esp now TX Data Rate
yanis88
Postby yanis88 » Thu Jun 26, 2025 6:44 pm
I'm new to working with the esp32 and still trying to wrap my head around how the protocol works when setting the protocol is set manually e.g.
esp_wifi_set_protocol(WIFI_IF_STA, <protocol_value>);
esp_wifi_config_espnow_rate(WIFI_IF_STA, <phy_rate>);
My understanding based on the docs and the esp_wifi_types.h is that the <protocol_value> can be one of the following:
  • 1 --> 11B
  • 3 --> 11BG
  • 7 --> 11BGN
  • 8 --> LR
  • 15 --> 11BGN+LR
As for the phy_rate looking at the wifi_phy_rate_t in the same header as above (correct me if I'm wrong):
  • 0-7 --> 11B
  • 0-15 --> 11BG
  • 0-31 --> 11BGN
  • 0-7 + 41-42 --> LR
  • 0-42 --> 11BGN+LR
I am not using an Access Point - just broadcasting packets - and I am checking in the esp_wifi_set_promiscuous_rx_cb(<callback>) the rx_ctrl.rate, rx_ctrl.mcs, and rx_ctrl.sig_mode.
Here's what confuses me:
  • When I use rate 41 and the protocol is set to LR, I get rx_ctrl.rate=25 and rx_ctrl.mcs=0 (that one is expected). Where does the 25 come from? Which rates are used for the LR?
  • When I try 11N and setting the rate to 31, the received rate is somewhere in the 20s and the mcs is usually 6.
  • Is there a clear mapping between the rates and the protocol used?
  • Throughput looks the same at 1Mbps and WIFI_PHY_RATE_LORA_250K which seems to cap at around 350kbps for a payload of 250 bytes
Thanks!
nopnop2002
Contact:
Re: esp now TX Data Rate
Postby nopnop2002 » Fri Jun 27, 2025 10:25 pm
Please try increasing the payload size.
If we send a payload of 1470 bytes, the communication speed will be about 7060 Bytes/Sec (55.2M Bits/Sec).
In ESPNOW Ver1, the maximum payload size was 250 bytes, but in Ver2 it has been expanded to 1470 bytes.
Since ESPNOW for ESP8266 is Ver1, there is a limit of 250 bytes when communicating with the ESP8266.
MicroController
Postby MicroController » Sat Jun 28, 2025 11:52 am
Huh? (7060 kilo-bytes?)
nopnop2002
Contact:
Postby nopnop2002 » Sat Jun 28, 2025 2:22 pm
I got the unit wrong.
about 70.6 KBytes/Sec (552K Bits/Sec).
Users browsing this forum: ChatGPT-User, PerplexityBot, Qwantbot and 2 guests
