ESP32-H2 SuperMini current consumption
St-Ivoda
Postby St-Ivoda » Thu Sep 18, 2025 7:33 am
Hello everyone! I'm trying to find the most efficient power consumption formula for ESP32 microcontrollers, and after some research, I've chosen the ESP32-H2 SuperMini.
According to the datasheet, this microcontroller consumes no more than 10 µA in deep sleep mode, but after measuring the consumption with PPK2, I got ~880 µA. This board has a charger chip, which I successfully desoldered (as well as the LED), but the consumption changed minimally (~80 µA).
I highly doubt the LDO on the board is the problem. I have no idea why the consumption is so high, so I'm asking for your help.
Example program - Deep Sleep Example, which I used to measure.
ves011
Contact:
Re: ESP32-H2 SuperMini current consumption
Postby ves011 » Fri Sep 19, 2025 9:08 am
If your board has a LDO, most likely this is the cause. With 800 uA quiescent current is a pretty good one.
e.g. AMS1117 has 5 to 10 mA quiescent current. Also you need to consider 0mA baseline of the measurement tool.
I measured deep sleep current for a esp32-S3-WROOM-1 module and found it inline with the datasheet. 18uA (with a 10uA baseline) measured vs 8uA datasheet, so i expect H2 to be in the same range.
Users browsing this forum: PerplexityBot, YisouSpider and 1 guest
