Need help understanding why my ESP32-S3 died
Posted: Wed Sep 10, 2025 1:26 am
Quick info:
So, i want to start this of with the fact that i am not experienced in pcb's and circuit boards, i am mainly a software developer, so i'll understand a small amount of electronics talk, but not a ton.
My issue is that my ESP32-S3 N16R8 seemed to have shorted, but i am uncertain as to why.
The ESP32-S3 was running GrblHAL with a custom configuration for this board when it died.
Setup:
ESP32/CNC Shield/TMC2209
I have a CNC Shield V3 on top of an AliExpress bought ESP32-S3 N16R8 "uno" (https://www.aliexpress.com/item/1005006 ... 18028Q78JE) with 4x TMC2209 stepper drivers (technically 3, driver "A" is not actually plugged in to the uart or a stepper, i just keep it there as a spare). The CNC Shield V3 has a single modification done to it, i've cut the 5V leg and bridged it to 3.3V instead, since i wanted the TMC2209 drivers to use 3.3V as to not damage the ESP32. There's also an old Arduino SD Card reader that i slapped on their cause i wanted to use the ESP32-WebUI once i got everything going.
TMC2209
The 3 stepper drivers are connected via uart (all 3 uart pins on the stepper drivers to 2 pins on the esp32's back with 1k resistor on tx) and their DIAG pins are to their corresponding endstop pins (is what i thought at the time, but it seems i actually connected the INDEX pin if i'm not mistaken, but sensorless homing was working, so i'm hoping this wasn't the issue)
Spindle/BTS7960
The spindle is driven with another AliExpress module, a BTS7960 module (https://www.aliexpress.com/item/1999464 ... 18028Q78JE).
The ESP32/CNC Shield combo and the BTS7960 board were connected together with my own little board that is in the picture, which is an B0505S-1W to isolate the power, and an ISO7742F to isolate the PWM and ENABLE signals for the spindle. (I hope that's what it does anyway, like i said, not really super knowledgeable about electronics, just know some basics)
PSU
The ESP32/CNC Shield and the BTS7960 are powered by the same 24V 10A PSU, just connected to the 2 different terminals that are on my PSU.
What i was doing:
The CNC these were connected to is a CNC 3018 (from what i can tell a non-pro version) and what happened when it died was that i was moving the toolhead around a bit to figure out the steps/mm and max travel of the machine, when all of a sudden Candle stopped reporting anything. Confused i closed Candle and opened Putty to take a look at the serial myself, which was spitting out the following over and over:
I assumed at this point that the flash had somehow gotten corrupted and attempted to reflash GrblHAL, which didn't work until i did it with baud rate 115200, at which point it seemed to flash without a problem, just slow obviously. I once again connected to the serial and at first it seemed fine, it was printing the inital startup info:
At this point GrblHAL is usually done booting and i can start sending commands, but not this time, it was completely unresponsive, so i hit the reset button on the board and at that point it didn't respond to anything anymore, so i took the CNC shield off and noticed the actual ESP32-S3 board was hot to the touch, likely meaning i had somehow shorted it and it's dead.
Actual question:
So now onto my actual reason for writing here, what could have caused this to happen and how can i prevent it in the future?
I assumed the CNC Shield V3 would keep the 24v away from my ESP32-S3 and just in case i made the isolation board for the pwm and enable pins on the bts7960, so afaik it wasn't the 24v hitting the ESP32, but i could be wrong.
Setup:
TMC2209
Spindle/BTS7960
PSU
What i was doing:
Build:Mar 27 2021
rst:0x10 (RTCWDT_RTC_RST),boot:0x8 (SPI_FAST_FLASH_BOOT)
SPIWP:0xee
mode:DIO, clock div:2
load:0x3fce3808,len:0x1338
load:0x403c9700,len:0xb90
load:0x403cc700,len:0x2ed4
Checksum failure. Calculated 0x0a stored 0x91
ets_main.c 329Code: Select all
ROM:esp32s3-20210327
Build:Mar 27 2021
rst:0x1 (POWERON),boot:0x8 (SPI_FAST_FLASH_BOOT)
SPIWP:0xee
entry 0x403c993c
I (29) boot: ESP-IDF v4.4.6-dirty 2nd stage bootloader
I (29) boot: compile time 03:51:15
I (29) boot: Multicore bootloader
I (31) boot: chip revision: v0.2
I (35) boot.esp32s3: Boot SPI Speed : 40MHz
I (40) boot.esp32s3: SPI Mode : DIO
I (45) boot.esp32s3: SPI Flash Size : 4MB
I (49) boot: Enabling RNG early entropy source...
I (55) boot: Partition Table:
I (58) boot: ## Label Usage Type ST Offset Length
I (66) boot: 0 nvs WiFi data 01 02 00009000 00006000
I (73) boot: 1 phy_init RF data 01 01 0000f000 00001000
I (81) boot: 2 factory factory app 00 00 00010000 00200000
I (88) boot: 3 grbl Unknown data 01 99 00210000 00001000
I (96) boot: 4 storage Unknown data 01 82 00211000 000f0000
I (103) boot: End of partition table
I (107) esp_image: segment 0: paddr=00010020 vaddr=3c0c0020 size=1f9d8h (129496) map
I (148) esp_image: segment 1: paddr=0002fa00 vaddr=3fc99da0 size=00618h ( 1560) load
I (149) esp_image: segment 2: paddr=00030020 vaddr=42000020 size=b9910h (760080) map
I (342) esp_image: segment 3: paddr=000e9938 vaddr=3fc9a3b8 size=04074h ( 16500) load
I (347) esp_image: segment 4: paddr=000ed9b4 vaddr=40374000 size=15da0h ( 89504) load
I (383) boot: Loaded app from partition at offset 0x10000
I (383) boot: Disabling RNG early entropy source...Actual question:
