ESP32C3 SoftAP配网 两分钟后才获取到IP
suki1213
Postby suki1213 » Thu Jul 24, 2025 6:23 am
在使用SoftAP模式对ESP32C3进行配网时 偶尔会出现成功获取到正确的配网信息时 无法成功获取IP 等待两分钟之后才能够成功获取
日志如下
09:57.832729 W (8910719) main: memory: 154740 bytes
10:02.833356 W (8915719) main: memory: 154996 bytes
10:06.647571 W (8919529) wifi:Password length matches WPA2 standards, authmode threshold changes from OPEN to WPA2
10:06.747232 I (8919629) ESP_Project: Received Wi-Fi credentials
10:06.753233 SSID : Ampere Time
10:06.753233 Password : GXFC2024
10:07.833186 W (8920719) main: memory: 154732 bytes
10:10.699258 I (8923579) wifi:primary chan differ, old=1, new=8, start CSA timer
10:11.097868 I (8923979) wifi:switch to channel 8
10:11.102867 I (8923979) wifi:ap channel adjust o:1,1 n:8,2
10:11.108864 I (8923979) wifi:new:<8,2>, old:<1,1>, ap:<8,2>, sta:<0,0>, prof:1, snd_ch_cfg:0x0
10:11.113864 I (8923989) wifi:new:<8,2>, old:<8,2>, ap:<8,2>, sta:<8,0>, prof:1, snd_ch_cfg:0x0
10:11.119863 I (8923989) wifi:state: init -> auth (0xb0)
10:11.125864 I (8924009) wifi:state: auth -> init (0x1100)
10:11.136868 I (8924009) wifi:new:<8,2>, old:<8,2>, ap:<8,2>, sta:<8,0>,
10:11.138869 I (8924009) wifi:primary chan differ, old=8, new=11, start CSA timer
10:11.532564 I (8924419) wifi:switch to channel 11
10:11.538569 I (8924419) wifi:ap channel adjust o:8,2 n:11,2
10:11.544080 I (8924419) wifi:new:<11,2>, old:<8,2>, ap:<11,2>, sta:<8,0>, prof:1, snd_ch_cfg:0x0
10:11.556086 I (8924419) wifi:new:<11,2>, old:<11,2>, ap:<11,2>, sta:<11,0>, prof:1, snd_ch_cfg:0x0
10:11.557088 I (8924429) wifi:state: init -> auth (0xb0)
10:11.561087 I (8924439) wifi:state: auth -> assoc (0x0)
10:11.599603 I (8924479) wifi:state: assoc -> run (0x10)
10:11.695820 I (8924569) wifi:connected with Ampere Time, aid = 32, channel 11, BW20, bssid = 48:81:d4:6a:e9:fc
10:11.700823 I (8924569) wifi:security: WPA2-PSK, phy: bgn, rssi: -63
10:11.766978 I (8924649) wifi:pm start, type: 0
10:11.767979
10:11.774736 I (8924649) wifi:set rx beacon pti, rx_bcn_pti: 14, bcn_timeout: 25000, mt_pti: 14, mt_time: 10000
W (8925719) main: memory: 154196 bytes
10:13.909630 I (8926789) wifi:AP's beacon interval = 102400 us, DTIM period = 1
10:17.832435 W (8930719) main: memory: 154408 bytes
10:21.054806 W (8933939) httpd_txrx: httpd_sock_err: error in recv : 104
10:22.832984 W (8935719) main: memory: 154832 bytes
10:23.147098 I (8936029) wifi:<ba-add>idx:0 (ifx:0, 48:81:d4:6a:e9:fc), tid:0, ssn:3, winSize:64
10:27.832816 W (8940719) main: memory: 154748 bytes
10:32.833400 W (8945719) main: memory: 154748 bytes
10:37.833660 W (8950719) main: memory: 154536 bytes
10:42.833356 W (8955719) main: memory: 154748 bytes
10:47.833648 W (8960719) main: memory: 154748 bytes
10:52.833557 W (8965719) main: memory: 154748 bytes
10:57.833461 W (8970719) main: memory: 154748 bytes
11:02.833465 W (8975719) main: memory: 154748 bytes
11:07.832991 W (8980719) main: memory: 154748 bytes
11:12.833592 W (8985719) main: memory: 154748 bytes
11:17.832967 W (8990719) main: memory: 154748 bytes
11:22.834240 W (8995719) main: memory: 154748 bytes
11:27.832978 W (9000719) main: memory: 154748 bytes
11:32.833170 W (9005719) main: memory: 154748 bytes
11:37.832901 W (9010719) main: memory: 154748 bytes
11:42.833590 W (9015719) main: memory: 153784 bytes
11:42.904613 I (9015789) ESP_Project: IP_EVENT_STA_LOST_IP
11:47.833273 W (9020719) main: memory: 153812 bytes
11:52.833040 W (9025719) main: memory: 151648 bytes
11:57.833887 W (9030719) main: memory: 151648 bytes
11:59.884897 I (9032759) wifi:station: a2:30:d1:80:56:85 leave, AID = 1, reason = 3, bss_flags is 756835, bss:0x3fcc3dcc
11:59.895973 I (9032759) wifi:new:<11,0>, old:<11,2>, ap:<11,2>, sta:<11,0>, prof:1, snd_ch_cfg:0x0
11:59.895973 I (9032769) wifi:<ba-del>idx:2, tid:0
11:59.901168 I (9032769) wifi:<ba-del>idx:5, tid:5
11:59.901168 I (9032769) wifi:<ba-del>idx:4, tid:6
11:59.906171 I (9032779) wifi:<ba-del>idx:3, tid:7
11:59.912174 I (9032779) ESP_Project: WIFI_EVENT_AP_STADISCONNECTED
11:59.918173 W (9032789) main: blue task start: 152104 bytes
11:59.923174 I (9032789) BLE_INIT: BT controller compile version [6cfabcd]
11:59.934172 I (9032799) BLE_INIT: Feature Config, ADV:1, BLE_50:0, DTM:1, SCAN:1, CCA:0, SMP:1, CONNECT:1
11:59.940172 I (9032809) BLE_INIT: Bluetooth MAC: 74:4d:bd:fb:cc:26
11:59.945176 I (9032819) wifi:Coexist!!! Wi-Fi station would only keep waked when available
11:59.946178
11:59.950176 I (9032819) ESP_Project: ble_init init bluetooth
11:59.959284 W (9032839) main: blue task end: 101612 bytes
11:59.964285 I (9032849) ESP_Project: The number handle = 8
11:59.969958 I (9032849) ESP_Project: ESP_GATTS_START_EVT
11:59.975966 I (9032849) ESP_Project: advertising start success
12:02.834259 W (9035719) main: memory: 101568 bytes
12:07.834199 W (9040719) main: memory: 101568 bytes
12:12.833915 W (9045719) main: memory: 101568 bytes
12:17.833963 W (9050719) main: memory: 101568 bytes
12:22.833956 W (9055719) main: memory: 101568 bytes
12:47.833851 W (9080719) main: memory: 101568 bytes
12:52.834174 W (9085719) main: memory: 101440 bytes
12:57.834902 W (9090719) main: memory: 101568 bytes
13:02.833897 W (9095719) main: memory: 101568 bytes
13:04.419169 I (9097299) esp_netif_handlers: sta ip: 192.168.1.54, mask: 255.255.254.0, gw: 192.168.1.1
13:04.424167 I (9097299) ESP_Project: GOT IP:192.168.1.54
13:04.430166 I (9097299) ESP_Project: wifi_info Ampere Time GXFC2024
求解答,谢谢
Users browsing this forum: Semrush [Bot] and 1 guest
