problem with uploading pc encrypted firmware to the esp32-c3
krzysztof.kuczek
Postby krzysztof.kuczek » Thu Jul 24, 2025 4:30 pm
I have a problem uploading PC‑encrypted firmware to the ESP32‑C3 equipped with a flash‑encryption‑capable bootloader.
So what I did:
  • I generated a key and burned it:
    espefuse.py --port COM6 burn_key BLOCK_KEY0 flash_key.bin XTS_AES_128_KEY
  • I built the bootloader with Flash Encryption = ON, flashed it, and then stored it as
    bootloader_custom.bin
  • Then I did:
    espefuse.py --port COM6 burn_efuse SPI_BOOT_CRYPT_CNT 0x1
    espefuse.py -p COM6 burn_bit BLOCK0 0
    espefuse.py -p COM6 burn_bit BLOCK0 4
    espefuse.py -p COM6 burn_bit BLOCK0 1 2
  • I built the Arduino project using PlatformIO and made copies of
    partitions.bin
    and
    firmware.bin
Then I uploaded everything using the --encrypt flag and it works fine:
esptool.py --chip esp32c3 --port COM6 --baud 921600 --before default_reset --after hard_reset write_flash --flash_size detect --encrypt 0x0      bootloader_custom.bin
esptool.py --chip esp32c3 --port COM6 --baud 921600 --before default_reset --after hard_reset write_flash --flash_size detect --encrypt 0x8000   partitions.bin
esptool.py --chip esp32c3 --port COM6 --baud 921600 --before default_reset --after hard_reset write_flash --flash_size detect --encrypt 0x10000  firmware.bin
But I want to encrypt the firmware on my PC like this:
espsecure.py encrypt_flash_data --key flash_key.bin --address 0x10000 --output firmware_enc.bin firmware.bin
and then try to upload without the --encrypt flag:
esptool.py --chip esp32c3 --port COM6 --baud 921600 --before default_reset --after hard_reset write_flash --flash_size detect 0x10000 firmware_enc.bin
but it ends with
Invalid header: 0x0dca6d99
Any hints?
Thank you in advance.
Kris
dmitrij999
Re: problem with uploading pc encrypted firmware to the esp32-c3
Postby dmitrij999 » Sun Aug 03, 2025 8:20 pm
I had the similar problem with ecryption on PC
Could you please try to encrypt with adding the —aes-xts flag?
yangolan
Postby yangolan » Wed Sep 17, 2025 1:19 pm
this problem only occurred because of the encryption? it didn't happen before?
Users browsing this forum: Amazon [Bot], Baidu [Spider], Bing [Bot], Qwantbot, Semrush [Bot] and 3 guests
