Problems with WiFi STA mode
apalazzi
Postby apalazzi » Tue Sep 23, 2025 5:52 pm
I had a code that worked as expected in esp-idf v5.1.6, but after upgrading to v5.5.1 doesn't connect any longer to my wifi network... here is the log:
I (1569) wifi:wifi driver task: 3ffd0b8c, prio:23, stack:6656, core=0
I (1589) wifi:wifi firmware version: 14da9b7
I (1589) wifi:wifi certification version: v7.0
I (1589) wifi:config NVS flash: enabled
I (1589) wifi:config nano formatting: disabled
I (1594) wifi:Init data frame dynamic rx buffer num: 32
I (1599) wifi:Init static rx mgmt buffer num: 5
I (1603) wifi:Init management short buffer num: 32
I (1607) wifi:Init dynamic tx buffer num: 32
I (1611) wifi:Init static rx buffer size: 1600
I (1616) wifi:Init static rx buffer num: 4
I (1619) wifi:Init dynamic rx buffer num: 32
(1625) wifi_init: rx ba win: 6
I (1628) wifi_init: accept mbox: 6
I (1632) wifi_init: tcpip mbox: 32
I (1636) wifi_init: udp mbox: 6
I (1640) wifi_init: tcp mbox: 6
I (1644) wifi_init: tcp tx win: 5760
I (1648) wifi_init: tcp rx win: 5760
I (1652) wifi_init: tcp mss: 1440
I (1656) wifi_init: WiFi IRAM OP enabled
I (1661) wifi_init: WiFi RX IRAM OP enabled
I (1671) phy_init: phy_version 4861,b71b5ad,Aug  5 2025,11:16:06
I (1745) wifi:mode : sta (88:13:bf:36:c2:60)
I (1745) wifi:enable tsf
[  1282][E][STA.cpp:306] begin(): Failed to start STA!
I (1750) wifi:Set ps type: 1, coexist: 0
I disabled the globals on the Arduino library, so i create the WiFi object with WiFi(), that should be just like IDF does this.
I looked at the documentation and googled around but couldn't find any solution... does somebody have any hint?
Bye
Andrea
lbernstone
Re: Problems with WiFi STA mode
Postby lbernstone » Tue Sep 23, 2025 7:59 pm
Try just taking out lines 305-308 in STA.cpp
https://github.com/espressif/arduino-es ... 2e6df63a01
apalazzi
[SOLVED] Re: Problems with WiFi STA mode
Postby apalazzi » Tue Sep 23, 2025 8:20 pm
Solved... the issue was that when you #define NO_GLOBAL_INSTANCES then the global extern WiFiClass WiFi is not declared, but other classes rely on that global to be available.
Declaring a global WiFi solves the issue... not sure why it didn't throw an error during compilation but anyway now it works.
Bye
Andrea
Users browsing this forum: Applebot, ChatGPT-User and 1 guest
