Using RTC with Backup Battery on ESP32-P4
Posted: Thu Sep 04, 2025 5:17 am
by Sudheesh
Hi everyone,
I’m new to ESP and currently working with the ESP32-P4 on a custom board. I want to use the RTC with a backup battery so that it keeps running when the main power is removed.
I have connected VBAT to a CR1220 backup battery, following the ESP32-P4 datasheet.
I have a few questions:
1.How can I enable and use the RTC with battery backup on the ESP32-P4?
2.Which configurations need to be changed in menuconfig to support this?
3.Are there example codes available for reading/writing the RTC time and verifying that it retains the correct time after a power loss?
4.Do I need to configure any special registers or settings for RTC backup mode?
Any guidance, example code, or reference documentation would be very helpful.
Thank you!
Re: Using RTC with Backup Battery on ESP32-P4
Posted: Thu Sep 04, 2025 5:46 pm
by ahsrabrifat
You’ve correctly wired the VBAT pin to your CR1220 battery—but to make it active, you need to configure ESP-IDF to support VBAT.
Posted: Fri Sep 05, 2025 6:20 pm
by Sudheesh
Thank you,ahsrabrifat.
I am not familiar with the configuration. Could you please share any documentation on that? I am using ESP-IDF v5.5.
Posted: Mon Sep 08, 2025 7:42 pm
by ahsrabrifat
Posted: Sat Nov 15, 2025 2:47 pm
by _Dejan_
@Sudheesh Did you make it work?
First link "ESP32-P4 Battery Backup Solution" is for "ESP-IoT-Solution" and not for "ESP-Idf" ... If I look into file which I need modify there is no "pmu_sleep_start" function...
Any solution for ESP-IDF? I need to keep RTC if power is loss... NTP is not option because there is no internet or loacal connection(No LAN or WiFi)...
Posted: Mon Dec 29, 2025 8:36 pm
by LeverNuts
@Sudheesh and @_Dejan_
Has anyone had luck with this? Using VSCode extension I can find VBAT settings that seem relevant. I am specifically trying to keep the RTC through power loss. Following the above links gave me a variety of results. I was able to get RTC to persist through power loss, but booting became very inconsistent. It would be nice if Espressif could provide an example or improved documentation.
Posted: Tue Dec 30, 2025 1:12 am
by username
You have to go into menuconfig to enable VBAT.
Screenshot 2025-12-29 191118.png (58.19 KiB) Viewed 2800 times
Posted: Fri Apr 03, 2026 5:47 pm
by LLM_coder
Could NOT get this to work. Ultimately, I had to add a DS3231 to the I2C bus. I'm currently progging a Waveshare ESP32-P4 dev board (with a 7" screen). We tried the following things to try and get them to work:
ESP32-P4 RTC Time Persistence Across Power Cycles — Approaches Tried
Hardware
  • Board: Waveshare ESP32-P4-WIFI6-Touch-LCD-7B
  • SoC: ESP32-P4 rev 1.3
  • ESP-IDF: v5.4
  • VBAT: CR1220 coin cell, measured 3.27V, seated in onboard battery holder
  • VBAT circuit: CR1220 connected to ESP_VBAT pin via onboard holder (confirmed in schematic — VBAT feeds the LP domain power input)
  • Peripherals using SDIO: SD card on SDMMC Slot 0 (4-bit, 40MHz), WiFi via ESP32-C6 coprocessor on SDIO Slot 1 (esp_hosted, 4-bit, 40MHz)
Problem Statement
gettimeofday()
returns epoch 0 (1970-01-01) on every boot — including soft reboots from serial DTR/RTS reset — even though the ESP32-P4 datasheet (Section 4.1.4.10) documents a 48-bit RTC Timer that provides "uninterrupted operation during any reset or sleep mode, except for power-on reset of LP system."
The goal was to maintain wall-clock time across power outages using the CR1220 battery, without relying on NTP or deep sleep.
Relevant sdkconfig
CONFIG_RTC_CLK_SRC_INT_RC=y
CONFIG_ESP_TIME_FUNCS_USE_RTC_TIMER=y
CONFIG_ESP_TIME_FUNCS_USE_ESP_TIMER=y
CONFIG_NEWLIB_TIME_SYSCALL_USE_RTC_HRT=y
CONFIG_SOC_RTC_FAST_MEM_SUPPORTED=y
CONFIG_SOC_RTC_MEM_SUPPORTED=y
How ESP-IDF System Time Works (background)
gettimeofday()
computes:
boot_time + time_since_boot
  • Code: Select all
    boot_time
    is stored in LP_STORE2/3 registers (
    LP_SYSTEM_REG_LP_STORE2_REG
    LP_SYSTEM_REG_LP_STORE3_REG
    ) via
    esp_time_impl_set_boot_time()
    in
    components/newlib/port/esp_time_impl.c
  • Code: Select all
    time_since_boot
    uses
    s_microseconds_offset + esp_system_get_time()
    where
    bridges the ESP timer to the RTC counter
  • Code: Select all
    settimeofday()
    writes:
    boot_time = now - time_since_boot
    into LP_STORE2/3
  • The 48-bit RTC counter (
    esp_rtc_get_time_us()
    ) provides the monotonic reference
If LP_STORE2/3 and the RTC counter both survive a reset, time should persist.
[hr]
Approach 1: Baseline — System Calls Only (the P4 "onboard RTC" shim)
Implementation: Replaced the external DS3231 I2C driver with a shim that wraps
gettimeofday()
settimeofday()
, treating the ESP32-P4's internal RTC as the time source.
Result:
gettimeofday()
always returns epoch ~3 seconds (just boot time) after any reset. Diagnostic logging confirmed:
[DIAG] Reset: POWERON, RTC counter: 3298603 us (0.0 hrs), epoch: 3
Even a serial DTR/RTS reset (not actual power loss) reports
ESP_RST_POWERON
and shows the RTC counter at ~3.3 seconds (just the time since boot started). The LP_STORE2/3 registers are zeroed.
Root cause: Every reset — including serial-triggered resets — appears as
RESET_REASON_CHIP_POWER_ON
to the ROM, which zeros LP_STORE registers and resets the 48-bit RTC counter. The VBAT switching that would keep the LP domain alive during main power loss is not enabled by default.
[hr]
Approach 2: NVS Bootstrap
Implementation: On every boot, before the RTC driver reads
gettimeofday()
, check if NVS contains
last_sync_ts
(minutes since epoch, saved on every NTP sync). If
gettimeofday()
shows year < 2025, call
settimeofday()
with the NVS timestamp to prime the clock.
Also saved
rtc_ref_us
(raw
value at last NTP sync) to NVS, so that if the RTC counter survived a power cycle, we could compute:
current_time = nvs_epoch + (rtc_counter_now - rtc_counter_saved) / 1e6
for second-accurate recovery.
Result: Clock was primed to approximately correct time (minute resolution from NVS). Components started immediately without the 27-second NTP wait. However, the RTC counter delta was always zero because the counter resets on every boot — so the "second-accurate VBAT refinement" path never activated. The time was stale by the duration of the power outage.
[hr]
Approach 3: PMU VBAT Auto-Switch via Direct Register Write
Implementation: Based on Espressif's ESP32-P4 VBAT documentation, set the PMU to auto-switch the LP domain to VBAT when main power drops:
// In DS3231::init(), before any SDIO initialization:
REG_SET_FIELD(PMU_HP_SLEEP_LP_DIG_POWER_REG, PMU_HP_SLEEP_VDDBAT_MODE, 2);  // AUTO mode
REG_SET_BIT(PMU_VDDBAT_CFG_REG, PMU_VDDBAT_SW_UPDATE);
// Poll for activation:
while (2 != REG_GET_FIELD(PMU_VDDBAT_CFG_REG, PMU_ANA_VDDBAT_MODE)) { ... }
Result — Partial success then crash:
The VBAT switching did work for time persistence. After power cycling (unplug, wait, replug), the boot log showed:
MAIN: RTC Time: 2026-04-03 12:16:33
This was the correct time, proving LP_STORE2/3 and the RTC counter survived the power cycle via VBAT.
However, both SDIO peripherals crashed on the VBAT-wake boot:
  • SD card (SDMMC Slot 0):
    sdmmc_init_sd_ssr: sdmmc_send_cmd returned 0x107
    ESP_ERR_TIMEOUT
  • WiFi SDIO (Slot 1, esp_hosted):
    assert failed: xQueueSemaphoreTake queue.c:1709 (( pxQueue ))
Root cause: When VBAT keeps the LP domain powered, the reset reason is no longer
. In
components/esp_system/port/soc/esp32p4/clk.c
lines 375-399, LP peripheral cleanup — including SDIO PLL clock gate clearing — only runs on
CHIP_POWER_ON
if (rst_reason == RESET_REASON_CHIP_POWER_ON) {
    // These only run on cold boot:
    REG_CLR_BIT(LP_CLKRST_HP_CLK_CTRL_REG, LP_CLKRST_HP_SDIO_PLL2_CLK_EN);
    REG_CLR_BIT(LP_CLKRST_HP_CLK_CTRL_REG, LP_CLKRST_HP_SDIO_PLL1_CLK_EN);
    REG_CLR_BIT(LP_CLKRST_HP_CLK_CTRL_REG, LP_CLKRST_HP_SDIO_PLL0_CLK_EN);
    // ... more LP clock cleanup ...
When VBAT keeps the LP domain alive, stale SDIO PLL clock states, LP UART clocks, and LP pad configurations survive into the next boot, causing the SDIO host controller to initialize against corrupted state.
Additional finding:
PMU_ANA_VDDBAT_MODE
(bits [1:0] of
PMU_VDDBAT_CFG_REG
) is a read-only status register reflecting the current power mode. It only updates during actual PMU state transitions (sleep entry/exit), not from runtime register writes. The poll loop always timed out with "VBAT auto-switch failed to activate" even though the configuration register was written correctly — the mode only takes effect on the next power transition.
[hr]
Approach 4: LP Peripheral Force-Reset + SDIO Clock Cleanup + VBAT Enable
Implementation: Before enabling VBAT, force-reset LP peripherals and replay the
CHIP_POWER_ON
cleanup:
// Step 1: Force-reset LP peripherals
PMU.power.lp_peri.force_reset = 1;
esp_rom_delay_us(100);
PMU.power.lp_peri.force_reset = 0;
// Step 2: Clear stale SDIO/LP clocks (from clk.c:375-399)
// ... all other LP clock gates from clk.c ...
// Step 3: Enable VBAT
Result — Worse crash:
The
lp_peri
force-reset was too destructive. It wiped LP_STORE registers (including
LP_STORE4
= XTAL frequency calibration) and corrupted LP ROM execution state:
W (4868) rtc_clk: invalid RTC_XTAL_FREQ_REG value, assume 40MHz   (×6 times)
After the first boot completed, subsequent boots crashed immediately in LP ROM code:
rst:0x0 (N/A),boot:0xf (SPI_FAST_FLASH_BOOT)
invalid reset
Guru Meditation Error: Core 0 panic'ed (Illegal instruction)
PC: 0x4fc02ba6   ← LP ROM address space (0x4fc0xxxx)
Root cause: The
lp_peri
power domain encompasses more than just SDIO-related state. The force-reset pulse zeroed critical LP system registers (XTAL calibration in LP_STORE4, RTC slow clock calibration in LP_STORE1, boot_time in LP_STORE2/3) and corrupted LP ROM state, making the LP core execute garbage instructions on subsequent boots.
[hr]
Approach 5: RTC_NOINIT_ATTR (investigated, not attempted)
Finding: We investigated using
RTC_NOINIT_ATTR
to store a
{magic, epoch, rtc_counter}
struct in LP RAM that survives resets. However:
  • Code: Select all
    RTC_NOINIT_ATTR
    persistence tests are explicitly disabled for ESP32-P4 in ESP-IDF 5.4 due to issue IDF-9564:
    // components/esp_system/test_apps/.../test_reset_reason.c:27-29
    #if (CONFIG_SOC_RTC_FAST_MEM_SUPPORTED || CONFIG_SOC_RTC_SLOW_MEM_SUPPORTED) && !CONFIG_IDF_TARGET_ESP32P4
    #define CHECK_RTC_MEM 1
    #endif
  • The LP RAM linker section exists (
    lp_ram_seg
    at
    0x50108000
    , 8KB) and the macro is defined (not empty), but behavior is unvalidated on P4.
  • Even if it worked, without the RTC counter surviving, we'd only have the epoch snapshot, not elapsed time.
[hr]
Summary of Findings
Approach                  | RTC Counter? | LP_STORE?  | SDIO?      | Usable?
Baseline (no VBAT)        | No (zero)   | No (zero) | Yes       | No time persistence
NVS bootstrap             | N/A (zero)  | N/A       | Yes       | Minute-res only, stale
VBAT auto-switch          | YES         | YES       | NO crash  | Time works, SDIO broken
LP force-reset + VBAT     | Destroyed   | Destroyed | Crashes   | Unusable
RTC_NOINIT_ATTR           | N/A (IDF-9564)                      | Untested/disabled on P4
[hr]
Questions for Espressif
1. Is there a supported way to enable VBAT power switching for the LP domain without going through the deep sleep infrastructure? Our device runs in full-power mode and experiences unexpected power loss. We need the PMU to be pre-configured so that when VDDA drops, it automatically switches to VBAT — without having called
esp_deep_sleep_start()
first.
2. Can the SDIO PLL clock cleanup in
clk.c:375-399
be extended to also run on VBAT wake resets? The current code only clears stale LP clocks on
. When VBAT keeps the LP domain alive, the reset reason changes and these cleanup steps are skipped, leaving SDIO in a broken state.
3. Is there a way to selectively reset LP peripherals (SDIO clocks, GPIO pads) without resetting the LP_STORE registers and RTC counter?
is too broad — it wipes everything including XTAL calibration and boot_time.
4. What is the status of IDF-9564 (
RTC_NOINIT_ATTR
disabled on ESP32-P4)? If LP RAM persistence across resets were reliable, it could provide an alternative path for time persistence without VBAT.
5. The
esp_vbat
component referenced in the ESP-IoT-Solution VBAT documentation — is there a timeline for it being integrated into ESP-IDF as a standard component? A proper API for VBAT management that handles the LP domain cleanup on wake would solve this cleanly.
[hr]
Resolution
We ultimately attached an external DS3231 I2C RTC module (SDA=GPIO7, SCL=GPIO8) with its own battery backup. This provides sub-second time accuracy across power cycles without any dependency on the ESP32-P4's LP domain persistence.
