Uart2 Lost Connection or Reading Wrong
ligteltelecom
Postby ligteltelecom » Tue Aug 12, 2025 9:03 pm
I have this problem when I use Uart 2. It starts reading fine, but in the middle it starts reading strange characters.
using an FTD1232 interface read everything correctly.
  Serial2.setRxBufferSize(4096);
  Serial2.setTimeout(512);
  delay(100);
  Serial2.begin(115200, SERIAL_8N1, RX_PIN, TX_PINX);
void Uart2COMTask(void *pvParameters)
  int rxBytesRead = 0;
  char rxBuffer[512];
  while (1)
    if (Serial2.available() > 0)
      rxBytesRead = Serial2.readBytes(rxBuffer, 512);
      for (int i = 0; i < rxBytesRead; i++)
        Serial.write(rxBuffer[i]);
    vTaskDelay(pdMS_TO_TICKS(1));
SerialSecond starting....
␀␀␀␀␀␀␀␀␀␀@�H�8@s4_h2_b1_f1 @ 0x2e4600000
15 NUB_SPMI_A0: s2_h0_b0 @ 0x2e4900000
18 AOP_SPMI0: s4_h0_b0 @ 0x2f4880000
19 AOP_SPMI1: s4_h0_b0 @ 0x2f48c0000
4fbf8fe65e3b7c6:363
4fbf8fe65e3b7c6:365
4fbf8fe65e3b7c6:365
4fbf8fe65e3b7c6:365
4fbf8fe65e3b7c6:365
4fbf8fe65e3b7c6:365
4fbf8fe65e3b7c6:515
4fbf8fe65e3b7c6:517
4fbf8fe65e3b7c6:517
4fbf8fe65e3b7c6:615
1a618789140ad84:702
af714dbce4d39c3:314
e51893b627f0e6e:541
e51893b627f0e6e:545
b5255f381ca81f9:500
b5255f381ca81f9:516
b5255f381ca81f9:524
b5255f381ca81f9:548
b5255f381ca81f9:556
b5255f381ca81f9:564
b5255f381ca81f9:572
b5255f381ca81f9:580
7ab90c923dae682:193
970995cadb21431:612
970995cadb21431:620
970995cadb21431:627
970995cadb21431:523
970995cadb21431:523
970995cadb21431:493
970995cadb21431:495
970995cadb21431:496
␀␀␀␀␀␀␀␀␘�␀␀␀␀␀␀␀␀␀@肒*�33cb:178
f81b84702e533cb:205
f81b84702e533cb:219
␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀�␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀ ␀␀�␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␂␀␀␀␀␀␂␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀ ␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␂␀␀␀␀␀␀␀␀�␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀�␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀ ␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀�␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␂␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␂␀␀␀␀␀␀␀␀␀␀␀␀␀�␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀�␀�␀␀␀␀␀␀␀␀␀�␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀���␀␀␀␀␀␀␀␀␀␁��␀␀␀␀␀␀␀␀␀␀��␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀@␀�␀␀␀␀␀␀␀␀␀@�␀␀␀␀␀␀␀�␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀�␇␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀?␀␀␀␀␀␀␀��␀␀␀␀␀␀␀␀␀␀0␀␀␀ ␏␀␀␀␀␀␀z␀�␀␀␀␀␀␐�␀␀␀␀␀8�␀␀␀␀␀␀␀␀�␀␀␀␀␀��␀␀␀␀␀`��␀␀␀␀␀␀␀␁␀␀␀␀␀%␀␀␀␀␀���␡␀␀␀␀␀␀␀␀␀␀␁��␀␀␀␀␀␀␀�␀␀␀␀␀␀␀�`�␀␀␀␀␀␁␀�␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀�␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␃␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␡�␀␀␀␀␀␀␃␀␀␀␀␀␀␀␀␀␀␀�<␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀���␀␀␀␀␀␀␀␀!��␀␀␀␀␀��␀␀␀␀␀␀␀���␀␀␀␀␀␀␀␃␀␀␀␀␀␀␀␀␀␀␀␔��␀␀␀␀␀�?␀␀␀`��␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀�␏␁␀␀␀␀␀␀␀␀␀␀␀�␟␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀�␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀�␀␀␀␀␀;2�␀␀␀␀␀␀␀␀␀␀␀␀␘␀␀␀␀␐␏��␀␀␀␀␀��␀␀␀␀���␀␀␀␀���␀␀␀␀␀␀␆�?␀␀␀␀␀␡�␀␀␀␀b␗␀␀␀␀���␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␂����␀␀␀␀␀␀␀␀␀␀�␀␀␀␀␀␀␀␀␀��␀␀␀␀␀␀�␀␀␀␀␀���␀␀␀␀␀␀�␀␀␀␀␀␀␀␀␀␀␀�␀␀␀␄$␁�␀␀␀␀␀␀␀␀���␀␀␀␀��␀␀␀␀␀�s��␀␀␀␀␀��␡␀␀␀␀␀␀␀␀␀␀␁␀␀␀␀␀�␀␀␀␀␀␀�␀␀␀␀␀n�␀␀␀␀␀␀���␀␀␀␀␀␀␀␀␀␀␀␀␁@�␀␀␀␀␀␀��␀␀␀␀ p��␀␀␀␀���␀␀␀␀���␀␀␀␀␀␀��␀␀␀␀␀�␀␀␀␀␀␀␀�␀␀␀␀␀���␀␀␀␀␀���␀␀␀␀␀␀␀��␀␀␀␀␀␃␀␀␀␀��␀␀␀␀␀␀␀␀␀␀��␀␀␀␀␀␀␀␀␀␀␀␀␀�␀␅␀␀␀␀␀␀␀␀␀␟␀␀␀␀␐�␀␀␀␀␀␀�␀h␀␀␀␀␀␀_␁␀␀␀␀␀␀�?�␀␀␀␀␀␀␀�␀␀␀␀␀␀␟�␀␀␀␀␀␅��␀␀␀␀␀�␀�␀␀␀␀␀␀␀␀␀␀�␇␀␀␀@␀���␀␀␀␀␀���␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀���␀␀␀␀␀␀␀␀␀␀␀␀␀��␁␀␀␀␀␀␁␆␀␀␀␀l�␀␀␀␀␀␀␃␀␀␀␀��␀␀␀␀␀␀␀�␀␀␀␀����␀␀␀␀␀␀ �␀�␀␀␀␀␀␀␀␀@␀/�␀␀␀␀␀␀␀␀␀␀␀␀�␀␀␀␀␀��␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␄��␀␀␀␀␀␐��␀␀␀␀␀␀�␀␀␀␀␀␀␀␀␀␀␀␀␀␀�␄��␀␀␀␀␘���␀␀␀␀␀␀␀␀␀␀�␀␀␀␀␀␀
@␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀6␀␀␀␀␀␀␀@��␁␀␀␀␀␀␀␀�␁␀␀␀␀␀␀␀␀�␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀���␀␀␀␀␀␀␀␀␀����␁␀␀␀␀␀3�␘␀␀␀␀�␀␀␀␀@��␀␀␀␀␀␐␀�␀␀␀␀␀␀��␀�␀␀␀␀␀␀␀␀␐��␀␀␀␀␀␀��␀␏␀␀␀␀␀␀␀␀�␐␀␀␀␀␀␀␀␀␀␀���␃␀␀␀␀␀␀���␀␀␀␀␀␀���␇␀␀␀␀␀�␘��␀␀␀␀␀␀␀␀�␀␀␀␀␀␀␀�␄␀␀␀ ␏�␀␀␀␀␀���␀␀␀␄␀␀��␀␀␀␀␀␀␀␀␀␀��␀␀␀␀␀���␀␀␀␀␀@␀␀␀␀`␡�␀␀␀␐␀␀␀␀␀␀`��␀␀␀␀␀�~␀␀␀␀␀�␡␀␀␀␀␀ ���␀␀␀␀␀␀��␀␀␀␀␀␀␀␄��␀␀␀␀␀␀␀␀␀␀␀�␀␀␀␀␀���␀␀␀␀␀␀��␁␀␀␀��␂␀␀␀␀0�␀␀␀␀␀␀�<�␀␀␀␀␀␀␀x␀␀␀␀␀␀␀��␀␀␀␀␀␀ ␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀����␀␀␀␀���␀␀␀␀␀�␀␀␀␀␀␀␀␀␀␀�|�␃␀␀␀␀��␀␀␀␀␀␀␀␀␀␀␐x��␁␀␀␀���␀�?␀␀␀␀␀␀�␄␀␀␀␀��␀␀��␀␀␀␀␀␀��␀␀␀␀␀�␀␀␀␀␀␀␀␀␀␀␀��␀@␀␀␀␀�␀␀␀␀␀␀␀␀␀␀␀␂�␀␀␀��␀␀␀␀␀␀␀ ␀␀␀0�␁␀␀␀␀␀␀␀␀␀�␃␀␀␀␀␀␀␀␀
␀␀␀␀␀␀␀@��␀␀␀␀␀�ǟ�␀␀␀␀␀␀␀␀␀��␃␀␀␀␀��␀␀␀␀���<␀␀␀␀␀␀␀␀␀��␁␀␀␀␀��␀␀␀␀␀␀␀␀���␀␀␀␀␀␀␀␀␀`������␞␀␀␀␀␀p�␀␀␀␀�␀␀␀␀␀␀␀��␀␀␀␀����␀␀␀␀�␡��␀␀␀␀␀␀␀␀␀␐���␀␀␀␀␄␀��␀␀␀␀␀␀␀␀��␀␀␀␀␀␀��␀␀␀␀␀����␀␀␀␀␀␀␀␖��␀␀␀␀␀␟��␀␀␀␀␀␀␀␀␀␀��␁␀␀␀␀␀␀���␁␀␀␀␀␀�␀␀␀␀␀���␀␀␀ ␀␡�␀␀␀␀x␀�␀␀␀␀␀␀�␅�␀␀␀␀␀␀␀␀␀␀��␀␀␀␀␀␀␀␀␀␀␀␀␀␀��␀␀␀␀���␀␀␀␀␀␀��␀␀␀␀␇␀�␀␀␀␀␀␀␀�␀␀␀␀␀␀␀x�␀␀␀␀␀����␀␀␀�q�␀␀␀␀␀␐�␀␀␀␀���␀␀␀␀��␀␀␀␀␃␀���␀␀␀␀␀␀␀␀␀␀�␀␀␀␀␀␀��␀␀␀␀␀␀␀␀�␀␀␀␀␀p␟␀�␀␀␀␀␀␀␀␀␀␀␀␀��␀␀␀␀␀␀␔��␀␀␀␀␀␀␀␀␀␀���␞␀␀␀␀�␀␀␀␀␀��␄␀␀␀␀��␀␀␀␀␀␁�␀␀␀␀␀␀��␀␀␀␀␀␀␀␀␀␀�␀␀␀␀␀␀��␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀�␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀�␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␁�␀␀␀␀␀␀�␀␀��␀␀␀␀��␀␀␀␀��␀␀␀␀��␀␀␀␀␀␀���␜␀␀␀␀␀␀��␀␀␀␀��␀␀␀␀␀�␀␀␀␀ �␀␀␀␀␀␀�␀␀␀␀␀�␀␀␀␀@␁�␀␀␀␀␀␀␂␀␀␀␀␀�␀␀␀␀z�␀␀␀␀␀␃�␀␀␀␀␀�␀␀␀��␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␁��␀␀ ␀��␀␀␀␀␀␀��␀␀␀␀␀␃␀␀␀��␀␀␀}�␀␀␀��␀␀␀␀␁␀␀␀␀�␀␀␀␀␀␀␀��␁␀␀␀␀␀␀␀␀␀�␃␀␀��~␀␀␀��␀␀␀␀␀␀␄B�␀␀␀␀␀␀␀␀␀␀␀␀␀␀�␀␀␀���␡␀␀␀�␀␀␀�␀␀@�␀␀␀␀␀␐��␀␀␀␀�␀␀␀␀␀␀␀␀␀␀␀�␀␀␀␀␀␀␀␏�␀␀␀␀␀␀␀␀␀~��␀␀␀␀␀␀␀␀␀��␀␀␀␀��␀␀␀␀␀␀␀�␀␀␀␀␀␀␀���␀␀␀␀v␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␐␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀�␀␀␀␀␀␀␀␀␀␀␀␀␀␀␐␀␀␀␀␀␀␀␀␀␀��␀␀0�`␀␀␀␀␀␀�␀␀␀␀␄␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀�␇␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀|␀␀␀␀␀␀␀␀�␃␀␀␀␀␀␀␟␀␀␀␀␀␀␀␀␀␀␀␀␀ �␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␘␀␀␀␀���� ␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀ ␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀o�␀␀␀␀␀␀��␃␂␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀@��␀␀␀␀␀␀␀␀␀␀��␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀��␀�␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␁␀␀␀␀�␀␀␀␀␀␂␀�␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀�␗␀␀␀␀␀␀␀␀␀␀␀␀␀�~␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀ ␀␀␀␀␀␀␀␀␀␀␀␀{␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀�?�␀␀␀␀␀��␀␀␀␀␀��␀␀␀␀␀␀␀�␀␀␀␀␀␀␀␀␀␀�␀␀␀␀␀␀␀␀␀���␀␀␀␀␘��␀␀␀��␀␀␀`�␂␀␀␀��␀␀␀��␁␀␀␀␀␀␀�␀␀␀␀␀@��␀␀␀␀�␀␀␀␀␂␀␀␀␆�␀␀␀��␁␀␀���␀␀␀␀␀�␀␀␀␀�␀␀␀␀p�␀␀␀␀`��␀␀␀␀ ��␀␀␀��␀␀␀␀���␀�␀␀␀␀␀��␀␀␀���␀␀␀␀��␀␀␀␀␀␀��␀␀␀�␡␀␀␀␀��␀␀␀␀␀␀␀␀�␀␀␀���␃␀␀�␁␀␀␐x␏␀␀␀0�␀␀ ␀␀␀␀␀␀␀␀␀␀␀␀x�␀␀␀␀␀␀␀��␀␀␀␀␀␀␀�␀␀␀␀��␀␀␀�␀␀␀␀�␀␀␀␀p�␀␀␀␀��␀␀��␀␀␀␀��␀␀␀���␀␀␀��␀␀␀␀�␀␀���␀␀␀␀�␀␀␀␀��␀␀␀��␀␀␀�␀␀␀␀␀␀␀␀␀␀��␀␀␀␀␘␀␀`�␀␀␀␀␀␀␀␀␀␀␀␀�␀␀���␀␀␀�␀␀␀␀�␁␀�␇␀␀␀��␀␀␀␀␀`���␀␀␀␀␀␀�␀␀␀␀���␀␀␀␀␀␀␀�␀␀␀␀␀␀␀��␀␀␀␀␀␀@p␞␀␀␀�␀␀␀@��␀␀␀�␀␀␀�␀␀␀�␁␀␀��␀␀␀␀�␀␀��␀␀␀␀��␀␀␀␀��␄␀@�␀␀@�␀␀��␀␀␀��␀␀␀␀��␀␀␀�␀␀␀␀␀0�␀␀␀␆�␀␀␀|�␀␀␀␀␀␀␀␀␀␀␀`�␀␀␀␀@�␀␀␀���␏␀␀�p�␀␀␀8�␀␀␀@�␀␀␀�␀␀␀�␀␀␀␀��␃␀␀␀��␀␀␀�␀0��␀␀␀�␇␀␀␀�␀␀␀�␀␀␀␜␀␀�␁␀␀��␀␀␀��␀␀␀␀␀␀␀␀␀␀␀��␀␀␀��␀␀��␀␀␀�␂␀␀�␁␀␀␀�␀␀␀ �␀␀␀␏�␀␀␀␀�␀␀␀�␀␀␀␀␀␀␃�␀␀␀�␃␀␀␀�␀␀␀�␀␀␀�␀␀␀8�␁␀␀�␆␀␀␀��␀␀␀␀␀␀␀��␀␀␀��␁␀␀��␀␀␀0�␄␃␀␀�␀␀��␀␀ x�␀␀␀␀␀␀�␁�␀␀8␀␀␀␀␀�␁␀␀␀␀␀␀�␀␀␀`>␀␀␀␀␀␀�␁␀␀␀␀␀␀␀␀␀␀␀␀8␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀p␀␀␀␀��␀␀␀␀␀␀␀␀␀p��4~␀�␁␀␌␀␀px␀␀␀��␁␀�␀␀␀␀␀␀␀���␇␀␀␀ ␀␀␀␀␀␀��`�␀�?��␀�␀␀␀␀␀␀␀␀␀��␀0�␀`␁␀␀␀␀␀␚�␇�␅␀�␀␀␀��␀␀␀␀␀␀␀␀␀�␃p␡␀0␀␀�␀�␁␀�����␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀��␃␀␀�␀␀@�␃␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀��␀␀␀␀␀␀␀␀␀␀��␁␀␀␀␀␀␀␀␀␀␀����␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀���␀�␟␀�␀␀␀␀␀␀␀���␀�␟␀�␀�␀␀␀␀␀␀␀@���␁�␅␀␀␀�␟␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀��������␀␀␀␀��␀␀␀␀�␆�␁�|����␀␀␀␀␀␀␀␂␀␀␀␀␀␀��␀␀␀␀␀␀␀␀␀�␀␀␀�␀␀␀␀��␀␀␀␀␀��␀␀␀8�␁␀��␀␀`�␀␀␀�␀␀␀␀�␀␀␀␁␀␀␀␂�␀␀␀␀��␀␀␀��␀␀��␀␀␀␀␀@��␀␀␀��␀␀␀␀␀��␀␀␀|␀␀␀�␀␀ �␀␀�?␀␀␀�␂��␀␀␀␀␀␀␀␀␀␀@8␀␀␀�␀␀␀␀␀��␀␀␀␀␀x�␀␀␀␀�␀�␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀��␀␀␀␀␀␀␀␀␀␀␀␀�␁��␀␀␀��␀␀␀␀@z�␀�␀␀␀␟�␀␀␀␀�␃␀␀␀␀␀ ␀@��␀␀␀␀␀␀␀␀␀␀��␀␀␀␀␀␀␟␀␀␀␀␀␀␀␀␀��␀␀␀�␡�␇?�␇��@␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀�␋␀ �␘�␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀�␀␁␀␀␀␀␀␀␁␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀�␀␀␀␀␀␀␐�␀␀␀␀␀␀␀␀�␀␀␀␀␀␀␀␀␀␀␀␀x�␀␀␀␀␀␀␀␀␀ ␜␀ �␀␀␀␀␀␀�␀␀��␀␀␀��␀␀␀␀␀␀␀␀␀␀�␀␀␀��␀␀␀␀␀␀␀␀␇␀��␀␀␀␀␀␀�␀␀␀x��<␀␀␀␀␀␀␀␀␀␀␀␀␀ �� �␀␀␀0|�␀␀␀␀␀␀��␀␀␀␀␀␀␀��␇��␀␂␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀��␀␀␀␀␀␀␀␀␀␀␀�␇��␃␀␀ �␀␀␀��␇␀␀␀p�␀␀␀␀␀␀␎�␀␀␀�␀␀␀␀�␀␀␀␀␀␀␀␀��␀␀␀␀␀��␀␀␀␀␀␀␀␀␀��␀␀␀␀�␀␀␀␀␀␀��␀␀␀␀@��␀␀␀�␀␀␀␀␀␀␀␀��␀␀␀@␀␀␀␀��␀␀␀�␀␀␀��␀␀␀␀␀␀�␀␀␀��␀␀␀␀�␀␀␀�␟␀␀␐�␀␀␀�␀␀␀␀␀␀␀��␀␀␀␀�␀␀␀␀_�␀␀␀␀␀␀�␀␀␀��␃␀␀␀␀␀␀��␀␀␀�␀␀␀␀p�␁␀␀␀␀␀␀��␀␀␀�␀␀␀␀␇�␀␀␀␀␀␀␀␀␀�␀␀␀␀�␀␀␀␀��␀␀␀��␀␀␀�␀␀␀␀␀␀␀`�␀␀␀␀␀␀␀���␀␀␀���␀␀␀@��␀␀␀␀�␀␀␀��␇␀␀␀␀␀��␀␀�␀␀␀␀��␀␀␀␀�␁␀␀␀␀␂␀␄�␀␀␀␀�␂␀␀␀␀␀x␀␀␀␀@��␀␀␀␀␀␀␀␀␀�␀0`␀p␀␀␀�␁␀�␀␀␀␀��␀␀␀�␀␀␀␀␀�␀␀␀��␀␀␀␀␀␀�␀␀␀␀␀␀␀@␀␀�␀␀␀␀␀␀␀␀␀␀␀�␀␀␀␀␀␀P��␀␀␀␀8>␀␂�␁����␂␀␀�␀␀␀��␀␀␀␀�␀␀␀�␀␀␀��␃␀␀␀␂�␀␀␀��␀␀␀0�␀␀␀��␀␀␀␀␀�␀␀␀␀8␀␀␀␀␀␀�␀␀␀␀␟␁␀␀�␀␀0␀␀��␀␀␀␐␀␀␀␀�␀␀␀␀␀␀␀␀␀␀p�␀␀␀��␀␀���␀␀@␀␀��␀␀␀��␀␀␀�␀␀�␀␀␀␀�␀␀␀�␀␀␀␀␀␀␀␀␀`␀␀␀@��␀␀␀␀␀��␀␀␀�␀␀␀�␀␀␀␀␀␀8�␀␀␀␀��␀␀␀�␀␀␀��␀␀��␀␀␀␀␀␀␀␀␁��␀�␀␀␀␀␀�␀␀␀��␀␀␀�␀␀�␀␀␀␀��␀␀␀␁�␀��␀␀␀␀��␀␀�8�␀␀␀␁��␀␀␀␀␀␀␀␀␀��␁�␡␀␀␁␀␁␀`␀@@␀␀␀␀␀␀��␀�␀␀␀��␀␀␀��␀�␀␁␀␀␀␀␀␀�␀␀␀␀␀␀␀␀␀␀␀␀�␀␀␀�␀␀␀␀␄�␀␀␀�␀␀␀V�␀␀␀␀�␀␀␀8␀␀␀��␀␀␀�␀␀␀␀␀␀␀␀␀␐�␀␀␀␀�␀␀␀�␀␀␀␀␃␀␀␀␀␀␀�␀␀␀��␀␀␀␀␀␀␀␀␀␀␀␀��␀␀␀␀�␀␀␀␀p��␓␀␀␀␀␀��␀␀��␀␀␀␆�␀␀��␀␀␀␀␀�␀␀␀␀␀��␀␀␀␟␀␀␀␀�␀␀␀��␀␀␀␀�␀␀␀␀@␁␀␀�k�␀␀␀␀␀␀␀␀␀␂␂H�␀␀␀␀�␀␀␀␀␀␀␀␀␀␀�␀␀␀␀␀�␀␀␀␀��␀␀␀�␀␀␀␀�␟␀␀0␀␀␀␀␀␀␀␀␀␀␀���␀␀␀␀�␄␀␀�␀␀��␀␀␀␀␄�␀␀␀��␀␀␀␀�␀␀␀␀␀␀␀␀��␀␀␀��␀␀␀�␀␀␀␀�␀␀␀��␀␀␀␀␀�␀␀␀␀�␁␀␀␀��␀␀␀␀�␀␀@�␀␀␀␀␀�␀␀␀�␀␀␀␀␐␀␀��␀␀␀��␀␀␀␀�␀␀␀�␀␀␀��␀␀␀�␀␀␀��␀�␀I�␀�␃ �␀␀␀␀␀␀␀␀␀�␀␀␀��␀␀␀␀␀�␀␀␀␐��␀␀␀␀��␀␀␀␀␀�␀␀␀�␀␀␀@␟␀��␀␀␀␀␀␀␀␀␀␀��␀␀␀␀�␀␀␀�␃␀␀␀�␀␀␀�␀H�␀␀␀␓�␀␀␀��␀␀␀��␀␀␀␀��␀␀␀␀␀�␀␀␀␀���␀␀␀␀␀��␁␀␀␀␀␀␀��␀␀␀�␀␀␀␀;␀␀␀␀�␀␀␀␀�␀␀␀␀���␀␀␀��␀␀␀��␀␀␀�␀␀��␀␀␀␀�␀␀␀�␀␀␀␀␀�␀␀␀��␀␀␀�␀␀␀␀␀␀␀�␀␀␀ �␀␀@␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀��␀␀␀h␀␀��␀␀␀␀��␀␀␀␀␁��␀␀␀␀␀␐�␀␀␀��␀␀␀␀��␀␀␀␀7␀␀���␕␀␀␀��␀␀␀␀�␀␀␀␀�␀␀␀␀␂�␀␀␀␀␂�␀␀␀��␀␀␀��␀␀␀��␀␀␀@␀␀␀␀␀␀␀␀��␀␀␀␀�␀␀␀�␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀�␀␀␀␀�␀␀␀␀␀␀␀␀␀␀␀␀␀�␀␀␀␀␁�␀␀␀␀␀␀␀␟␀␀␘�␀␀␀�␗␀␀␀␀�␀␀␀��␁��␁␀␀␀␀␀␀␀␀␀␀�␀␀␀�␀␐␀␀␀␀␀␀�␀␀␀␀␀␀�␀␀␀␀�␀␀␀␀␀␀␀␀�␀␀␀␀␀␐␀␀␀␀␀␀␀␀␀␀�␀␀␀␐␀␀␀��␀␀␀␀��␀␀␀␀�␀␀␀��␀���␀�␁␁␀␀␀␀␀␀␀␀��␀␀␀␀�␀␀␀�␀␀␀�␀␀␀␀�␀␀␀␀␀␀␀␀␀␀␀�␀␀␀␀���␀␀␀␀␀␀␀␀␀␀␀␀␀␀z��␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀��␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀`␀␀␀␀␀␀␀␀␀␀␄␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀��␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀�␀␀␀␀�␀␀␀␀␀␀␀␀␀␀␀␀␀�?␀␀␀␀␀␀␘�␀␀␀␀�␀␀␀␀��␀␀␀␀��␀␀␀␀␀�␀␀␀␀�␀␀␀␀␀␀␀�␀␀��␀␀␀�␀␀␀␀␀␀␀z␀␀␀�␀␀␀��␀��␀␀p�␀␀␀p�␀␀␀��␀␀␀␀�␀␀␀��␀␀␀␀��␀␀␀�␀␀␀�␀␀␀�␀␀ ��␀␀␀�8�␀␀p�␀␀␀�␀␀␀��␀␀␀␀�␀␀���␅␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␁␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀�␃␁␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀��?␟��␟x88␐␀␀�␟␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀���␀␀␀␀␀␀␀␀␀␀␀�` ␐␀␀␀␀␀␀␀␀␀␀␀␀␀␀�␏␀␀␀␀␀␀␀␀␀␀������␏␀␀␀␀␀␀�����␡␀␀␀␀␀␀(�������␡�␀␀␀␀␀␀␀␀��␀␀␀@���␃␀��␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀ ��␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀�␀␀␀␀␀␀␀␀␀␀�␁␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀@␀␀␀␀␃�␁␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀�␁␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀��␇␀␀␀␀␀␀␀␀␀␀␀␟0␀␀␀��P`␀␐�␀␀␀�?�␟`␀��␀␀␀␀␀␀�␀␀␀␀␀␀␀␀␀␀p␀␀␀␀␀␀␀␀␀␀p��?p����␀␀␀␀␀␀␀␀␀␀␀␀�␡�?␔`�␇␀␀␀␀␀␀␀␀␀␀��␏0␀␀␀␀␀␀␀␀␀␀�p�␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀���␡␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀�p�␇`␑␀␀␀␀␀␀␀@␀␀␀␀␀␀��?␟␏␌�␀␀␀␀�����␏�␁␀␄␀␀␀␁␀␀␀x␀�␟␀␀␀␀␀␀␀␀␀���␡�␡�����␡␟�␆␇�~␞␀␀␀␀␀␀␀␀␀��␘␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀�␏0␀␀␀␀␀␀�␀A�␀�p8␘␀␀␀␀␀␀␀�␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀�␀␀␀p��␀␀�␀␀␀��␀␀��␀␀␀␀�␀␀␀␀�␀␀␀␀␀␀�␀␀␀���␀␀␀�␀␀␀␀�␀␀␀␀��␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀p�␀␀␀��␀␀␀�␀␀␀␀␀␀��␀␀␀␀␀␀␀␀␁␀␀��␀␀␀��␀␀␀�␀␀␀␀␀␀��␀␀␀��␀␀␀8�␀␀␀␀�␀␀␀␀p�␀␀␀p�␀␀␀��␀␀�␁␀␀␀x��␀␀␀␀␀␀␀␀␐��␁␀�␟␀␀␀��␀␀␀@�␀␀␀␀���␀␀␀�␀␀␀�␀␀␀␀␀��␀␀␀␀�␀␀␀␀<�␀␀␀�␀␀␀␀␀␀␐��␀␀␀␀�␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␄␀␀␀␀␀␀@�␂␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␄␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀@␀␀␀␀␀␀␀␀␀␀␀␀�␁␀␀␀�␀␀␀␀␀␀␀␀��␀␀␐�␀␀␀␀�␀␀���␀␀␀␀��␁␀␀␀␀���␀␀␀␀␀␀��␀␀␀␀␀␀␀␄�␀␀␀␀␔�␁␀␀␀␀␀␀␀␀��␀␀␀␀��␀␀␀␐�␀␀␀␀��␀␀␀␀␀␀␀�␀␀␀␀�␀␀␀��␀␀␀�␀␀␀���␀␀␄␀␀␀␀␀␀␀␀��␀␀␀␀␏␀␀␀�␀␀␀␀␀�␀␀��␔␀␀␀�␀␀␀␀␀␀␀�␀␀␀␃�␀␀␀@�␀␀␀␀␀␀␋�␀␀␀�␀␀␀��␀␀␀␀��␀␀␀␀␇␀␀␀␐�␀␀␀␀�␀␀x�␀␀␀␀�␀␀␀�␀␀␀␀␀␀␀␀�␀␀␀␀��␂␀␀␀␀�␀␀␀␀��␀␀␀␀␀␀�␀␀␀��␀␀␀␐␀␀␀@�␀␀␀␀␀␀␀␀␀�␀␀␀␀␀␀␀�␀␀␀␀␀␀␀␀��␀␀␀�␀␀␀␀␀␀�␀␀␀␀�␀␀␀␀␀␀ ␀�␀␀␀␀␀�␀␀␀␀�␀␀␀␀␀␀��␐␀␀␀␃�␀␀␀��␀␀␀␀␄�␀␀␀␀��␀␀␀`␀␀␀��␀␀␀␀␀␀␀�␀␀␀␀␀��␀␀␀�␀␀␀␀��␀␀␀␀�␀␀␀␐␀␀␀␀␀␀␀␀␀␀␀␇␀␄␀␃␀␀␀�␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␁␀␀␀␀␀␀�␀␀␀␀␀␀�␀␀␀�␀␀␀␀�␀␀�␀␀␀␀␀�␀␀␀��␀␀␀␀␀␀��␀␀␀␀�␀␀␀␀␀␀␀␀�␀␃␀␀␀␀␀␀␀␀␀�k␀␀␀␀��␀␀␀␀��␀␀␀�␀␀␀␀␀␀␀␀��␁␀␀␀␀@��␀␀␀␀�␀y␁␀␀␀␀␀␀�␀␀␀␀�␀␀␀␀␀␀␀␀␀␀�␀␀␀␀␐�␀␀␀��␀␀␀␀␀␀Ѐ�␀␀␀�␀␀␀␀�␀␀␀␀␀�␀␀␀��␀␀␀␀��␀␀␀␀x␀␀␀��␀␀␀␀�␀␀␀␀�␀␀␀␀␀␀␀=�␀␀��␀␀␀��␀␀␀��␀␀␀␀��␀␀␀␀��␀␀␀��␀␀␀␀␀␀␀�␀␀␀␀��␀␀␀��␀␀␀␀␀�␄␀␀␀␁�␀␀␀␀�␀␀␀��␀␀␀␀␀�␀␀␀␀␀␀␀␀��␁␀␀␀ ␀␀␀␀␀␀d␀␀␀␀␀�␀␀␀␀␀␀␀x�␀␀␀␀�␀␀␀��␀␀␀��␀␀␀��␀␀@��␀␀␀␀�␇␀␀��␀␀␀␀�␀�␀␀␀␀␀␀␀�␀␀␀␀␀␀␀␀␀�␀␀␀␀␀␀␀␀␀␀��␀␀␀␀N�␀␀␀␀��␀␀␀␀�␇␀�␀␀␀␀�␀␀␀�␁␀␀�␀␀␀x�␀␀␀␀�?␀␀␀␀␀��␀␀␀␀��␀␀␀␀�␅␀��␀�␀␀␀@�␀␀␀�␁␀␀��␀␀␀␀␀␀p�␀␀␀␀␀␀␀␀␀␀�␀␀␀␀␀␀␀`<␀␀␀�␏␀␀p�␀␀��␀␀���␀␀␀��␀␀␀␀�␀␀@��␀␀␀␀��␀␀�␀␀␀��␀␀␀�␀␀␀␀␀␀␀␀␀�␀␀␀␀␀␀␀␀␀␀�?␀␀␀��␀␀␀��␁␀␀␀�␀␀@␜␀��␁␀␀␂�␀␀␀��␀␀␀�␀␀␀��␌␀␀␀x�␀␀␀␂␀␀�␁␀@�␁␀␀��␀␀␀␀�␇␀␀␀�␀␀␀�␀␀␀�␂␀�␀␀␀␀␀␀␀���␀␀␀␀␀␀␀␀�␀␀␀␀␀␀␀␀␀␀��␀␀␀␀�␀␀␀␀␁�␀␀␀؀␀␀␀␀�␀␀␀�␀␀␀␀�␀␀␀�␀␀␀␀␀␀�␀␀␀␀�␀␀␀␀�␟␀␀��␀␀␀ ��␀␀␀␀␀␀␀��␀␀␀␀␀␀p�␀␀␀�␟␀␀␀��␀␀␀␀��␀␀␀
␀␀␀␀�␀␀␀�@␀␀␀␀␀␀␀␀␀␀�␀␀8␀␀��␀␀␀␀␀�␀␀��␀␀���␀␀␀���␀␀␀ ␀␀␀��␀␀�␀␀␀2�␀␀␐�␀␀␀␀�␄␀␀␀�␀␀␀␀�␀␀␀␀��␀␀␀�␁␀␀␀␀�␀␀␀␀��␀␀␀␀��␀␀␀0�␀␀␀␀�␀␀␀�␀␀␀␀␀��␀␀␀␀␀␀�␀␀ ␀␀␀␀�␀␀␀��␀␀␀␀�␀␀␀��␀␀␀␀␗␀␀␀�␀␀␀␀␀␀␀��␀␀␀␀�␀␀␀␀␀␀�␀␀␀��␀␀␀�␀␀␀@␆�␀␀␀��␀␀␀␀o��␀␀␀␀�␀␀␀��␀␀␀␁�␀␀␀(�␀␀␀���␀␀␀␀␀␀␀␀␀�␀␀��␀␀�␀␀␀!��␁␀␀␀␀␀␀␐�␀␀␀␇�␀␀␀␀�␀␀␀␀v�␀␀␀␀␀ �␀␀␀�␀␀␀␀�␀␀␀␀␀�␀␀␀␀�␀␀␀␀��␀␀␀␀��␀␀␀␀␀␀��␀␀␀␀␀␀�␀␀␀␀␀␀␀��␀␀␀␀␀␀␀␀␀␀␀␀�� ␁␀␀␀␂␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀�����␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␁␁␀␀���␎␀␄␀␀␀␀␀␀␀␀␀␀␀␀␀��␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␂␀␀�␀␀␀␀␀␀␀␀␀�␀␀␀��␀␀␀␀4␀␀␀␀�␀␀␀��␀␀␀␀�␀␀␀␀␀�␀␀␀␀�␀␀␀␁��␀␀␀␀0␁␀␀␀␀␀␑␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀����␁␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␁␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␂␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀ ��␀␀␀␀@��␀␀␀␀␀␀␀���␀␀␀␀␀␀␀␀␀␀���␀␀␀␀␀␀␀␀␆␀␀␀␀␀���␀␀␀␀␀␀␀��␁␀␀␀␀␀␀␀␀␀�O␀␀␀��␀␀␀␀␀␀��␀␀␀␀␀�␀�␁␀␀␀��␀␀␀␀␀␀␀␀␀␀␀␀␀␀ ��␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀`��␃␀␀␀␀␂�?�␀␀␀␀␀␀␀␂␁␀␀␀␀␀��␁␀��␀␀␀␀␀␀␀@␀␀␀␀␑���␀�␀␀␀␀␀␀␀␀␀0��␆␀␀␀␀␀␀␀␀␀��␁␀␀␀␀␀px�␅␀␀␀␀�␁␀␀␀␀␀␀␀␀␀��␀␀␀␀␀�␀␀␀␀␀`��␀␀␀␀␀␀␀@�X␜␀␀␀␀␀␃�␀␀␀␀␀`|�␀␀␀␀␀␐�␀␀␀␀␀␀␀␀���␀�␀␀␀␀␀␀ ��␀␀␀␀␀���␀␀␀␀␀␀␀@␀␀␀␀␀␀␀␀␀p␘␀␀␀␀���␀␀␀␀␀␀�0��␀␀␀␀␀␀���␅␀␀␀␀��␟�␀␀␀␀␀␀␀␀␀␀␁�␀␀␀␀␀␀␀���␀␀␀␀␀8��␀␀␀␀␀�␀␀␀␀␀␀␀0�8��␀␀␀␀␀␀␀␀␀␀␀␀␀␀��␀␀␀␀␀␀␀␀␀␀␀␁␀␀␀�␇␀␀␀␀␀␀␀␀␀␀␀␀␀␀`x�␀␀␀␀␀␀␀␀␀␀ �␀␀␀␀␀␀␀␀��␀␀␀␀␀0�␀␀␀␀␀␀␀���␀␀␀␀␀␀␀␀␀�?␀␀␀␀␀��␁␀␀␀␀␀␀␀␀␀␀␀`��␀␀␀␀␀␀␀␀␀␀␀␀␡��␀␀␀␀␀␀␀`�␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␃␀␀␀␀␀␀␀x��␀␀␀␀␀␀␀␀␀␀␁␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␄␀␀␀␀␀@�␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀��␀␀␀␀␀␀␀␀␀␀␀␀�␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀p␏␀␀`�␀␀␀�␀␀␀␀�␀␀␀�x␀␀␀␀␀␀␀␀␀␀␀␀␀�␇␀␀␀␀␀�␀␀␀␀␀␀�␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀��␀␀␀␀�␀␀␀␀␃�␀␀␀p�␀␀␀␀��␀␀␀`�␀␀␀��␀␀��␀␀␀��␀␀␀␀��␀␀␀��␀␀␀␀␀␀␀�␀␀�␡␀␀␀␀␀�␀␀␀�␀␀␀��␀␀␀␀��␀␀␀��␀␀��␀␀␀���␀␀␀��␀␀␀`|␀␀␀␀��␀␀␀␀␀␀␀��␁␀␀␀��␀␀␀␀␀␀␀�␀␀␀@t�␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀�␀␀␀␀��␀␀␀���␀␀␀␀␀␀␀␀␀�␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀�␀␀␀␀��␀␀␀␀␀�␀␀␀␜␀␀␀␀␀␀␀�␀␀␀�␀␀␀��␀␀␀p|�␀␀��␀␀␀�␀␀␀␐��␀␀��␀␀␀�␀␀��␀␀␀␀␀��␀␀␀0�␀␀�␀␀␀␀␀␀␀␀␀�␀�␁␀␀@��␀␀␀��␆␀␀␘�␀␀␀␀␀␀␀␀�?␀␀�␀␀␀����$␀␀␀␀␀␀␀␀␀␀␀␀␀␀��␀␀␀␀��␀␀␀␀�␋␀␀␀��␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀��␀␀␀␀�␁␀␀␀␀␀␀␀␀␀␘␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␃␀␀␀␡�␀␀␀�␡␀␀␀��␀␀␀�␀␀␀␀��␀␀�␀␀��
␀␀␀�␀␀␀��␀␀��␆␀␀�␀␀␀�␀�␀␀␀���␃␀␀��␀␀��␀␀␀��␀␀␀��@␀␀␀␀␀␀8�␀␀␀�␀␀␀��␀␀␀␀��␀␀␀␀␀␀␀␀��␀␀␀��␃␀␀␀␀␀␀��␀␀␀��␇␀␀�␀␀��␀␀␀�␀␀␀␀␀␀␀␀␀��␀␀␀@<�␀␀␀`�␇␇␀␀␀␀␀␀␀␀␀␀|␀␀␀␀␀␀␀␀␀␀�x␀␀␀␀␀␀`␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀�����␏p␀␀␀␀␀␀�~~<0`␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀�␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀��@␀␀␀␀␀␀␀␀␀�p�␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀>�␃␀␀␀␀␀␀�␀␀␀␀␀␀␀␀�?8␀␀␀␀8�␀␀␀␀␀␀�␇␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀��␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀��␇␀␀␀␄␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␂␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀p���>␄␀␀␀␀␀␀␀␀␀␀␀␀␀���␀␀␀��␀␀␀�x�␀␀␀��␀␀␀�␀␀␀␀��␀␀␀�␀␀␀�␀␀␀␀␀␀␀�?␀␀�␀␀␀��␀␀␀␀␀␀␀␂␀�␀␀␀␀�␀␀␀␀�␀␀␀␀␀��␀␀␀�␀␀␀␀�p␀␀␀␀␀␀␀␀��␀␀␀␀��␀␀␀␀␀�␀␀␀`�␀␀␀␀␀�␀␀␀��␀␀�␀␀␀␀␀␀␀␀�␀�␀␀␀�␀␀␀␀�␀␀�␀␀�␀␀␀��␀␀␀␂�␀␀␀␀␀␀␀�␀␀��␀␀␀␀��␀␀␀␀␀�␀␀␀@|␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀�␀␀␀�␀␀@�␀␀␀␀␂␀␀␀␀␀␀␜�␀␀␀␀��␀␀␀␐�␀␀␀␀␀��␀␀p�␀␀␀␀�␀␀␀�␀␀␀␁␀␀␀␀0�␀␀␀��␀␀␀��␀␀0�␀␀��␀␀␀��␀␀␀��␀␀␀␀␀␀␀␀␀�␀␀␀␀␀␀␀␂␀␀��␀␀␀␀␀��␀␀␀␀␀␀␀␀�␀�␀␀␀0�␀␀␀␀␀��␀␀␀␀␀␀␀��␀␀␀p␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀␂␀␀␀␀␀␀␀␀␀␀␀���␄␀␀␀␀␀␀␀␀����␀␀␀␀␀��␀␀␀␀␀␀�␇�␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀��7␀␀␀␀␀␀␀␀␀�␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀��␀␀␀␀␀␀␀␀␀␀␀␀␀␀?␀␀���#␞I
FTD1232 reading
0 NUB_SPMI: s4_h2_b1_f1 @ 0x2e4700000
 1 NUB_SPMI1: s4_h2_b1_f1 @ 0x2e4600000
4fbf8fe65e3b7c6:363
4fbf8fe65e3b7c6:365
4fbf8fe65e3b7c6:365
4fbf8fe65e3b7c6:365
4fbf8fe65e3b7c6:365
4fbf8fe65e3b7c6:365
4fbf8fe65e3b7c6:515
4fbf8fe65e3b7c6:517
4fbf8fe65e3b7c6:517
4fbf8fe65e3b7c6:615
1a618789140ad84:702
af714dbce4d39c3:314
e51893b627f0e6e:541
e51893b627f0e6e:545
b5255f381ca81f9:500
b5255f381ca81f9:516
b5255f381ca81f9:524
b5255f381ca81f9:548
b5255f381ca81f9:556
b5255f381ca81f9:564
b5255f381ca81f9:572
b5255f381ca81f9:580
7ab90c923dae682:193
970995cadb21431:612
970995cadb21431:620
970995cadb21431:627
970995cadb21431:523
970995cadb21431:523
970995cadb21431:493
970995cadb21431:495
970995cadb21431:496
970995cadb21431:493
970995cadb21431:495
970995cadb21431:496
1d04ca4e8e2f572:554
f81b84702e533cb:178
f81b84702e533cb:205
f81b84702e533cb:219
89994699affdef:138
e0427b017f3b029:477
e0427b017f3b029:483
e0427b017f3b029:477
e0427b017f3b029:483
e0427b017f3b029:477
e0427b017f3b029:483
e0427b017f3b029:477
e0427b017f3b029:483
4a4ecc14a95a0fb:192
image <<PTR>>: bdev <<PTR>> type illb offset 0x0 len 0x1704f0
image <<PTR>>: bdev <<PTR>> type ansf offset 0x1704f0 len 0xfc3f1
image <<PTR>>: bdev <<PTR>> type logo offset 0x26c8e1 len 0x785e
image <<PTR>>: bdev <<PTR>> type bat0 offset 0x27413f len 0x1a9ca
image <<PTR>>: bdev <<PTR>> type wchf offset 0x28eb09 len 0x35fbd
image <<PTR>>: bdev <<PTR>> type liqd offset 0x2c4ac6 len 0x100070
image <<PTR>>: bdev <<PTR>> type bat1 offset 0x3c4b36 len 0x3eb7
image <<PTR>>: bdev <<PTR>> type lpw1 offset 0x3c89ed len 0x25455
image <<PTR>>: bdev <<PTR>> type glyP offset 0x3ede42 len 0x25cda
image <<PTR>>: bdev <<PTR>> type batF offset 0x413b1c len 0x2f65d
image <<PTR>>: bdev <<PTR>> type lpw0 offset 0x443179 len 0x2b46a
image <<PTR>>: bdev <<PTR>> type chg0 offset 0x46e5e3 len 0x71ce
image <<PTR>>: bdev <<PTR>> type alpm offset 0x4757b1 len 0x102ddb
image <<PTR>>: bdev <<PTR>> type recm offset 0x57858c len 0xc64bd
image <<PTR>>: bdev <<PTR>> type dtre offset 0x63ea49 len 0x1043f
image <<PTR>>: bdev <<PTR>> type aubt offset 0x64ee88 len 0x94b6b
image <<PTR>>: bdev <<PTR>> type chg1 offset 0x6e39f3 len 0x13e72
1a618789140ad84:702
11a12b6063c71bb:1792
image <<PTR>>: bdev <<PTR>> type dcpf offset 0x0 len 0x57ed56
78faf5021313e82:68
78faf5021313e82:68
78faf5021313e82:68
78faf5021313e82:79
e62f453327738a:264
852d9777685f7a3:89
6e26078e119d4f2:1624
6e26078e119d4f2:387
852d9777685f7a3:89
6e26078e119d4f2:387
852d9777685f7a3:89
6e26078e119d4f2:387
852d9777685f7a3:89
6e26078e119d4f2:387
6e26078e119d4f2:387
e3119da927ae88f:92
e51893b627f0e6e:2356
e51893b627f0e6e:2360
b5255f381ca81f9:1287
af714dbce4d39c3:179
af714dbce4d39c3:180
af714dbce4d39c3:183
af714dbce4d39c3:184
af714dbce4d39c3:185
af714dbce4d39c3:189
af714dbce4d39c3:190
af714dbce4d39c3:191
4205a3329fb8d20:372
956d543d057efe0:281
956d543d057efe0:240
1a618789140ad84:702
956d543d057efe0:281
956d543d057efe0:240
956d543d057efe0:281
956d543d057efe0:240
956d543d057efe0:240
89994699affdef:270
1a618789140ad84:702
956d543d057efe0:281
956d543d057efe0:240
956d543d057efe0:281
956d543d057efe0:240
cf04bf97efcfb5e:411
cf04bf97efcfb5e:2259
956d543d057efe0:281
89e98085b55d01e:553
4fbf8fe65e3b7c6:2360
a3ca66f2d546829:622
:: 🔥🌸 Microkernel iBoot for d83, Copyright 2007-2023, Apple Inc.
:: Local boot, Board 0x4 (d83ap)/Rev 0xf
:: BUILD_TAG: iBoot-10151.2.12
:: BUILD_STYLE: RELEASE
:: USB_SERIAL_NUMBER: SDOM:01 CPID:8130 CPRV:11 CPFM:03 SCEP:01 BDID:04 ECID:000C0DC22841401C IBFL:3D SIKA:00 SRNM:[DGXG4LH66V]
9905b4edc794469:704
3974bfd3d441da3:1401
3974bfd3d441da3:1467
9905b4edc794469:704
9905b4edc794469:704
3d8efc6452c6cc3:479
3d8efc6452c6cc3:479
3d8efc6452c6cc3:479
3d8efc6452c6cc3:479
3d8efc6452c6cc3:479
3d8efc6452c6cc3:479
3d8efc6452c6cc3:479
3d8efc6452c6cc3:479
f6ce2cad806de9b:97
f6ce2cad806de9b:156
3d8efc6452c6cc3:851
1a618789140ad84:702
3d8efc6452c6cc3:856
3d8efc6452c6cc3:631
3d8efc6452c6cc3:851
1a618789140ad84:702
3d8efc6452c6cc3:856
3d8efc6452c6cc3:631
3d8efc6452c6cc3:851
1a618789140ad84:702
3d8efc6452c6cc3:856
3d8efc6452c6cc3:631
3d8efc6452c6cc3:851
1a618789140ad84:702
3d8efc6452c6cc3:856
3d8efc6452c6cc3:631
3d8efc6452c6cc3:851
1a618789140ad84:702
3d8efc6452c6cc3:856
3d8efc6452c6cc3:631
3d8efc6452c6cc3:851
1a618789140ad84:702
3d8efc6452c6cc3:856
3d8efc6452c6cc3:631
3d8efc6452c6cc3:851
1a618789140ad84:702
3d8efc6452c6cc3:856
3d8efc6452c6cc3:851
1a618789140ad84:702
3d8efc6452c6cc3:856
a60aa294185a059:707
e51893b627f0e6e:1462
eb354a5d02629f4:4621
eb354a5d02629f4:4626
cf04bf97efcfb5e:411
cf04bf97efcfb5e:411
cf04bf97efcfb5e:411
cf04bf97efcfb5e:411
cf04bf97efcfb5e:411
cf04bf97efcfb5e:411
cf04bf97efcfb5e:411
cf04bf97efcfb5e:411
89e98085b55d01e:1391
3a2af965d49e02c:136
3bdace14b1a9a68:3472
3bdace14b1a9a68:3771
7ab90c923dae682:1205
7ab90c923dae682:146
4fbf8fe65e3b7c6:2314
c8fcb951d0b2a99:40
c8fcb951d0b2a99:46
c8fcb951d0b2a99:46
c8fcb951d0b2a99:46
c8fcb951d0b2a99:46
c8fcb951d0b2a99:46
c8fcb951d0b2a99:46
9d3861cf3bd3cd0:459
9d3861cf3bd3cd0:459
9d3861cf3bd3cd0:459
9d3861cf3bd3cd0:459
9d3861cf3bd3cd0:459
9d3861cf3bd3cd0:459
9d3861cf3bd3cd0:459
9d3861cf3bd3cd0:459
9d3861cf3bd3cd0:459
9d3861cf3bd3cd0:459
9d3861cf3bd3cd0:459
9d3861cf3bd3cd0:459
8d3ff3cd3759614:594
8d3ff3cd3759614:606
8d3ff3cd3759614:594
8d3ff3cd3759614:606
8d3ff3cd3759614:594
8d3ff3cd3759614:606
8d3ff3cd3759614:594
8d3ff3cd3759614:606
6b5f3c9b59dd40:1447
6b5f3c9b59dd40:1447
6b5f3c9b59dd40:1447
6b5f3c9b59dd40:1447
6b5f3c9b59dd40:1447
6b5f3c9b59dd40:1447
6b5f3c9b59dd40:1447
======== End of iBoot serial output. ========
lbernstone
Re: Uart2 Lost Connection or Reading Wrong
Postby lbernstone » Wed Aug 13, 2025 5:57 am
What type of board? There are some known issues with UART right now.
https://github.com/espressif/arduino-esp32/issues/11721
