I'm not able to get verbose logging to work within the Arduino IDE for some reason which I think is a known problem with the debug macros(?), so I can't get any more detailed information from the rmt_rx.c code to track this down. So I guess my question is: anything obvious I am missing here, and is there some way to get the verbose logging to work again?
This signal I'm trying to read has a 7.5ms LOW start (or stop depending on which side you're catching), with zero being ~600us, one being 1.5ms, and a logic HIGH between signals of ~750us. Not that is matters yet as I can't get this far.
#include <Arduino.h>
#include <driver/rmt_rx.h>
rmt_channel_handle_t rx_chan = NULL;
rmt_rx_channel_config_t rx_chan_config = {
.gpio_num = GPIO_NUM_10, // GPIO number
.clk_src = RMT_CLK_SRC_DEFAULT, // select source clock
.resolution_hz = 1 * 1000 * 1000, // 1 MHz tick resolution, i.e., 1 tick = 1 µs
.mem_block_symbols = 64, // memory block size, 64 * 4 = 256 Bytes
.intr_priority = 0,
.flags = {
.invert_in = true,
.with_dma = false,
.io_loop_back = false
rmt_receive_config_t rx_recv_config = {
.signal_range_min_ns = 0, // the shortest duration for a binary 0
.signal_range_max_ns = 750000 // skywalker preamble
// circular buffer to hold messages
QueueHandle_t receive_queue = xQueueCreate(1, sizeof(rmt_rx_done_event_data_t));
// rmt_rx callback
static bool rmt_rx_done_callback(rmt_channel_handle_t channel, const rmt_rx_done_event_data_t *edata, void *user_data)
BaseType_t high_task_wakeup = pdFALSE;
QueueHandle_t receive_queue = (QueueHandle_t)user_data;
// send the received RMT symbols to the parser task
xQueueSendFromISR(receive_queue, edata, &high_task_wakeup);
// return whether any task is woken up
return high_task_wakeup == pdTRUE;
// assign rmt_rx callback as handler rmt_rx_done event
rmt_rx_event_callbacks_t cbs = {
.on_recv_done = rmt_rx_done_callback,
static void parse_frame(rmt_symbol_word_t *rmt_nec_symbols, size_t symbol_num)
Serial.printf("NEC frame start---\r\n");
for (size_t i = 0; i < symbol_num; i++) {
Serial.printf("{%d:%d},{%d:%d}\r\n", rmt_nec_symbols[i].level0, rmt_nec_symbols[i].duration0,
rmt_nec_symbols[i].level1, rmt_nec_symbols[i].duration1);
Serial.printf("---NEC frame end: ");
while (!Serial);
Serial.println("Starting...");
delay(5000);
// instantiate rx channel
ESP_LOGI("setup", "create rx chan", NULL);
ESP_ERROR_CHECK(rmt_new_rx_channel(&rx_chan_config, &rx_chan));
// register rx callback
ESP_LOGI("setup", "register rx callback", NULL);
ESP_ERROR_CHECK(rmt_rx_register_event_callbacks(rx_chan, &cbs, receive_queue));
ESP_LOGI("setup", "enable rx chan", NULL);
ESP_ERROR_CHECK(rmt_enable(rx_chan));
delay(1000);
// allocate buffer
rmt_symbol_word_t raw_symbols[64];
// give time to rmt to fetch a signal into the buffer
ESP_LOGI("loop", "read");
ESP_ERROR_CHECK(rmt_receive(rx_chan, raw_symbols, sizeof(raw_symbols), &rx_recv_config));
// fetch any rx frames from the buffer
rmt_rx_done_event_data_t rx_data;
if( xQueueReceive(receive_queue, &rx_data, 0) ) { //if we got a message
//parse it
parse_frame(rx_data.received_symbols, rx_data.num_symbols);
}Code: Select all
07:40:15.156 -> =========== Before Setup Start ===========
07:40:15.156 -> Chip Info:
07:40:15.156 -> ------------------------------------------
07:40:15.156 -> Model : ESP32-C6
07:40:15.156 -> Package : 0
07:40:15.156 -> Revision : 0.01
07:40:15.156 -> Cores : 1
07:40:15.156 -> CPU Frequency : 160 MHz
07:40:15.156 -> XTAL Frequency : 40 MHz
07:40:15.156 -> Features Bitfield : 0x00000052
07:40:15.156 -> Embedded Flash : No
07:40:15.156 -> Embedded PSRAM : No
07:40:15.156 -> 2.4GHz WiFi : Yes
07:40:15.156 -> Classic BT : No
07:40:15.156 -> BT Low Energy : Yes
07:40:15.156 -> IEEE 802.15.4 : Yes
07:40:15.156 -> INTERNAL Memory Info:
07:40:15.156 -> Total Size : 470940 B ( 459.9 KB)
07:40:15.156 -> Free Bytes : 436608 B ( 426.4 KB)
07:40:15.156 -> Allocated Bytes : 27828 B ( 27.2 KB)
07:40:15.156 -> Minimum Free Bytes: 431796 B ( 421.7 KB)
07:40:15.156 -> Largest Free Block: 401396 B ( 392.0 KB)
07:40:15.156 -> Flash Info:
07:40:15.177 -> Chip Size : 8388608 B (8 MB)
07:40:15.177 -> Block Size : 65536 B ( 64.0 KB)
07:40:15.177 -> Sector Size : 4096 B ( 4.0 KB)
07:40:15.177 -> Page Size : 256 B ( 0.2 KB)
07:40:15.177 -> Bus Speed : 40 MHz
07:40:15.177 -> Bus Mode : QIO
07:40:15.177 -> ------------------------------------------
07:40:15.177 -> Partitions Info:
07:40:15.177 -> nvs : addr: 0x00009000, size: 20.0 KB, type: DATA, subtype: NVS
07:40:15.177 -> otadata : addr: 0x0000E000, size: 8.0 KB, type: DATA, subtype: OTA
07:40:15.177 -> app0 : addr: 0x00010000, size: 1280.0 KB, type: APP, subtype: OTA_0
07:40:15.177 -> app1 : addr: 0x00150000, size: 1280.0 KB, type: APP, subtype: OTA_1
07:40:15.177 -> spiffs : addr: 0x00290000, size: 1408.0 KB, type: DATA, subtype: SPIFFS
07:40:15.177 -> coredump : addr: 0x003F0000, size: 64.0 KB, type: DATA, subtype: COREDUMP
07:40:15.177 -> Software Info:
07:40:15.177 -> Compile Date/Time : Jun 8 2025 08:38:37
07:40:15.177 -> Compile Host OS : macosx
07:40:15.177 -> ESP-IDF Version : v5.4.1-1-g2f7dcd862a-dirty
07:40:15.177 -> Arduino Version : 3.2.0
07:40:15.177 -> Board Info:
07:40:15.177 -> Arduino Board : ESP32C6_DEV
07:40:15.177 -> Arduino Variant : esp32c6
07:40:15.177 -> Arduino FQBN : esp32:esp32:esp32c6:UploadSpeed=921600,CDCOnBoot=cdc,CPUFreq=160,FlashFreq=80,FlashMode=qio,FlashSize=4M,PartitionScheme=default,DebugLevel=verbose,EraseFlash=none,JTAGAdapter=builtin,ZigbeeMode=default
07:40:15.177 -> ============ Before Setup End ============
07:40:15.177 -> [ 737][I][esp32-hal-periman.c:141] perimanSetPinBus(): Pin 12 already has type USB_DM (38) with bus 0x4080ead0
07:40:15.210 -> [ 737][I][esp32-hal-periman.c:141] perimanSetPinBus(): Pin 13 already has type USB_DP (39) with bus 0x4080ead0
07:40:15.210 -> Starting...
07:40:20.199 -> [ 5738][I][sketch_jun5a.ino:60] setup(): [setup] create rx chan
07:40:20.199 -> [ 5738][I][sketch_jun5a.ino:64] setup(): [setup] register rx callback
07:40:20.199 -> [ 5738][I][sketch_jun5a.ino:67] setup(): [setup] enable rx chan
07:40:20.199 -> =========== After Setup Start ============
07:40:20.199 -> INTERNAL Memory Info:
07:40:20.199 -> ------------------------------------------
07:40:20.199 -> Total Size : 470940 B ( 459.9 KB)
07:40:20.199 -> Free Bytes : 436104 B ( 425.9 KB)
07:40:20.199 -> Allocated Bytes : 28204 B ( 27.5 KB)
07:40:20.199 -> Minimum Free Bytes: 431796 B ( 421.7 KB)
07:40:20.199 -> Largest Free Block: 401396 B ( 392.0 KB)
07:40:20.199 -> GPIO Info:
07:40:20.199 -> GPIO : BUS_TYPE[bus/unit][chan]
07:40:20.199 -> 12 : USB_DM
07:40:20.199 -> 13 : USB_DP
07:40:20.199 -> 16 : UART_TX[0]
07:40:20.199 -> 17 : UART_RX[0]
07:40:20.199 -> ============ After Setup End =============
07:40:21.235 -> [ 6767][I][sketch_jun5a.ino:77] loop(): [loop] read
07:40:21.235 -> E (6967) rmt: rmt_rx_enable(513): channel not in init state
07:40:22.207 -> [ 7767][I][sketch_jun5a.ino:77] loop(): [loop] read
07:40:22.207 -> E (7967) rmt: rmt_rx_enable(513): channel not in init state
07:40:22.207 -> E (7967) rmt: rmt_receive(419): channel not in enable state
07:40:23.243 -> [ 8772][I][sketch_jun5a.ino:77] loop(): [loop] read
07:40:23.243 -> E (8972) rmt: rmt_rx_enable(513): channel not in init state
07:40:23.243 -> E (8972) rmt: rmt_receive(419): channel not in enable state
07:40:24.243 -> [ 9772][I][sketch_jun5a.ino:77] loop(): [loop] read
07:40:24.243 -> E (9972) rmt: rmt_rx_enable(513): channel not in init state
07:40:24.243 -> E (9972) rmt: rmt_receive(419): channel not in enable state
07:40:25.247 -> [ 10777][I][sketch_jun5a.ino:77] loop(): [loop] read
07:40:25.247 -> E (10977) rmt: rmt_rx_enable(513): channel not in init state
07:40:25.247 -> E (10977) rmt: rmt_receive(419): channel not in enable state
