Saving circular buffer in flash memory of esp32
aneeshp123
We are making a project where we are supposed to store sensor readings in a circular buffer of 1000 sensor readings in the flash memory. What should be the approach?
MicroController
Re: Saving circular buffer in flash memory of esp32
Approach:
if (isBufferFull()) {
deleteOldestEntries();
appendNewEntry();
Options:
a) Use a file system and store the data in files - may be the easiest way but also the most inefficient.
b) Use the partitions and flash API to write directly to flash, rotating writes and erases in a dedicated partition of at least 2 pages.
Don't try and use the NVS API. It's not made for this scenario, and as others have already found out may work somewhat but clumsy at best.
appendNewEntry();
Options:
Users browsing this forum: Baidu [Spider], DuckDuckGo [Bot] and 3 guests
