Help to merge HID and MSC instances together
rtek1000
Postby rtek1000 » Mon Jun 30, 2025 7:33 pm
I would like to operate with Mouse, Keyboard and Flash Drive, for this it is necessary to have support for USB Host with HID class and MSC class. And since the ESP32-S3 has only 1 USB Host (OTG) port, it is necessary to use a USB HUB as well.
There are already separate examples one for USB Host with HID class and other for USB Host with MSC class. And support for USB HUB is already implemented as well. The examples work alone (HID or MSC):
https://github.com/espressif/esp-idf/tr ... s/usb/host
The code I've managed to put together so far is this (using HID code as a basis):
 * SPDX-FileCopyrightText: 2022-2023 Espressif Systems (Shanghai) CO LTD
 * SPDX-License-Identifier: Unlicense OR CC0-1.0
#include <stdio.h>
#include <stdbool.h>
#include <string.h>
#include <unistd.h>
#include "freertos/task.h"
#include "freertos/queue.h"
#include "esp_err.h"
#include "esp_log.h"
#include "usb/usb_host.h"
#include "errno.h"
#include "driver/gpio.h"
#include "usb/hid_host.h"
#include "usb/hid_usage_keyboard.h"
#include "usb/hid_usage_mouse.h"
#include <stdlib.h>
#include <assert.h>
#include <sys/stat.h>
#include <dirent.h>
#include <inttypes.h>
#include "sdkconfig.h"
#include "esp_timer.h"
#include "usb/msc_host.h"
#include "usb/msc_host_vfs.h"
#include "ffconf.h"
/* GPIO Pin number for quit from example logic */
#define APP_QUIT_PIN     GPIO_NUM_0 // BOOT button on most boards
static const char *TAG = "example";
#define MNT_PATH         "/usb"     // Path in the Virtual File System, where the USB flash drive is going to be mounted
#define BUFFER_SIZE      4096       // The read/write performance can be improved with larger buffer for the cost of RAM, 4kB is enough for most usecases
// IMPORTANT NOTE
// MSC Class Driver is not fully support connecting devices through external Hub.
// TODO: Remove this line after MSC Class Driver will support it
static bool dev_present = false;
 * @brief Application Queue and its messages ID
QueueHandle_t app_event_queue = NULL;
static QueueHandle_t app_queue;
typedef struct {
    enum {
        APP_QUIT,                // Signals request to exit the application
        APP_DEVICE_CONNECTED,    // USB device connect event
        APP_DEVICE_DISCONNECTED, // USB device disconnect event
    } id;
    union {
        uint8_t new_dev_address; // Address of new USB device for APP_DEVICE_CONNECTED event if
    } data;
} app_message_t;
 * @brief BOOT button pressed callback
 * Signal application to exit the main task
 * @param[in] arg Unused
static void gpio_cb(void *arg)
    BaseType_t xTaskWoken = pdFALSE;
    app_message_t message = {
        .id = APP_QUIT,
    if (app_queue) {
        xQueueSendFromISR(app_queue, &message, &xTaskWoken);
    if (xTaskWoken == pdTRUE) {
        portYIELD_FROM_ISR();
 * @brief MSC driver callback
 * Signal device connection/disconnection to the main task
 * @param[in] event MSC event
 * @param[in] arg   MSC event data
static void msc_event_cb(const msc_host_event_t *event, void *arg)
    if (event->event == MSC_DEVICE_CONNECTED) {
        ESP_LOGI(TAG, "MSC device connected (usb_addr=%d)", event->device.address);
            .id = APP_DEVICE_CONNECTED,
            .data.new_dev_address = event->device.address,
        xQueueSend(app_queue, &message, portMAX_DELAY);
    } else if (event->event == MSC_DEVICE_DISCONNECTED) {
        ESP_LOGI(TAG, "MSC device disconnected");
            .id = APP_DEVICE_DISCONNECTED,
static void print_device_info(msc_host_device_info_t *info)
    const size_t megabyte = 1024 * 1024;
    uint64_t capacity = ((uint64_t)info->sector_size * info->sector_count) / megabyte;
    printf("Device info:\n");
    printf("\t Capacity: %llu MB\n", capacity);
    printf("\t Sector size: %"PRIu32"\n", info->sector_size);
    printf("\t Sector count: %"PRIu32"\n", info->sector_count);
    printf("\t PID: 0x%04X \n", info->idProduct);
    printf("\t VID: 0x%04X \n", info->idVendor);
#ifndef CONFIG_NEWLIB_NANO_FORMAT
    wprintf(L"\t iProduct: %S \n", info->iProduct);
    wprintf(L"\t iManufacturer: %S \n", info->iManufacturer);
    wprintf(L"\t iSerialNumber: %S \n", info->iSerialNumber);
#endif
static void file_operations(void)
    const char *directory = "/usb/esp";
    const char *file_path = "/usb/esp/test.txt";
    // Create /usb/esp directory
    struct stat s = {0};
    bool directory_exists = stat(directory, &s) == 0;
    if (!directory_exists) {
        if (mkdir(directory, 0775) != 0) {
            ESP_LOGE(TAG, "mkdir failed with errno: %s", strerror(errno));
    // Create /usb/esp/test.txt file, if it doesn't exist
    if (stat(file_path, &s) != 0) {
        ESP_LOGI(TAG, "Creating file");
        FILE *f = fopen(file_path, "w");
        if (f == NULL) {
            ESP_LOGE(TAG, "Failed to open file for writing");
            return;
        fprintf(f, "Hello World!\n");
        fclose(f);
    // Read back the file
    FILE *f;
    ESP_LOGI(TAG, "Reading file");
    f = fopen(file_path, "r");
    if (f == NULL) {
        ESP_LOGE(TAG, "Failed to open file for reading");
        return;
    char line[64];
    fgets(line, sizeof(line), f);
    fclose(f);
    // strip newline
    char *pos = strchr(line, '\n');
    if (pos) {
        *pos = '\0';
    ESP_LOGI(TAG, "Read from file '%s': '%s'", file_path, line);
void speed_test(void)
#define TEST_FILE "/usb/esp/dummy"
#define ITERATIONS  256  // 256 * 4kb = 1MB
    int64_t test_start, test_end;
    FILE *f = fopen(TEST_FILE, "wb+");
    if (f == NULL) {
        return;
    // Set larger buffer for this file. It results in larger and more effective USB transfers
    setvbuf(f, NULL, _IOFBF, BUFFER_SIZE);
    // Allocate application buffer used for read/write
    uint8_t *data = malloc(BUFFER_SIZE);
    assert(data);
    ESP_LOGI(TAG, "Writing to file %s", TEST_FILE);
    test_start = esp_timer_get_time();
    for (int i = 0; i < ITERATIONS; i++) {
        if (fwrite(data, BUFFER_SIZE, 1, f) == 0) {
            return;
    test_end = esp_timer_get_time();
    ESP_LOGI(TAG, "Write speed %1.2f MiB/s", (BUFFER_SIZE * ITERATIONS) / (float)(test_end - test_start));
    rewind(f);
    ESP_LOGI(TAG, "Reading from file %s", TEST_FILE);
        if (0 == fread(data, BUFFER_SIZE, 1, f)) {
            return;
    ESP_LOGI(TAG, "Read speed %1.2f MiB/s", (BUFFER_SIZE * ITERATIONS) / (float)(test_end - test_start));
    fclose(f);
    free(data);
 * @brief APP event group
 * Application logic can be different. There is a one among other ways to distingiush the
 * event by application event group.
 * In this example we have two event groups:
 * APP_EVENT            - General event, which is APP_QUIT_PIN press event (Generally, it is IO0).
 * APP_EVENT_HID_HOST   - HID Host Driver event, such as device connection/disconnection or input report.
typedef enum {
    APP_EVENT = 0,
    APP_EVENT_HID_HOST
} app_event_group_t;
 * @brief APP event queue
 * This event is used for delivering the HID Host event from callback to a task.
typedef struct {
    app_event_group_t event_group;
    /* HID Host - Device related info */
    struct {
        hid_host_device_handle_t handle;
        hid_host_driver_event_t event;
        void *arg;
    } hid_host_device;
} app_event_queue_t;
 * @brief HID Protocol string names
static const char *hid_proto_name_str[] = {
    "NONE",
    "KEYBOARD",
    "MOUSE"
 * @brief Key event
typedef struct {
    enum key_state {
        KEY_STATE_PRESSED = 0x00,
        KEY_STATE_RELEASED = 0x01
    } state;
    uint8_t modifier;
    uint8_t key_code;
} key_event_t;
/* Main char symbol for ENTER key */
#define KEYBOARD_ENTER_MAIN_CHAR    '\r'
/* When set to 1 pressing ENTER will be extending with LineFeed during serial debug output */
#define KEYBOARD_ENTER_LF_EXTEND    1
 * @brief Scancode to ascii table
const uint8_t keycode2ascii [57][2] = {
    {0, 0}, /* HID_KEY_NO_PRESS        */
    {0, 0}, /* HID_KEY_ROLLOVER        */
    {0, 0}, /* HID_KEY_POST_FAIL       */
    {0, 0}, /* HID_KEY_ERROR_UNDEFINED */
    {'a', 'A'}, /* HID_KEY_A               */
    {'b', 'B'}, /* HID_KEY_B               */
    {'c', 'C'}, /* HID_KEY_C               */
    {'d', 'D'}, /* HID_KEY_D               */
    {'e', 'E'}, /* HID_KEY_E               */
    {'f', 'F'}, /* HID_KEY_F               */
    {'g', 'G'}, /* HID_KEY_G               */
    {'h', 'H'}, /* HID_KEY_H               */
    {'i', 'I'}, /* HID_KEY_I               */
    {'j', 'J'}, /* HID_KEY_J               */
    {'k', 'K'}, /* HID_KEY_K               */
    {'l', 'L'}, /* HID_KEY_L               */
    {'m', 'M'}, /* HID_KEY_M               */
    {'n', 'N'}, /* HID_KEY_N               */
    {'o', 'O'}, /* HID_KEY_O               */
    {'p', 'P'}, /* HID_KEY_P               */
    {'q', 'Q'}, /* HID_KEY_Q               */
    {'r', 'R'}, /* HID_KEY_R               */
    {'s', 'S'}, /* HID_KEY_S               */
    {'t', 'T'}, /* HID_KEY_T               */
    {'u', 'U'}, /* HID_KEY_U               */
    {'v', 'V'}, /* HID_KEY_V               */
    {'w', 'W'}, /* HID_KEY_W               */
    {'x', 'X'}, /* HID_KEY_X               */
    {'y', 'Y'}, /* HID_KEY_Y               */
    {'z', 'Z'}, /* HID_KEY_Z               */
    {'1', '!'}, /* HID_KEY_1               */
    {'2', '@'}, /* HID_KEY_2               */
    {'3', '#'}, /* HID_KEY_3               */
    {'4', '$'}, /* HID_KEY_4               */
    {'5', '%'}, /* HID_KEY_5               */
    {'6', '^'}, /* HID_KEY_6               */
    {'7', '&'}, /* HID_KEY_7               */
    {'8', '*'}, /* HID_KEY_8               */
    {'9', '('}, /* HID_KEY_9               */
    {'0', ')'}, /* HID_KEY_0               */
    {KEYBOARD_ENTER_MAIN_CHAR, KEYBOARD_ENTER_MAIN_CHAR}, /* HID_KEY_ENTER           */
    {0, 0}, /* HID_KEY_ESC             */
    {'\b', 0}, /* HID_KEY_DEL             */
    {0, 0}, /* HID_KEY_TAB             */
    {' ', ' '}, /* HID_KEY_SPACE           */
    {'-', '_'}, /* HID_KEY_MINUS           */
    {'=', '+'}, /* HID_KEY_EQUAL           */
    {'[', '{'}, /* HID_KEY_OPEN_BRACKET    */
    {']', '}'}, /* HID_KEY_CLOSE_BRACKET   */
    {'\\', '|'}, /* HID_KEY_BACK_SLASH      */
    {'\\', '|'}, /* HID_KEY_SHARP           */  // HOTFIX: for NonUS Keyboards repeat HID_KEY_BACK_SLASH
    {';', ':'}, /* HID_KEY_COLON           */
    {'\'', '"'}, /* HID_KEY_QUOTE           */
    {'`', '~'}, /* HID_KEY_TILDE           */
    {',', '<'}, /* HID_KEY_LESS            */
    {'.', '>'}, /* HID_KEY_GREATER         */
    {'/', '?'} /* HID_KEY_SLASH           */
 * @brief Makes new line depending on report output protocol type
 * @param[in] proto Current protocol to output
static void hid_print_new_device_report_header(hid_protocol_t proto)
    static hid_protocol_t prev_proto_output = -1;
    if (prev_proto_output != proto) {
        prev_proto_output = proto;
        printf("\r\n");
        if (proto == HID_PROTOCOL_MOUSE) {
            printf("Mouse\r\n");
        } else if (proto == HID_PROTOCOL_KEYBOARD) {
            printf("Keyboard\r\n");
            printf("Generic\r\n");
        fflush(stdout);
 * @brief HID Keyboard modifier verification for capitalization application (right or left shift)
 * @param[in] modifier
 * @return true  Modifier was pressed (left or right shift)
 * @return false Modifier was not pressed (left or right shift)
static inline bool hid_keyboard_is_modifier_shift(uint8_t modifier)
    if (((modifier & HID_LEFT_SHIFT) == HID_LEFT_SHIFT) ||
            ((modifier & HID_RIGHT_SHIFT) == HID_RIGHT_SHIFT)) {
        return true;
    return false;
 * @brief HID Keyboard get char symbol from key code
 * @param[in] modifier  Keyboard modifier data
 * @param[in] key_code  Keyboard key code
 * @param[in] key_char  Pointer to key char data
 * @return true  Key scancode converted successfully
 * @return false Key scancode unknown
static inline bool hid_keyboard_get_char(uint8_t modifier,
                                         uint8_t key_code,
                                         unsigned char *key_char)
    uint8_t mod = (hid_keyboard_is_modifier_shift(modifier)) ? 1 : 0;
    if ((key_code >= HID_KEY_A) && (key_code <= HID_KEY_SLASH)) {
        *key_char = keycode2ascii[key_code][mod];
        // All other key pressed
        return false;
    return true;
 * @brief HID Keyboard print char symbol
 * @param[in] key_char  Keyboard char to stdout
static inline void hid_keyboard_print_char(unsigned int key_char)
    if (!!key_char) {
        putchar(key_char);
#if (KEYBOARD_ENTER_LF_EXTEND)
        if (KEYBOARD_ENTER_MAIN_CHAR == key_char) {
            putchar('\n');
#endif // KEYBOARD_ENTER_LF_EXTEND
        fflush(stdout);
 * @brief Key Event. Key event with the key code, state and modifier.
 * @param[in] key_event Pointer to Key Event structure
static void key_event_callback(key_event_t *key_event)
    unsigned char key_char;
    hid_print_new_device_report_header(HID_PROTOCOL_KEYBOARD);
    if (KEY_STATE_PRESSED == key_event->state) {
        if (hid_keyboard_get_char(key_event->modifier,
                                  key_event->key_code, &key_char)) {
            hid_keyboard_print_char(key_char);
 * @brief Key buffer scan code search.
 * @param[in] src       Pointer to source buffer where to search
 * @param[in] key       Key scancode to search
 * @param[in] length    Size of the source buffer
static inline bool key_found(const uint8_t *const src,
                             uint8_t key,
                             unsigned int length)
    for (unsigned int i = 0; i < length; i++) {
        if (src[i] == key) {
            return true;
    return false;
 * @brief USB HID Host Keyboard Interface report callback handler
 * @param[in] data    Pointer to input report data buffer
 * @param[in] length  Length of input report data buffer
static void hid_host_keyboard_report_callback(const uint8_t *const data, const int length)
    hid_keyboard_input_report_boot_t *kb_report = (hid_keyboard_input_report_boot_t *)data;
    if (length < sizeof(hid_keyboard_input_report_boot_t)) {
        return;
    static uint8_t prev_keys[HID_KEYBOARD_KEY_MAX] = { 0 };
    key_event_t key_event;
    for (int i = 0; i < HID_KEYBOARD_KEY_MAX; i++) {
        // key has been released verification
        if (prev_keys[i] > HID_KEY_ERROR_UNDEFINED &&
                !key_found(kb_report->key, prev_keys[i], HID_KEYBOARD_KEY_MAX)) {
            key_event.key_code = prev_keys[i];
            key_event.modifier = 0;
            key_event.state = KEY_STATE_RELEASED;
            key_event_callback(&key_event);
        // key has been pressed verification
        if (kb_report->key[i] > HID_KEY_ERROR_UNDEFINED &&
                !key_found(prev_keys, kb_report->key[i], HID_KEYBOARD_KEY_MAX)) {
            key_event.key_code = kb_report->key[i];
            key_event.modifier = kb_report->modifier.val;
            key_event.state = KEY_STATE_PRESSED;
    memcpy(prev_keys, &kb_report->key, HID_KEYBOARD_KEY_MAX);
 * @brief USB HID Host Mouse Interface report callback handler
static void hid_host_mouse_report_callback(const uint8_t *const data, const int length)
    hid_mouse_input_report_boot_t *mouse_report = (hid_mouse_input_report_boot_t *)data;
    if (length < sizeof(hid_mouse_input_report_boot_t)) {
        return;
    static int x_pos = 0;
    static int y_pos = 0;
    // Calculate absolute position from displacement
    x_pos += mouse_report->x_displacement;
    y_pos += mouse_report->y_displacement;
    hid_print_new_device_report_header(HID_PROTOCOL_MOUSE);
    printf("X: %06d\tY: %06d\t|%c|%c|\r",
           x_pos, y_pos,
           (mouse_report->buttons.button1 ? 'o' : ' '),
           (mouse_report->buttons.button2 ? 'o' : ' '));
    fflush(stdout);
 * @brief USB HID Host Generic Interface report callback handler
 * 'generic' means anything else than mouse or keyboard
static void hid_host_generic_report_callback(const uint8_t *const data, const int length)
    hid_print_new_device_report_header(HID_PROTOCOL_NONE);
    for (int i = 0; i < length; i++) {
        printf("%02X", data[i]);
    putchar('\r');
 * @brief USB HID Host interface callback
 * @param[in] hid_device_handle  HID Device handle
 * @param[in] event              HID Host interface event
 * @param[in] arg                Pointer to arguments, does not used
void hid_host_interface_callback(hid_host_device_handle_t hid_device_handle,
                                 const hid_host_interface_event_t event,
                                 void *arg)
    uint8_t data[64] = { 0 };
    size_t data_length = 0;
    hid_host_dev_params_t dev_params;
    ESP_ERROR_CHECK(hid_host_device_get_params(hid_device_handle, &dev_params));
    switch (event) {
    case HID_HOST_INTERFACE_EVENT_INPUT_REPORT:
        ESP_ERROR_CHECK(hid_host_device_get_raw_input_report_data(hid_device_handle,
        data,
        64,
        &data_length));
        if (HID_SUBCLASS_BOOT_INTERFACE == dev_params.sub_class) {
            if (HID_PROTOCOL_KEYBOARD == dev_params.proto) {
                hid_host_keyboard_report_callback(data, data_length);
            } else if (HID_PROTOCOL_MOUSE == dev_params.proto) {
                hid_host_mouse_report_callback(data, data_length);
            hid_host_generic_report_callback(data, data_length);
    case HID_HOST_INTERFACE_EVENT_DISCONNECTED:
        ESP_LOGI(TAG, "HID Device, protocol '%s' DISCONNECTED",
                 hid_proto_name_str[dev_params.proto]);
        ESP_ERROR_CHECK(hid_host_device_close(hid_device_handle));
    case HID_HOST_INTERFACE_EVENT_TRANSFER_ERROR:
        ESP_LOGI(TAG, "HID Device, protocol '%s' TRANSFER_ERROR",
    default:
        ESP_LOGE(TAG, "HID Device, protocol '%s' Unhandled event",
 * @brief USB HID Host Device event
 * @param[in] event              HID Host Device event
void hid_host_device_event(hid_host_device_handle_t hid_device_handle,
                           const hid_host_driver_event_t event,
                           void *arg)
    switch (event) {
    case HID_HOST_DRIVER_EVENT_CONNECTED:
        ESP_LOGI(TAG, "HID Device, protocol '%s' CONNECTED",
        const hid_host_device_config_t dev_config = {
            .callback = hid_host_interface_callback,
            .callback_arg = NULL
        ESP_ERROR_CHECK(hid_host_device_open(hid_device_handle, &dev_config));
//        if (HID_SUBCLASS_BOOT_INTERFACE == dev_params.sub_class) {
//            ESP_ERROR_CHECK(hid_class_request_set_protocol(hid_device_handle, HID_REPORT_PROTOCOL_BOOT));
//            if (HID_PROTOCOL_KEYBOARD == dev_params.proto) {
//                ESP_ERROR_CHECK(hid_class_request_set_idle(hid_device_handle, 0, 0));
        ESP_ERROR_CHECK(hid_host_device_start(hid_device_handle));
    default:
 * @brief Start USB Host install and handle common USB host library events while app pin not low
 * @param[in] arg  Not used
static void usb_lib_task(void *arg)
    const usb_host_config_t host_config = {
        .skip_phy_setup = false,
        .intr_flags = ESP_INTR_FLAG_LEVEL1,
    ESP_ERROR_CHECK(usb_host_install(&host_config));
    const msc_host_driver_config_t msc_config = {
        .create_backround_task = true,
        .task_priority = 5,
        .stack_size = 4096,
        .callback = msc_event_cb,
    ESP_ERROR_CHECK(msc_host_install(&msc_config));
    xTaskNotifyGive(arg);
	bool has_clients = true;
    while (true) {
        uint32_t event_flags;
        usb_host_lib_handle_events(portMAX_DELAY, &event_flags);
        // In this example, there is only one client registered
        // So, once we deregister the client, this call must succeed with ESP_OK
        if (event_flags & USB_HOST_LIB_EVENT_FLAGS_NO_CLIENTS) {
			has_clients = false;
            ESP_ERROR_CHECK(usb_host_device_free_all());
        if (event_flags & USB_HOST_LIB_EVENT_FLAGS_ALL_FREE && !has_clients) {
    ESP_LOGI(TAG, "USB shutdown");
    // Clean up USB Host
    vTaskDelay(10); // Short delay to allow clients clean-up
    ESP_ERROR_CHECK(usb_host_uninstall());
    vTaskDelete(NULL);
 * Signal application to exit the HID Host task
static void gpio_isr_cb(void *arg)
    const app_event_queue_t evt_queue = {
        .event_group = APP_EVENT,
    if (app_event_queue) {
        xQueueSendFromISR(app_event_queue, &evt_queue, &xTaskWoken);
 * @brief HID Host Device callback
 * Puts new HID Device event to the queue
 * @param[in] event             HID Device event
void hid_host_device_callback(hid_host_device_handle_t hid_device_handle,
                              void *arg)
        .event_group = APP_EVENT_HID_HOST,
        // HID Host Device related info
        .hid_host_device.handle = hid_device_handle,
        .hid_host_device.event = event,
        .hid_host_device.arg = arg
        xQueueSend(app_event_queue, &evt_queue, 0);
void app_main(void)
    BaseType_t task_created;
    app_event_queue_t evt_queue;
    ESP_LOGI(TAG, "HID and MSC Host example");
    // Init BOOT button: Pressing the button simulates app request to exit
    // It will disconnect the USB device and uninstall the HID driver and USB Host Lib
    const gpio_config_t input_pin = {
        .pin_bit_mask = BIT64(APP_QUIT_PIN),
        .mode = GPIO_MODE_INPUT,
        .pull_up_en = GPIO_PULLUP_ENABLE,
        .intr_type = GPIO_INTR_NEGEDGE,
    ESP_ERROR_CHECK(gpio_config(&input_pin));
    ESP_ERROR_CHECK(gpio_install_isr_service(ESP_INTR_FLAG_LEVEL1));
    ESP_ERROR_CHECK(gpio_isr_handler_add(APP_QUIT_PIN, gpio_isr_cb, NULL));
    * Create usb_lib_task to:
    * - initialize USB Host library
    * - Handle USB Host events while APP pin in in HIGH state
    task_created = xTaskCreatePinnedToCore(usb_lib_task,
                                           "usb_events",
                                           4096,
                                           xTaskGetCurrentTaskHandle(),
                                           2, NULL, 0);
    assert(task_created == pdTRUE);
    // Wait for notification from usb_lib_task to proceed
    ulTaskNotifyTake(false, 1000);
    * HID host driver configuration
    * - create background task for handling low level event inside the HID driver
    * - provide the device callback to get new HID Device connection event
    const hid_host_driver_config_t hid_host_driver_config = {
        .create_background_task = true,
        .task_priority = 5,
        .stack_size = 4096,
        .core_id = 0,
        .callback = hid_host_device_callback,
    ESP_ERROR_CHECK(hid_host_install(&hid_host_driver_config));
    // Create queue
    app_event_queue = xQueueCreate(10, sizeof(app_event_queue_t));
    ESP_LOGI(TAG, "Waiting for USB Device to be connected");
    msc_host_device_handle_t msc_device = NULL;
    msc_host_vfs_handle_t vfs_handle = NULL;
    while (1) {
        // Wait queue
        if (xQueueReceive(app_event_queue, &evt_queue, portMAX_DELAY)) {
            if (APP_EVENT == evt_queue.event_group) {
                // User pressed button
                usb_host_lib_info_t lib_info;
                ESP_ERROR_CHECK(usb_host_lib_info(&lib_info));
                if (lib_info.num_devices == 0) {
                    // End while cycle
                    ESP_LOGW(TAG, "To shutdown example, remove all USB devices and press button again.");
                    // Keep polling
            if (APP_EVENT_HID_HOST ==  evt_queue.event_group) {
                hid_host_device_event(evt_queue.hid_host_device.handle,
                                      evt_queue.hid_host_device.event,
                                      evt_queue.hid_host_device.arg);
				if (evt_queue.event_group == APP_DEVICE_CONNECTED) {
		            if (dev_present) {
		                ESP_LOGW(TAG, "MSC Example handles only one device at a time");
		                // 0. Change flag
		                dev_present = true;
		                // 1. MSC flash drive connected. Open it and map it to Virtual File System
		                ESP_ERROR_CHECK(msc_host_install_device(msg.data.new_dev_address, &msc_device));
		                const esp_vfs_fat_mount_config_t mount_config = {
		                    .format_if_mount_failed = false,
		                    .max_files = 3,
		                    .allocation_unit_size = 8192,
		                ESP_ERROR_CHECK(msc_host_vfs_register(msc_device, MNT_PATH, &mount_config, &vfs_handle));
		                // 2. Print information about the connected disk
		                msc_host_device_info_t info;
		                ESP_ERROR_CHECK(msc_host_get_device_info(msc_device, &info));
		                msc_host_print_descriptors(msc_device);
		                print_device_info(&info);
		                // 3. List all the files in root directory
		                ESP_LOGI(TAG, "ls command output:");
		                struct dirent *d;
		                DIR *dh = opendir(MNT_PATH);
		                assert(dh);
		                while ((d = readdir(dh)) != NULL) {
		                    printf("%s\n", d->d_name);
		                closedir(dh);
		                // 4. The disk is mounted to Virtual File System, perform some basic demo file operation
		                file_operations();
		                // 5. Perform speed test
		                speed_test();
		                ESP_LOGI(TAG, "Example finished, you can disconnect the USB flash drive");
		        if ((evt_queue.event_group == APP_DEVICE_DISCONNECTED) || (evt_queue.event_group == APP_QUIT)) {
		            if (dev_present) {
		                if (vfs_handle) {
		                    ESP_ERROR_CHECK(msc_host_vfs_unregister(vfs_handle));
		                    vfs_handle = NULL;
		                if (msc_device) {
		                    ESP_ERROR_CHECK(msc_host_uninstall_device(msc_device));
		                    msc_device = NULL;
		            if (evt_queue.event_group == APP_QUIT) {
		                // This will cause the usb_task to exit
		                ESP_ERROR_CHECK(msc_host_uninstall());
    ESP_LOGI(TAG, "HID Driver uninstall");
    ESP_ERROR_CHECK(hid_host_uninstall());
    gpio_isr_handler_remove(APP_QUIT_PIN);
    xQueueReset(app_event_queue);
    vQueueDelete(app_event_queue);
The problem at the moment is that the HID example uses the "evt_queue" pvBuffer, and the MSC example uses the "msg" pvBuffer, but they are not standardized. What would be the best way to standardize this?
HID:
MSC:
        app_message_t msg;
        xQueueReceive(app_queue, &msg, portMAX_DELAY);
        if (msg.id == APP_DEVICE_CONNECTED) {
