nanoFramework on ESP32-S3 can't write to file system (FileStream Exception)
Murat Keçeli
Postby Murat Keçeli » Sat Aug 02, 2025 6:59 am
Subject: File System Access Issue on ESP32-S3 with .NET nanoFramework
We are using a device based on the ESP32-S3 (QFN56) with .NET nanoFramework.
Our goal is to store configuration settings in a text file (e.g., 'ayarlar.txt') using SPIFFS file system.
However, all file system operations (creation, writing, reading) fail on the current firmware.
✔️ Device Information:
- Model: ESP32-S3 (QFN56)
- Flash: 16MB
- PSRAM: 8MB
- Firmware: nanoFramework 1.12.4.231 (target: ESP32_S3_ALL)
- Serial Port: COM14 (confirmed connection)
❌ Problem Description:
The following code fails when attempting to create a file:
```csharp
using (var fs = new FileStream(@"\ayarlar.txt", FileMode.Create, FileAccess.Write))
// Exception is thrown here
Error received:
Exception System.Exception - CLR_E_PATH_TOO_LONG (1)
System.IO.NativeIO::GetAttributes
Additionally, trying to list directory contents fails:
```csharp
Directory.GetFiles(@"\");
⚠️ This indicates that the internal file system (SPIFFS) is either missing or not mounted.
🎯 Expected Behavior:
If the firmware includes SPIFFS support, file access via paths like `@"\ayarlar.txt"` should work without exception.
🧪 What We Have Tried:
- Firmware flashed via nanoff using:
--target ESP32_S3_ALL
--serialport COM14
--fwversion 1.12.4.231
--masserase
- Device successfully connects and responds via COM14.
- nanoCLR is running and recognized by Visual Studio.
📌 Our Request:
Please verify whether the current firmware includes SPIFFS support for the ESP32_S3_ALL target.
If not, we kindly request guidance or a rebuilt firmware that includes a working SPIFFS file system section.
We are also open to rebuilding the firmware ourselves if given instructions for enabling SPIFFS and partition configuration.
Kind regards,
Murat Keceli
Users browsing this forum: Amazon [Bot], Barkrowler, Google [Bot], PerplexityBot, Qwantbot and 1 guest
