Unexpected offset when using .rodata_custom_desc section
dcpazzini
Postby dcpazzini » Fri Sep 19, 2025 11:41 am
Hi everyone,
I’m planning to use the .rodata_custom_desc dedicated memory section to store basic device information. The goal is to allow a third-party software to read the generated .bin and identify this information.
Following the Espressif official documentation, I implemented the following:
typedef struct custom_app {
const char *my_custom_text;
} esp_custom_app_desc_t;
const __attribute__((section(".rodata_custom_desc"))) esp_custom_app_desc_t custom_app_desc = {
.my_custom_text = "Hello World 123",
The custom_app_desc is placed in main.c just to speed up testing.
I also ensured that the following line is added to the CMakeLists.txt of main.c:
target_link_libraries(${COMPONENT_TARGET} "-u custom_app_desc")
Result:
I can find the "Hello World 123" string in the generated .bin file, but not at the offset expected according to the Espressif documentation.
Question:
Is there something wrong with my setup, or am I misunderstanding how the .rodata_custom_desc section should be used?
Any suggestions would be greatly appreciated.
IDF version: 5.3.1
MicroController
Re: Unexpected offset when using .rodata_custom_desc section
Postby MicroController » Fri Sep 19, 2025 8:35 pm
At what offset did you expect to find the string? According to what documentation?
As you don't specify a section to place the string literal in, it should end up in some .rodata section.
MicroController
Postby MicroController » Fri Sep 19, 2025 8:56 pm
Try something like this:
  const char my_custom_text[32];
dcpazzini
Postby dcpazzini » Mon Sep 22, 2025 4:25 pm
Hello, thanks for reply.
https://docs.espressif.com/projects/esp ... -reference
"Offset for custom structure is sizeof(esp_image_header_t) + sizeof(esp_image_segment_header_t) + sizeof(esp_app_desc_t)."
I was expecting to see something within the first 100 bytes, but it's placed at 0x3000 +
Konstantin
Postby Konstantin » Wed Oct 01, 2025 1:40 pm
The custom structure offset is 0x120 = (sizeof(esp_image_header_t) + sizeof(esp_image_segment_header_t) + sizeof(esp_app_desc_t)).
I double-checked it; it is exactly at 0x120 from the start of the app binary. I do not see an issue with it. If you use `const char *my_custom_text`, then yes, the text itself will be placed at +0x3000 offset. Just make sure that you use the correct type `const char my_custom_text[32]`.
If you are still getting this issue, please provide a simple example that demonstrates it.
dcpazzini
Postby dcpazzini » Thu Oct 02, 2025 1:38 pm
Hello everyone.
const char my_custom_text[32] instead of const char *my_custom_text has moved from the 0x3000+ range to 0x120.
Thank you all for your support.
