Hi everyone,
I’m a complete beginner in electronics and robotics, and I’m trying to build my very first project using an ESP32. I have some ideas about what I want to do, but I’m not sure if the components I’m choosing are suitable.
Here’s what I’m planning:
Motors & Wheels: To move a small robot around.
Motor Driver: L298N for controlling the motors.
Sensors:
Ultrasonic sensor HC-SR04 for obstacle detection.
IR sensors / bump sensors for detecting edges or collisions.
PIR sensor for detecting humans in the room.
Power: LiPo battery 7.4V with a step-down module to feed the ESP32.
Other: Breadboard and jumper wires.
I would really appreciate any advice on:
Whether these components are compatible with ESP32 and each other.
If the battery and step-down setup is safe and sufficient.
Any suggestions for improvements, or if I’m missing something important.
I also need help to find:
bump sensors
I’m completely new, so any guidance or tips would be amazing. Thank you so much for your help!
First-Time Project with ESP32 – Need Help Choosing Components
- componenti.png (232.15 KiB) Viewed 205 times
JoeSensoric
Re: First-Time Project with ESP32 – Need Help Choosing Components
This depends on the availability of libraries for these components for the development environment you want to use, e.G. ESP-IDF or Arduino.Whether these components are compatible with ESP32 and each other.
I would start with an ESP32 Robot Starter Kit. These are widely available and should contain software examples. And with an ESP32 with enough IO-pins it should be easy to enhance it.
Users browsing this forum: Baidu [Spider], Semrush [Bot] and 1 guest
