[ESP32 AT Firmware] Module Stops Responding After Several Hours of Stable Operation
Aldrin01392
Postby Aldrin01392 » Mon Jul 28, 2025 6:58 am
Hi all,
I'm working on a project using ESP32 running AT firmware (v3.4.0.0). The module is connected to a host MCU (STM32) and communicates via UART using AT commands.
The use case is simple:
The ESP32 connects to a Wi-Fi network using AT+CWJAP,
Then opens a TCP connection using AT+CIPSTART,
And continuously sends data to a remote server using AT+CIPSEND.
This runs repeatedly at a fixed interval (once every few seconds), for many hours.
The issue we are observing is quite strange:
➡️ Everything works perfectly for 6–8 hours, with consistent successful sends and replies from the server.
➡️ But after a random time in this range, one AT+CIPSEND response breaks mid-way, and after that, ESP32 becomes completely unresponsive to further AT commands.
➡️ No error is returned, just a complete stop of replies from the module.
➡️ Echoing shows that the last command was sent properly from the MCU side, but ESP seems stuck or not processing any new command.
We have verified that:
The power supply is stable.
No overlapping or malformed commands are sent.
Flow of data is consistent and within acceptable rates.
We are not using multiple connections (AT+CIPMUX=0).
It feels like the TCP socket or internal state of ESP32 enters an unrecoverable state after many hours of operation.
Questions:
1. Has anyone experienced a similar long-duration TCP issue with AT firmware?
2. Is there a known memory leak, socket timeout, or stack overflow issue in v3.4.0.0 under these conditions?
3. Would enabling AT+CIPSTATE monitoring or resetting the connection every few hours help prevent this?
4. Are there any recommended watchdog or keep-alive mechanisms for long-running TCP sockets in AT mode?
Any advice, pointers, or suggestions are welcome. Thanks in advance!
esp-at
Re: [ESP32 AT Firmware] Module Stops Responding After Several Hours of Stable Operation
Postby esp-at » Thu Sep 04, 2025 7:58 am
Hi Aldrin01392,
Could you please provide more details to see what happened? For example, Could you please visit https://github.com/espressif/esp-at/act ... 7453872398 and download `esp32-wroom-debug-at` this firmware, and have a test. the AT log port should output a lot of logs. please use serial tool to save them with timestamp. This is the direct way to analyze your issue.
Some reply for your questions:
Before each AT release, we systematically test the AT functionality with a large number of testcases for over a week and have not found any issues similar to yours.
- AT+SYSRAM? command to query memory state. btw, if alloc failed, the AT log port should output `alloc failed, size:<requested_size>, caps:<requested_cap>`
- You can configure the TCP send timeout via the AT+CIPTCPOPT command: https://docs.espressif.com/projects/esp ... cmd-tcpopt
I don't think AT+CIPSTATE can do anything for your case. resetting the connection is not a good way to figure it out.
- AT firmware already has multiple watchdogs built in. These include interrupt watchdog, task watchdog, and hardware watchdog. You can search `WDT` in sdkconfig file
- You can configure the TCP keep-alive via the AT+CIPTCPOPT command: https://docs.espressif.com/projects/esp ... cmd-tcpopt
amir.shn
Postby amir.shn » Thu Oct 16, 2025 6:22 pm
Hi Aldrin01392,
I am having exactly the same issue with the UDP connection, i am sending data from my main MCU which is a STM32H7 to the esp32-s2 solo at a sampling rate of approximately 20Hz.I receive busy p... once in a while after an hour and the ESP32 chip becomes completely unresponsive after about 3 hours.
Please let me know if you have found any solution for this issue.
Thanks.
Amir
esp-at
Postby esp-at » Thu Nov 13, 2025 9:56 am
Hi @amir.shn , could you please help debug it according to the comments i posted above.
