Can i point the websocket payload to another memory location ?
noweare
Postby noweare » Tue Aug 19, 2025 11:54 pm
Question about ws_echo_server example in http_server directory
The websocket packet payload is a uint8_t* and memory is allocated to store the request payload.
In the example the response uses in the same address for the payload.
I need to use more memory for the response but if I assign another address which points to the response I want to send
the payload doesn't accept it.
The payload address is the original address assigned to it.
    if ((ws_pkt.type == HTTPD_WS_TYPE_TEXT) && (strstr((char *)ws_pkt.payload, "quick") != 0))
          ws_pkt.payload = (uint8_t *)response;   //DOESN'T CHANGE THE PAYLOAD ADDRESS
          ESP_LOGI(TAG, "payload pointer: %p response pointer: %p", &ws_pkt.payload, response);
          ret = httpd_ws_send_frame(req, &ws_pkt);
MicroController
Re: Can i point the websocket payload to another memory location ?
Postby MicroController » Wed Aug 20, 2025 11:31 am
Because it's an "echo server" which just sends back the payload it receives.
ws_pkt.payload is a pointer. You're taking the address of this pointer (= a pointer to a pointer) instead of its value (= a pointer) here.
Use
ESP_LOGI(TAG, "payload pointer: %p response pointer: %p", ws_pkt.payload, response);
And don't forget to also set the payload length.
noweare
Postby noweare » Wed Aug 20, 2025 12:56 pm
Thanks, I was forgetting to set the length.
Have a good day, Microcontroller : )
Users browsing this forum: Baidu [Spider], Bing [Bot], Google [Bot], meta-externalagent and 1 guest
