Reading Hall Sensor Values from ULP
sslama
Postby sslama » Thu Feb 08, 2018 1:48 pm
I'm trying to get the current measurments from the hall sensor in ULP Mode.
When I'm reading them from a context outside the deep sleep mode like this:
adc1_config_width(ADC_WIDTH_12Bit);
hall_sensor_read();
I get values that change when a magnet is getting closer.
When I try to read those values from ULP I just get random values. I followed the ulp_adc example from espressif changed the channel to ADC1_CHANNEL_0 - also tried Channel 3 - as the documentation says the hall sensor is connected to both.
adc1_config_channel_atten(ADC1_CHANNEL_0, ADC_ATTEN_DB_0);
adc1_config_width(ADC_WIDTH_BIT_12);
adc1_ulp_enable();
I also changed the adc_channel constant in the adc.S file.
Is it even possible to read the values from the hall sensor in deep sleep mode?
WiFive
Re: Reading Hall Sensor Values from ULP
Postby WiFive » Thu Feb 08, 2018 5:52 pm
https://github.com/espressif/esp-idf/bl ... 1627-L1664
You have to write some other registers and it's not that useful without LNA
sslama
Postby sslama » Thu Feb 08, 2018 6:20 pm
So I understand, that the function
hall_sensor_read();
does a lot more than I tried to do in the code I posted.
The thing is - when I call the hall_sensor_read() function from the ULP context it returns the same value as the one I get calling the functions from my seconds code snippet.
What do you mean by "it is not that usefull without an LNA"- sorry - I'm quite new here and in electronics... :)
thanks
Users browsing this forum: Semrush [Bot] and 2 guests
