ESP32 S2 External Crystal Clock Source waveform
zsolim
Postby zsolim » Mon Sep 29, 2025 11:21 am
I'm designing custom PCB for ESP32 S2 SoC. For some reasons I want to use oscillator (OCXO) instead of crystal.
What are the requirements for External Crystal Clock Source waveform? Can I use OCXO with sine output waveform?
I was looking for the requirements in Hardware Design Guidelines but I found only that:
-the oscillator output is stable and its accuracy is within ±10 ppm,
-It is recommended that the amplitude of the crystal is greater than 500 mV.
Greetings
MicroController
Re: ESP32 S2 External Crystal Clock Source waveform
Postby MicroController » Tue Sep 30, 2025 12:43 pm
Should be fine. After all, a crystal also creates a sinusoidal signal.
Users browsing this forum: Amazon [Bot], Barkrowler and 2 guests
