Can the tracing hook macros be redefined in Arduino?
greengnu
Postby greengnu » Thu Jul 17, 2025 12:48 pm
can the FreeRTOS trace hook macros (https://freertos.org/Documentation/02-K ... ce-feature) be used in Arduino?
I tried to use them by creating a custom FreeRTOSConfig.h:
#include_next "freertos/FreeRTOSConfig.h"
#ifdef __cplusplus
extern "C" {
#endif
void vTaskSwitchedIn(void *pxTCB);
void vTaskSwitchedOut(void *pxTCB);
#ifdef __cplusplus
#endif
#define traceTASK_SWITCHED_IN()     vTaskSwitchedIn(pxCurrentTCB)
#define traceTASK_SWITCHED_OUT()    vTaskSwitchedOut(pxCurrentTCB)
and then implementing vTaskSwitchedIn and vTaskSwitchedOut in the .ino, but they never get called.
Adding #define configUSE_TRACE_FACILITY 1 doesn't make a difference either.
Is this possible in Arduino?
lbernstone
Re: Can the tracing hook macros be redefined in Arduino?
Postby lbernstone » Thu Jul 17, 2025 6:04 pm
Arduino-esp32 uses a pre-compiled version of ESP-IDF. This means any #define macros in that code have already been compiled in. This would include those trace macros for FreeRTOS, along with any of the Kconfig CONFIG_XX macros. To make these changes (or enable AppTracing in IDF), you would need to make your own archives with lib-builder, or use arduino as an esp-idf component.
Users browsing this forum: PerplexityBot and 3 guests
