Hi Everyone,
I'm using esp_crt_bundle_attach for SSL certificate verification in a POST request.
The same code works perfectly in ESP-IDF v5.2(on ESP32-C3), but in v5.5 (on both ESP32-C3 and C5), it fails with:
E (xxxxx) esp-tls-mbedtls: mbedtls_ssl_handshake returned -0x2700
I (xxxxx) esp-tls-mbedtls: Failed to verify peer certificate!
Verified:
esp_crt_bundle_attach used correctly
[ esp_tls_cfg_t cfg = {
.ciphersuites_list = server_supported_ciphersuites,
.crt_bundle_attach = esp_crt_bundle_attach,
TLS config unchanged
Certificate bundle enabled in menuconfig
Flash size and partitions are fine
SNTP time is synced before TLS
idf.py fullclean done
Issue:
Has anything changed in ESP-IDF v5.5 related to certificate bundles or TLS that could cause this? Any fixes or workarounds?
Thanks!
TLS Handshake Fails with esp_crt_bundle_attach in ESP-IDF v5.5 (ESP32-C3/C5)
NavitTripathi
Users browsing this forum: Amazon [Bot], Baidu [Spider], Bytespider, Google [Bot], Semrush [Bot] and 3 guests
