Hi there,
I started working on a project in which I need to reuse the code from the previous project, which was built on IDF-4.3.x, and the [https://docs.espressif.com/projects/esp ... index.html][IDF programming guide] doesn't have the documentation for it now.
What do I need to do in this case?
Want to work on a project build on ESP-IDF 4.3.x
sonukmrsah
Re: Want to work on a project build on ESP-IDF 4.3.x
Hi sonukmrsah,
To access documentation for older versions, check https://docs.espressif.com/projects/esp ... sions.html
Users browsing this forum: Baidu [Spider], Bing [Bot], Semrush [Bot] and 1 guest
