We use some ESP32 devices with esp-mesh-lite library, the root is connected to a WIFI Access Point.
https://github.com/espressif/esp-mesh-lite
Following the examples (rainmaker, mesh_local_control), the root and the nodes can access to Internet, throught the NAPT of the mesh library.
https://github.com/espressif/esp-mesh-l ... ansmission
Our ESP32 devices have an Ethernet Interface, with a Raspberry PI connected on it.
Our goal is to provide Internet access to the Raspberry PI.
To achieve it, we have to create a bridge (L2 or L3) between the Ethernet interface of the node, and the Mesh-Lite interface.
The ESP-IOT-Bridge have examples of bridging on different interfaces (usb, spi, modem...)
But for the esp-mesh-lite interface, we didn't succeeded to make it work.
What you think about the feasibility of our feature ?
Is there some limitation about the mesh-lite netif ?
Best regards
Stéphane
Bridging Ethernet for Nodes with ESP-MESH-LITE
nopnop2002
- Contact:
Re: Bridging Ethernet for Nodes with ESP-MESH-LITE
A simple esp-iot-bridgr SoftAP Interface can accept HTTP requests from the RPI.
https://github.com/espressif/esp-iot-br ... ifi_router
esp-mesh-lite uses esp-iot-bridge, but the SoftAP interface of esp-mesh-lite only accepts connections from the ESP-IDF station interface.
All nodes in esp-mesh-lite must be built with ESP-IDF.
So even if you connect an RPI to the esp-mesh-lite SoftAP Interface, you will not be able to access the Internet.
The http client on esp-idf works fine.
HTTP packets from leaf nodes are forwarded through the root node.
ESP32
| |<--HTTP packets-->|HTTP client|
| | | root | ESP32
|HTTP server| | | +-----------+
| | | | |HTTP client|
| |<--HTTP packets-->|<=========>|<--HTTP packets-->| leaf |
Thanks for the reply.
The RPI is connected to the leaf node with Ethernet.
As the leaf node can reach Internet, we think it is possible to share the Internet connection to the RPI,
With a bridge L2 or L3.
We want retransmit the packet received by Ethernet to the root node via the mesh netif
But we should have to add some routing L3 / bridging L2 stuff.
If it is L3 routing, we have to check if the leaf node can have an IP address.
If it is L2 routing, we don't know if the RPI talk in IP with root, or with Internet Wifi Hotspot
ESP32
| | | root | ESP32 RPI
|HTTP server| | | +-----------+ +-----------+
| | | | |HTTP client| |HTTP client|
| |<--HTTP packets-->|<=========>|<--HTTP packets-->| leaf |<--Ethernet Bridge L2/L3-->| |
+-----------+ +-----------+ +-----------+ +-----------+But we should have to add some routing L3 / bridging L2 stuff.
Finally it work, with a L3 bridge
All nodes have IP addresses in the mesh network,
We enabled CONFIG_BRIDGE_DATA_FORWARDING_NETIF_ETHERNET,
And called :
or
By calling esp_bridge_create_all_netif, DNS also are initialized.
Best regards
Stéphane
And called :
ip_napt_enable(ip_info.ip.addr, 1);Code: Select all
esp_bridge_create_all_netif();Best regards
Stéphane
nopnop2002
- Contact:
Awesome!!
If possible, could you please share the entire code?
Hi
The code is the mesh-local-control example based on IOT-Bridge project
If my comprehension is correct, this example set-up a DHCP server on all wifi-mesh lite node,
To give IP for the mesh childs.
So all nodes have his own IP with gateway + DNS.
To share the Internet connection of the node to the Ethernet port for RPI,
We just enabled the CONFIG_BRIDGE_DATA_FORWARDING_NETIF_ETHERNET configuration,
And RPI got Ethernet (with DHCP, gateway, DNS OK)
Best regards
Stéphane
Best regards
Stéphane
Users browsing this forum: Baidu [Spider], Google [Bot], meta-externalagent and 1 guest
