Espressif IDE + linux + openocd + gdb : Cannot access memory at address
esp32.damiano
Postby esp32.damiano » Mon Sep 22, 2025 4:36 pm
After quite some pain I have a 99% reliable developing environment, slow, but almost reliable
The setup
  • Linux, because windows is spyware
  • esp32-c6 custom board with ES8388, actually producing sound
  • openocd started manually and connecting using USB to the above
  • GDB started in aclipse by following
    https://docs.espressif.com/projects/esp ... -app-debug
    there are a few quirks, ask me for details if needed
  • code that starts thread to manage a console + some gpio +wify + a pipeline to play sound
the above works, the issue is while debugging a specific part of sw, namely, if I break at the following function
if I do a "step", the debugger complain that it cannot read the memory
I already have the following in Startup -> Initialization commands
mon reset halt
mon program_esp ${workspace_loc:wiradio/build/wiradio.bin} 0x10000 verify skip_loaded
set mem inaccessible-by-default off
maintenance flush register-cache
any other magic that need to be enabled ?
esp32.damiano
Re: Espressif IDE + linux + openocd + gdb : Cannot access memory at address
Postby esp32.damiano » Tue Sep 23, 2025 5:49 pm
Solved...
actually written in the instructions, that you ned to source or provide the gdbinit, the problem is... how ?
add
-x build/gdbinit/gdbinit
in the COMMAND LINE of the gdb
