ESP32-C3: Executing code from RTC_FAST_MEM causes “Illegal Instruction” (works fine under GDB)
bssmr32
Postby bssmr32 » Tue Oct 14, 2025 11:39 am
Hello everyone,
I'm experimenting with the idea of having self-modifying or dynamically loaded code in my ESP-IDF project and have encountered some behavior I can’t explain.
I have a regular ESP-IDF project compiled and running on an ESP32-C3.
After flashing the normal firmware, I modify the firmware image in flash by adding an additional code segment that should be loaded at 0x50001000.
After a reboot, the bootloader indeed detects and loads my new segment:
I (222) esp_image: segment 6: paddr=002d89a0 vaddr=50001000 size=001e4h (   484) load
When I read memory at address 0x50001000 via the D-Bus, my code appears correctly in RAM as expected.
However, when I try to execute it by jumping to 0x50001000, I get an Illegal Instruction exception:
Guru Meditation Error: Core  0 panic'ed (Illegal instruction). Exception was unhandled.
Core  0 register dump:
MEPC    : 0x50001000  RA      : 0x42088722  SP      : 0x3fca2d40  GP      : 0x3fc8ca00
TP      : 0x3fca3360  T0      : 0x42085e36  T1      : 0x40387f60  T2      : 0xffffffff
S0/FP   : 0x00000004  S1      : 0x50001000  A0      : 0x3fca5274  A1      : 0x3fca52b0
A2      : 0x00000000  A3      : 0x00000000  A4      : 0x00000002  A5      : 0x3fcb6b5c
A6      : 0x3fcc5574  A7      : 0x3fca2c24  S2      : 0x3fcabeec  S3      : 0x00000000
S4      : 0x00000001  S5      : 0x00000016  S6      : 0x00000d79  S7      : 0x00000001
S8      : 0x00000001  S9      : 0x00000d79  S10     : 0x00000d79  S11     : 0x3c1df000
T3      : 0xffffffff  T4      : 0x00000000  T5      : 0x0ccccccc  T6      : 0x00000019
MSTATUS : 0x00001881  MTVEC   : 0x40380001  MCAUSE  : 0x00000002  MTVAL   : 0x00000000
MHARTID : 0x00000000
Here’s the strange part:
If I connect GDB via OpenOCD (USB/JTAG) and then perform the exact same jump to 0x50001000, the code executes perfectly—no exception, no issue. This happens without any breakpoints or stepping; just having GDB attached makes it work.
This behavior is fully reproducible:
Without GDB → Illegal Instruction
With GDB attached → works flawlessly
Does anyone have an idea why executing from 0x50001000 only works when GDB is connected?
Any insights or pointers would be greatly appreciated.
eriksl
Re: ESP32-C3: Executing code from RTC_FAST_MEM causes “Illegal Instruction” (works fine under GDB)
Postby eriksl » Thu Jul 30, 2026 8:33 am
Looks like this part is already in flash cache when you write to it. Also the IDF sets up the MMU for a.o. the areas of flash being used. The area your addressing hasn't been set up. I do think what you want to do is possible but it won't be easy.
