Setting PYTHONNOUSERSITE, was not set
Using Python in D:\esp-idf\Espressif\python_env\idf5.5_py3.11_env\Scripts\
Python 3.11.2
Using Git in D:\esp-idf\Espressif\tools\idf-git\2.44.0\cmd\
git version 2.44.0.windows.1
Activating ESP-IDF 5.5
Setting IDF_PATH to 'D:\esp-idf\Espressif\frameworks\esp-idf-v5.5'.
* Checking python version ... 3.11.2
* Checking python dependencies ... OK
* Deactivating the current ESP-IDF environment (if any) ... OK
* Establishing a new ESP-IDF environment ... FAILED
error: Command "D:\esp-idf\Espressif\python_env\idf5.5_py3.11_env\Scripts\python.exe D:\esp-idf\Espressif\frameworks\esp-idf-v5.5\tools\idf_tools.py export --format key-value --add_paths_extras
D:\esp-idf\Espressif\frameworks\esp-idf-v5.5\components\espcoredump;D:\esp-idf\Espressif\frameworks\esp-idf-v5.5\components\partition_table;D:\esp-idf\Espressif\frameworks\esp-idf-v5.5\components\app_update" failed with error code 1
WARNING: tool xtensa-esp-elf-gdb version 16.2_20250324 is installed, but has reported version unknown
ERROR: tool xtensa-esp-elf-gdb has no installed versions. Please run 'D:\esp-idf\Espressif\python_env\idf5.5_py3.11_env\Scripts\python.exe D:\esp-idf\Espressif\frameworks\esp-idf-v5.5\tools\idf_tools.py install' to install it.
WARNING: tool riscv32-esp-elf-gdb version 16.2_20250324 is installed, but has reported version unknown
ERROR: tool riscv32-esp-elf-gdb has no installed versions. Please run 'D:\esp-idf\Espressif\python_env\idf5.5_py3.11_env\Scripts\python.exe D:\esp-idf\Espressif\frameworks\esp-idf-v5.5\tools\idf_tools.py install' to install it.
WARNING: tool xtensa-esp-elf version esp-14.2.0_20241119 is installed, but has reported version unknown
ERROR: tool xtensa-esp-elf has no installed versions. Please run 'D:\esp-idf\Espressif\python_env\idf5.5_py3.11_env\Scripts\python.exe D:\esp-idf\Espressif\frameworks\esp-idf-v5.5\tools\idf_tools.py install' to install it.
WARNING: tool riscv32-esp-elf version esp-14.2.0_20241119 is installed, but has reported version unknown
ERROR: tool riscv32-esp-elf has no installed versions. Please run 'D:\esp-idf\Espressif\python_env\idf5.5_py3.11_env\Scripts\python.exe D:\esp-idf\Espressif\frameworks\esp-idf-v5.5\tools\idf_tools.py install' to install it.
WARNING: tool esp32ulp-elf version 2.38_20240113 is installed, but has reported version unknown
ERROR: tool esp32ulp-elf has no installed versions. Please run 'D:\esp-idf\Espressif\python_env\idf5.5_py3.11_env\Scripts\python.exe D:\esp-idf\Espressif\frameworks\esp-idf-v5.5\tools\idf_tools.py install' to install it.
ERROR: Activation script failed
Command '['D:\\esp-idf\\Espressif\\python_env\\idf5.5_py3.11_env\\Scripts\\python.exe', 'D:\\esp-idf\\Espressif\\frameworks\\esp-idf-v5.5\\tools\\export_utils\\activate_venv.py', '--export']' returned non-zero exit status 1.
To view detailed debug information, set ESP_IDF_EXPORT_DEBUG=1 and run the export script again.
有知道如何处理的吗?
esp-idf V5.5 在window下使用问题
shadow_pan
Jump to
- English Forum
- Explore
- News
- General Discussion
- FAQ
- Documentation
- Documentation
- Sample Code
- Discussion Forum
- ESP32-S31
- Hardware
- ESP-IDF
- ESP-BOX
- ESP-ADF
- ESP-MDF
- ESP-WHO
- ESP-SkaiNet
- ESP32 Arduino
- IDEs for ESP-IDF
- ESP-AT
- ESP IoT Solution
- ESP RainMaker
- Rust
- ESP8266
- Report Bugs
- Showcase
- Chinese Forum 中文社区
- 活动区
- 乐鑫活动专区
- 讨论区
- ESP32-S31 中文讨论版
- 喵伴 中文讨论版
- ESP-IDF 中文讨论版
- 《ESP32-C3 物联网工程开发实战》书籍讨论版
- 中文文档讨论版
- ESP-AT 中文讨论版
- ESP-BOX 中文讨论版
- ESP IoT Solution 中文讨论版
- ESP-ADF 中文讨论版
- ESP Mesh 中文讨论版
- ESP Cloud 中文讨论版
- ESP-WHO 中文讨论版
- ESP-SkaiNet 中文讨论版
- ESP 生产支持讨论版
- 硬件问题讨论
- 项目展示
Users browsing this forum: Bytespider and 3 guests
- All times are UTC
- Top
- Delete cookies
About Us
Information
