what causes this problem at the very begining.
carleslsregner
I just installed the expressif IDE and as I try to create my very first project this pop up is displayed.
- error in espressif ide.png (33.28 KiB) Viewed 6703 times
kondalkolipaka
- Espressif staff
Re: what causes this problem at the very begining.
It looks like Python was not detected. Did you provide the Python path in the ESP-IDF Configuration window while installing the tools?
You can try setting it manually in Preferences, then click on "Add ESP-IDF" and check if the Python path is being detected correctly.
Also, what IDE version are you using? Our latest release is v3.6.0.
https://github.com/espressif/idf-eclips ... tag/v3.6.0
