VSCode extension: Command not found
julienD
Postby julienD » Tue Jul 15, 2025 4:50 pm
I did not use vscode with esp-idf for some times.
I recently upgraded my linux version to the latest LTS.
Then, I needed to use vscode for esp code developement.
I add some various compilation script errors, I tried: upgrade esp-idf, tools, removed / reinstall vscode extension,
removed / reinstall vscode, remove vscode extensions folder and some other combinations of the previous.
Errors changed during the above process. Now, when I invoke the build command (ctrl E +b), I'm stuck with this message:
Command 'espidf.buildDevice' not found
Do you have any idea of what may happen?
I'm using vscode 1.102.0.
Julien
radurentea
Re: VSCode extension: Command not found
Postby radurentea » Wed Jul 16, 2025 11:38 am
Hi julien,
I think this happens because there are some leftover settings in your setup.
Try to run the command ESP-IDF: Clear Saved ESP-IDF Setups from the Command Palette, if this command doesn't work, you can search for the configuration manually using these 3 commands from the Command Palette, which will open different settings.json files.
Screenshot 2025-07-16 143325.png (5.82 KiB) Viewed 4215 times
Inside these files search for "idf." properties and remove them.
After you've done these steps, try reconfiguring the extension with "ESP-IDF: Configure ESP-IDF Extension" (you might have to reinstall the extension if this command doesn't work and re-run the command again)
Let me know if this fixes your issue!
