IDF开发环境安装出错
xieliyi
IDF开发环境安装出错
Postby xieliyi » Fri Oct 17, 2025 3:44 am
我之前安装了esp-idf-tools-setup-offline-4.4.4.exe,可以正常使用。
然后安装了esp-idf-tools-setup-offline-5.5.1.exe,也可以正常使用。
然后卸载了esp-idf-tools-setup-offline-5.5.1.exe,再安装esp-idf-tools-setup-offline-4.4.4.exe,或者其它版本,都出错了,现在都是一样的:(其实这些工具是有,但无法正常识别出来)
Setting PYTHONNOUSERSITE, was not set
Using Python in F:\WIFI\ESP-IDF\V444\Espressif\python_env\idf4.4_py3.8_env\Scripts\
Python 3.8.7
Using Git in F:\WIFI\ESP-IDF\V444\Espressif\tools\idf-git\2.34.2\cmd\
git version 2.34.1.windows.1
Setting IDF_PATH: F:\WIFI\ESP-IDF\V444\Espressif\frameworks\esp-idf-v4.4.4
Adding ESP-IDF tools to PATH...
WARNING: tool xtensa-esp-elf-gdb version 11.2_20220823 is installed, but has reported version unknown
ERROR: tool xtensa-esp-elf-gdb has no installed versions. Please run 'F:\WIFI\ESP-IDF\V444\Espressif\frameworks\esp-idf-v4.4.4\install.bat' to install it.
WARNING: tool riscv32-esp-elf-gdb version 11.2_20220823 is installed, but has reported version unknown
ERROR: tool riscv32-esp-elf-gdb has no installed versions. Please run 'F:\WIFI\ESP-IDF\V444\Espressif\frameworks\esp-idf-v4.4.4\install.bat' to install it.
WARNING: tool xtensa-esp32-elf version esp-2021r2-patch5-8.4.0 is installed, but has reported version unknown
ERROR: tool xtensa-esp32-elf has no installed versions. Please run 'F:\WIFI\ESP-IDF\V444\Espressif\frameworks\esp-idf-v4.4.4\install.bat' to install it.
WARNING: tool xtensa-esp32s2-elf version esp-2021r2-patch5-8.4.0 is installed, but has reported version unknown
ERROR: tool xtensa-esp32s2-elf has no installed versions. Please run 'F:\WIFI\ESP-IDF\V444\Espressif\frameworks\esp-idf-v4.4.4\install.bat' to install it.
WARNING: tool xtensa-esp32s3-elf version esp-2021r2-patch5-8.4.0 is installed, but has reported version unknown
ERROR: tool xtensa-esp32s3-elf has no installed versions. Please run 'F:\WIFI\ESP-IDF\V444\Espressif\frameworks\esp-idf-v4.4.4\install.bat' to install it.
WARNING: tool riscv32-esp-elf version esp-2021r2-patch5-8.4.0 is installed, but has reported version unknown
ERROR: tool riscv32-esp-elf has no installed versions. Please run 'F:\WIFI\ESP-IDF\V444\Espressif\frameworks\esp-idf-v4.4.4\install.bat' to install it.
WARNING: tool esp32ulp-elf version 2.35_20220830 is installed, but has reported version unknown
ERROR: tool esp32ulp-elf has no installed versions. Please run 'F:\WIFI\ESP-IDF\V444\Espressif\frameworks\esp-idf-v4.4.4\install.bat' to install it.
WARNING: tool ccache version 4.3 is installed, but has reported version unknown
ERROR: tool ccache has no installed versions. Please run 'F:\WIFI\ESP-IDF\V444\Espressif\frameworks\esp-idf-v4.4.4\install.bat' to install it.
