Hello guys,
When use tickless idle in RTOS, I see my ADC reading I get from raw data all are fix 4041!
It seems maybe ADC could be powered down in automatic light sleep.
https://docs.espressif.com/projects/esp ... ement.html
Is it possible to force SARADC do not power down in auto light sleep?
SARADC do not work when enable automatic light sleep
Re: SARADC do not work when enable automatic light sleep
As you see. I didn't check the option below,
[uncheck]Power down Digital Peripheral in light sleep (EXPERIMENTAL)
If power management lock can be the only one solution, does this mean that the system will never work automatic light-sleep? However, ADC have to be reinitialized each time wake-up?
Make me confuse.
Make me confuse.
Users browsing this forum: Amazon [Bot], Qwantbot and 1 guest
