trying to install ESP8266_RTOS_SDK (problems with virtualenv)
Sunbelt57
Postby Sunbelt57 » Fri Sep 05, 2025 7:26 pm
while installing the sdk, I ran
python -m pip install --user -r requirements.txt
and got some error (I forget what it is now) so I found this link: viewtopic.php?t=12481 and followed the instructions on the 2nd post by ESP_igrr:
3. Delete C:\\ESP\\.espressif\\python_env\\idf3.3_py3.7_env directory
and the then
4. Run the installer again
which I have no idea what that means. So now when I try to run:
python -m pip install --user -r requirments.txt
I get:
bash: /home/dan/.espressif/python_env/idf5.5_py3.12_env/bin/python: No such file or directory
Sunbelt57
Re: trying to install ESP8266_RTOS_SDK (problems with virtualenv)
Postby Sunbelt57 » Sun Sep 07, 2025 3:55 pm
Here's what I did to get it to work:
python3 -m venv .venv
source .venv/bin/activate
python3 -m pip install -r ./requirements.txt
make sure IDF_PATH points to ESP8266_RTOS_SDK
export IDF_PATH=/home/dan/dev/esp/ESP8266_RTOS_SDK
and run ". ./export.sh" in ESP8266_RTOS_SDK directory
Users browsing this forum: Baidu [Spider], ChatGPT-User, Google [Bot] and 1 guest
