There are MAC and name filters available, but since it’s not always known in advance which devices will appear, these filters are not sufficient. I couldn’t find any other filtering options for this case.
Therefore, I decided to create a custom AT command.
My goal is to filter the incoming advertisement messages and send only the required data to the MCU via UART.
I created a custom AT command for this purpose.
When I run the scan command, the ble_gap_disc function returns success, and the corresponding event is triggered.
However, no actual data is received — the event->type value is always 0.
Does the IDF framework work properly inside a custom AT command, or am I making a mistake somewhere?
Any help would be greatly appreciated.
Thank you in advance!
static int ble_gap_event_cb(struct ble_gap_event *event, void *arg)
char rsp[250];
struct ble_hs_adv_fields fields;
ble_hs_adv_parse_fields(&fields, event->disc.data, event->disc.length_data);
uint16_t len = sprintf(rsp, "--> Request Id: %d - Type: %d - Data Len: %d - Data: \r\n", ridcount++, event->type, event->disc.length_data, fields.svc_data_uuid128);
esp_at_port_write_data((uint8_t *)rsp, len);
switch (event->type)
// NimBLE event discovery
case BLE_GAP_EVENT_DISC:
esp_at_port_write_data((uint8_t *)"\r\n --> BLE_GAP_EVENT_DISC\r\n", 27);
// ESP_LOGI("GAP", "GAP EVENT DISCOVERY");
len = sprintf(rsp, "Name: %d %s\n", fields.name_len, fields.name);
if (fields.name_len > 0)
// printf("Name: %.*s\n", fields.name_len, fields.name);
case BLE_GAP_EVENT_DISC_COMPLETE:
esp_at_port_write_data((uint8_t *)"\r\n --> BLE_GAP_EVENT_DISC_COMPLETE\r\n", 36);
default:
return 0;
void ble_app_scan(void)
esp_at_port_write_data((uint8_t *)"\r\n --> SCANNING...\r\n", 27);
ble_hs_id_infer_auto(0, &ble_addr_type); // Determines the best address type automatically
struct ble_gap_disc_params disc_params;
disc_params.filter_duplicates = 0; // 1;
disc_params.passive = 1;
disc_params.itvl = 0x32;
disc_params.window = 0x32;
disc_params.filter_policy = BLE_HCI_SCAN_FILT_NO_WL;
disc_params.limited = 0;
int rc = ble_gap_disc(ble_addr_type, BLE_HS_FOREVER, &disc_params, ble_gap_event_cb, NULL);
if (rc != 0)
char msg[64];
sprintf(msg, "ble_gap_disc failed rc=%d\n", rc);
esp_at_port_write_data((uint8_t *)msg, strlen(msg));
else
const uint8_t start_msg1[] = "AT+BILLSCAN\r\nSTART\r\n";
esp_at_port_write_data((uint8_t *)start_msg1, strlen((char *)start_msg1));
