I posted an issue here https://github.com/espressif/esp-idf/issues/16246 but I'm not sure that it's a software issue and did not get an answer there so I'm opening this topic.
I'm using a custom board with ESP32-C3-MINI-1, the chip is ESP32-C3 (QFN32) (revision v0.4).
The esp idf version is 5.4.1
What is the expected behavior?
LEDC frequency should not change in light sleep.
What is the actual behavior?
LEDC frequency is reduced by almost 20% in light sleep.
Steps to reproduce
From ledc_basic_example:
1. Set clk_cfg to LEDC_USE_RC_FAST
2. Enable RC_FAST domain to be active during sleep => esp_sleep_pd_config(ESP_PD_DOMAIN_RC_FAST, ESP_PD_OPTION_ON);
3. Allow pin to change during sleep => gpio_sleep_sel_dis(LEDC_OUTPUT_IO);
4. Change some basic parameters to be closer to the actual usecase
5. Add a flag for sleep state to see it on a scope
#include <stdio.h>
#include "driver/ledc.h"
#include "esp_err.h"
#include "esp_sleep.h"
#include "freertos/task.h"
#define LEDC_TIMER LEDC_TIMER_1
#define LEDC_MODE LEDC_LOW_SPEED_MODE
#define LEDC_OUTPUT_IO (2) // Define the output GPIO
#define LEDC_CHANNEL LEDC_CHANNEL_1
#define LEDC_DUTY_RES LEDC_TIMER_10_BIT // Set duty resolution to 10 bits
#define LEDC_DUTY (102) // Set duty to 10%. (2 ** 10) * 10% = 102
#define LEDC_FREQUENCY (2400) // Frequency in Hertz. Set frequency at 2.4 kHz
#define GPIO_FLAG_SLEEP (3)
static void example_ledc_init(void)
// Prepare and then apply the LEDC PWM timer configuration
ledc_timer_config_t ledc_timer = {
.speed_mode = LEDC_MODE,
.duty_resolution = LEDC_DUTY_RES,
.timer_num = LEDC_TIMER,
.freq_hz = LEDC_FREQUENCY, // Set output frequency at 2.4 kHz
.clk_cfg = SOC_MOD_CLK_RC_FAST
ESP_ERROR_CHECK(ledc_timer_config(&ledc_timer));
// Prepare and then apply the LEDC PWM channel configuration
ledc_channel_config_t ledc_channel = {
.channel = LEDC_CHANNEL,
.timer_sel = LEDC_TIMER,
.intr_type = LEDC_INTR_DISABLE,
.gpio_num = LEDC_OUTPUT_IO,
.duty = 0, // Set duty to 0%
.hpoint = 0,
ESP_ERROR_CHECK(ledc_channel_config(&ledc_channel));
static void gpio_init(){
// Configure the GPIO for the sleep flag output
gpio_config_t io_conf = {
.intr_type = GPIO_INTR_DISABLE,
.pin_bit_mask = (1ULL << GPIO_FLAG_SLEEP),
.mode = GPIO_MODE_OUTPUT,
.pull_up_en = 0,
.pull_down_en = 0,
gpio_config(&io_conf);
gpio_set_level(GPIO_FLAG_SLEEP, 0); // Set the GPIO to low initially
void app_main(void)
// Set the LEDC peripheral configuration
example_ledc_init();
gpio_init();
esp_sleep_enable_timer_wakeup(300000); // set sleep duration to 300ms
gpio_sleep_sel_dis(GPIO_FLAG_SLEEP);
while(1){
// Set duty to 10%
ESP_ERROR_CHECK(ledc_set_duty(LEDC_MODE, LEDC_CHANNEL, LEDC_DUTY));
ESP_ERROR_CHECK(ledc_update_duty(LEDC_MODE, LEDC_CHANNEL));
vTaskDelay(pdMS_TO_TICKS(300)); // Wait for 300ms
gpio_set_level(GPIO_FLAG_SLEEP, 1); // Set GPIO to high to indicate sleep state
esp_light_sleep_start(); //sleep for 300ms
gpio_set_level(GPIO_FLAG_SLEEP, 0); // Set GPIO to low to indicate wake state
vTaskDelay(pdMS_TO_TICKS(300)); // Wait for another 300ms before setting duty to 0%
// Set duty to 0%
ESP_ERROR_CHECK(ledc_set_duty(LEDC_MODE, LEDC_CHANNEL, 0));
vTaskDelay(pdMS_TO_TICKS(2000)); // Wait 2s in off state
More Information
The frequency returns to the correct value when the chip exits the sleep state, as shown below.
Yellow : LEDC_OUTPUT_IO
Blue : GPIO_FLAG_SLEEP
The top part of the screenshot shows the whole acquisition of 1s. The bottom part shows a zoomed extract of the acquisition.
Frequency is normal right before sleep (2.402kHz)
It drops during sleep (2.040kHz)
Then goes back to normal in wake state (2.402kHz)
The frequency drop is not the same across all boards
Since my post on github, I did more tests on other boards. I observed drops in frequency from 5% up to 30%.
The frequency is not stable during light sleep
The frequency is stable in wake state, but it oscillates by a few percent during light sleep
Hardware
The board is powered by usb, the module is supplied (3.3V) by an LDO (TLV75733PDBVR)
The pin with the PWM is connected to the gate of a MOSFET
Any ideas on what could cause this behaviour?
