Esp32S3 : Is it possible to switch between USB CDC and MSC at runtime ?
ThomasESP32
Postby ThomasESP32 » Mon Sep 22, 2025 1:55 pm
Good afternoon,
I am working with an Esp32S3 and I have found the example CDC MSC composite which works fine.
Now, I would like to know if it is possible to switch between CDC and MSC at runtime ?
If the answer is YES, is there any example ??
Best regards,
Thank you for your help,
Thomas TRUILHE
tore-espressif
Re: Esp32S3 : Is it possible to switch between USB CDC and MSC at runtime ?
Postby tore-espressif » Mon Oct 13, 2025 8:55 am
No, not out-of-the box. We use TinyUSB as our USB device stack, which uses static configuration.
You can implement this feature by defining your own tud_descriptor_configuration_cb() and tud_descriptor_device_cb() TinyUSB callbacks. In the callbacks you can then return whatever configuration you want.
Users browsing this forum: Amazon [Bot], Bing [Bot], ChatGPT-User and 3 guests
