vs code with esp-idf extension: no framework found
carleslsregner
Postby carleslsregner » Fri Aug 08, 2025 8:11 am
Good morning:
I am trying to develop a usbtmc (a test and measurement class usb). And right now I am using the VS code and the ESP_IDF extension. I installed the the extension and I am trying to execute a "hello world" program. Once I am able to execute a basic "hello world" application firmware I will develop the usbtmc itself. Let's begin.
The first step is that I do is to "Configure ESP_IDF Extension". I can see that the ESP_IDF is being downloaded and configured. I waited until it is done. I follow the instructions.
I choose the EXPRESS option.
Then I choose Find the esp-idf.
The next step is to create a project -a very simple one-. I clicked the "New Project Wizard".
However, there is something missing... how can this be? Wasn't the ESP-IDF already installed?
What course of action do you recommend me? Should I install the esp-idf from the https://dl.espressif.com/dl/esp-idf/ website and then press the button "Configure ESP_IDF Extension"
Thanks for all. Sorry for the trouble.
esp-idf extension2.png (59.17 KiB) Viewed 7858 times
esp-idf extension4.png (39.19 KiB) Viewed 7858 times
esp-idf extension3.png (61.2 KiB) Viewed 7858 times
carleslsregner
Re: vs code with esp-idf extension: no framework found
Postby carleslsregner » Fri Aug 08, 2025 9:51 am
I found something that may indicicate an error when I try to create a new project:
I am unable to select a framework for the project when I click the button "New project".
What is the best approach to follow in these cases?
Thanks.
esp-idf extension5.png (24.41 KiB) Viewed 7849 times
Last edited by carleslsregner on Fri Aug 08, 2025 10:08 am, edited 1 time in total.
bignacio
Postby bignacio » Wed Aug 20, 2025 6:39 am
If the frameworks are not shown it might be to the configuration not being correct.
Could you share the troubleshooting information such as Doctor Command output as described in here:
https://docs.espressif.com/projects/vsc ... oting.html
