Data only USB-cable
Lartzu
Data only USB-cable
Postby Lartzu » Mon Sep 01, 2025 7:49 am
I'm looking solution for data only USB-cable for ESP32 <-> WIN10.
I made cable where only data (white& green) are connected. Unfortunately it seems that Windows is not finding the USB-port with this cable when the board is power from other source.
Is there away to connect to board with data only cable and how the cable should look like?
Re: Data only USB-cable
Postby Sprite » Mon Sep 01, 2025 9:30 am
At the very least, you need ground (the black cable) as well.
Lartzu
Postby Lartzu » Mon Sep 01, 2025 10:30 am
The ground didn't help.
georgewicks
Postby georgewicks » Fri May 15, 2026 5:48 pm
I too am trying to use a Micro-USB data only cable with no success. I am powering the ESP32 DevKit separately - it works just fine, but I do need to a working setup with a data only cable. Espressif has made claims that one can use a data only cable, but so far no luck. Please help!
firdoshdiakus
Postby firdoshdiakus » Tue May 19, 2026 11:39 am
I used the green and white data wire with the black ground and it works, just leave out the red + wire
Users browsing this forum: Bytespider, Google [Bot] and 1 guest
