Does PSRAM setup affect Chip Startup Time optimization
VinayDand
Postby VinayDand » Sun Oct 19, 2025 3:00 pm
Referring to
https://docs.espressif.com/projects/esp ... -time.html
On our ESP-32-S3R8 board running @ 240 MHz CPU clock.
We can achieve a reduced boot time of around 40mS.
But as soon as we enable PSRAM in sdkconfig,
boot time increases to 480 mS
What can be done to reduce this boot time when PSRAM is enabled?
CONFIG_SPIRAM=y
CONFIG_SPIRAM_MODE_OCT=y
CONFIG_SPIRAM_FETCH_INSTRUCTIONS=y
CONFIG_SPIRAM_SPEED_80M=y
CONFIG_ESP_DEFAULT_CPU_FREQ_MHZ_240=y
We are on ESP-IDF 5.5.0
Any pointer to reduce boot time with PSRAM enabled will be appreciated
Best Regards,
Vinay
MicroController
Re: Does PSRAM setup affect Chip Startup Time optimization
Postby MicroController » Sun Oct 19, 2025 4:34 pm
If enabled, instructions in flash will be moved into PSRAM on startup.
Copying all application code from flash to PSRAM is bound to take a while.
VinayDand
Postby VinayDand » Tue Oct 21, 2025 10:27 am
That makes sense.
Thanks for the clarification.
Users browsing this forum: Amazon [Bot], Bing [Bot], Bytespider, ChatGPT-User, Qwantbot and 1 guest
