ESP32-C6 getting really hot when Wifi is enabled
Nicco00
Postby Nicco00 » Wed Jul 23, 2025 10:25 am
I have made a custom ESP PCB Design with an ESP32-C6 chip with QFN32 package and internal flash. The board works just fine till the point where the Wifi is enabled.
- Without the wifi enabled the board draws 0.2W (25-30° C)
- with the wifi enabled but not connected: 0.5W (60° C)
- with wifi enabled and connected: 1.9W (+100° C)
The antenna works fine wifi Signal is mostly below 70 dB
I would really appreciate any Help.
Bildschirmfoto 2025-07-23 um 12.23.39.png (172.67 KiB) Viewed 135 times
Bildschirmfoto 2025-07-23 um 12.24.23.png (190 KiB) Viewed 135 times
Re: ESP32-C6 getting really hot when Wifi is enabled
Postby Sprite » Fri Jul 25, 2025 12:23 am
Antennas are pretty sensitive to, well, anything really, to be tuned correctly. How did you tune it, or did you only run the EMC calculations to make sure it's impedance-matched and works on the correct frequency?
Users browsing this forum: Bytespider, ChatGPT-User, Qwantbot and 3 guests
