ESP32-C6-DevKitC-1: 3.3V Pin Power Supply – NeoPixel/RGB LED Not Working
tim_1337
Postby tim_1337 » Sat Oct 04, 2025 7:40 am
Hi everyone :D ,
I’m working with an ESP32-C6-DevKitC-1 and have a question about power supply options. According to the documentation, there are three (or four) ways to power the board:
  • Via the USB-C port (5V)
  • Via the USB-UART port (5V)
  • Via the 5V pin + GND
  • Via the 3.3V pin + GND
Issue:
When I power the board through the 3.3V pin + GND, the power LED lights up, but the built-in RGB LED (NeoPixel, GPIO8) cannot be controlled. However, if I supply 5V (or even 3.3V) to the 5V pin + GND, or use the USB ports, the LED works as expected.
Questions:
  1. Are there known differences between powering via the 3.3V pin vs. 5V pin/USB?
    • Is the 3.3V pin handled differently internally (e.g., missing voltage regulation for certain components)?
    • Could the NeoPixel/GPIO8 be underpowered or not initialized correctly when using the 3.3V pin?
  2. What is recommended for long-term or embedded use?
    • Is powering via the 5V pin (even with 3.3V!) more reliable?
    • Are there risks to supplying 3.3V to the 5V pin (e.g., for the voltage regulator)?
  3. Has anyone else encountered this or have an explanation?
Background:
I plan to embed the board in a small project and am looking for the most reliable alternative to USB power, as USB ports are impractical for my final setup.
Technical Details:
  • Board: ESP32-C6-DevKitC-1
  • NeoPixel/RGB LED: Controlled via GPIO8 (using standard firmware/example code)
  • Power source: Regulated PSU (3.3V/5V), sufficient current (>500mA)
Thanks in advance for your insights and experiences!
Minatel
Re: ESP32-C6-DevKitC-1: 3.3V Pin Power Supply – NeoPixel/RGB LED Not Working
Postby Minatel » Sat Oct 04, 2025 7:43 am
The RGB LED is connected to the 5V rails. Please see the schematic for version 1.4.
If you power on the 3V3, the LED will not work, as expected.
tim_1337
Postby tim_1337 » Sat Oct 04, 2025 7:52 am
Thanks for the hint, the schematic makes that clear. :)
Users browsing this forum: Amazon [Bot], Barkrowler and 2 guests
