp32S3 mount TF card return errors 0x107,but run spi-lcd at first ,mount is ok
QbasicJacky
Postby QbasicJacky » Wed Jun 04, 2025 11:40 pm
hardware
tfcs pin2
lcdcs pin21
mosi pin11
clk pin12
miso pin13
ret = spi_bus_initialize(SPI2_HOST, &bus_cfg, SDSPI_DEFAULT_DMA);
lcd_init(); //if not run this code mount tf error 0x107
ret = esp_vfs_fat_sdspi_mount(mount_point, &host, &slot_config, &mount_config, &card);
ahsrabrifat
Re: esp32S3 mount TF card return errors 0x107,but run spi-lcd at first ,mount is ok
Postby ahsrabrifat » Thu Jun 05, 2025 7:49 am
If you suspect the bootloader or other code resets the pin:
gpio_hold_en(GPIO_NUM_21);
