I am facing an issue with a project on an ESP32S2 (Wemos S2 Mini) and I'm about to go insane.
In a nutshell, my startup code has started crashing once I added some print statements in a completely other class. I therefore believe I have some sort of memory corruption issue, but I can't seem to track it down. The behavior is utterly baffling to me.
This is the crashing function:
template <class T>
void Display::debugPrint(T message)
Serial.print("this: ");
Serial.println((int)this);
Serial.print("¤t_debug_display_: ");
Serial.println((int)¤t_debug_display_);
Serial.print("current_debug_display_: ");
Serial.println((int)current_debug_display_);
Serial.println("\n");
delay(500);
current_debug_display_->print(message);
Inside the setup() function, I call this code like this:
Serial.print("&display: ");
Serial.println((int)&display);
Serial.print("display.current_debug_display_: ");
Serial.println((int)display.current_debug_display_);
Serial.print("&display.current_debug_display_: ");
Serial.println((int)&display.current_debug_display_);
Serial.println("---");
display.debugPrint("Loading...\n");
&display: 1073497384
&display.current_debug_display_: 1073497576
display.current_debug_display_: 1073497400
this: 1073497384
¤t_debug_display_: 1073497559
current_debug_display_: -256Then the program crashes, with this backtrace:
================== CURRENT THREAD REGISTERS ===================
exccause 0x1c (LoadProhibitedCause)
excvaddr 0xffffff00
======================== THREADS INFO =========================
#0 0x40085ae5 in Print::write (this=0xffffff00, str=0x3f000b05 "Loading...
") at C:/Users/samvdp/.platformio/packages/framework-arduinoespressif32/cores/esp32/Print.h:67
#1 0x40086248 in Print::print (this=0xffffff00, str=0x3f000b05 "Loading...
") at C:/Users/samvdp/.platformio/packages/framework-arduinoespressif32/cores/esp32/Print.cpp:90
#2 0x40082900 in Display::debugPrint<char const*> (this=0x3ffc4528 <display>, message=0x3f000b05 "Loading...
") at include/Display.h:111
#3 0x40083540 in setup () at src/main.cpp:68
#4 0x40088855 in loopTask (pvParameters=0x0) at C:/Users/samvdp/.platformio/packages/framework-arduinoespressif32/cores/esp32/main.cpp:42
Another thing I don't understand: The main loop of this project is just
void loop()
display.debugPrint("Yeah?\n");
delay(250);
void loop()
this: 1073497384
¤t_debug_display_: 1073497576
I would highly appreciate any suggestions on what to try!
Thanks,
Bart
EDIT:
I added one more check. I'm doing a
Serial.println(sizeof(Display));
If I look at the coredump in gdb, the code seems to be correct
0x40083af0 <_ZN7Display11debugPrint2IPKcEEvT_> entry a1, 32
0x40083af3 <_ZN7Display11debugPrint2IPKcEEvT_+3> l32r a7, 0x4008009c <_stext+124> (0x3ffc4a88 <USBSerial>
0x40083af6 <_ZN7Display11debugPrint2IPKcEEvT_+6> movi.n a12, 10
0x40083af8 <_ZN7Display11debugPrint2IPKcEEvT_+8> movi a11, 204
0x40083afb <_ZN7Display11debugPrint2IPKcEEvT_+11> mov.n a10, a7
0x40083afd <_ZN7Display11debugPrint2IPKcEEvT_+13> call8 0x4008721c <_ZN5Print7printlnEji>
