求助:ESP32S3 CMOS应用 用错了引脚导致I2C工作不正常
rogerlin
Postby rogerlin » Mon Oct 20, 2025 12:48 pm
第一次用ESP32 S3R8做产品,一个摄像头应用,用的是OV2640。样板出来之后发现程序一跑到摄像初始化时就芯片就重启,各种方式查了三天,才发现是用了PSRAM的引脚。GPIO33-37应该是给PSRAM用的,不应该把它们用在CMOS的data pin上。然后我disable了PSRAM,这下不会重启了,但是发现初始化时识别不到OV2640,应该是I2C没有正常工作,我查了cmos的驱动,是I2C没有读出OV2640的地址来。我排查了硬件的连接和OV2640的好坏(在另外一个demo板上可以正常初始化及显示)。
现在是怀疑还是用了什么不应该用的引脚,我把所有用到的引脚都列在了下面,请有经验的前辈帮忙我看一下还有哪些引脚用错了,帮忙给一下建议。
我使用的芯片是ESP32 S3R8 + 8MB flash,SDK是 V5.5.1, I2C使用了SDK的新驱动,Disable了PSRAM。
// IIC
#define DRV_GPIO_IIC_SDA_PIN             GPIO_NUM_4       // SDA
#define DRV_GPIO_IIC_SCL_PIN             GPIO_NUM_5       // SCL
// CMOS GPIO
#define DRV_GPIO_CMOS_PIN_PWDN        GPIO_NUM_46       // -1, physically 46 (not connected)
#define DRV_GPIO_CMOS_PIN_RESET       GPIO_NUM_NC       // -1, not connected
#define DRV_GPIO_CMOS_PIN_XCLK        GPIO_NUM_14       // was 15
#define DRV_GPIO_CMOS_PIN_SSCB_SDA    DRV_GPIO_IIC_SDA_PIN        // SIOD
#define DRV_GPIO_CMOS_PIN_SSCB_SCL    DRV_GPIO_IIC_SCL_PIN        // SIOC
#define DRV_GPIO_CMOS_PIN_Y2          GPIO_NUM_37       // Y2
#define DRV_GPIO_CMOS_PIN_Y3          GPIO_NUM_36       // Y3
#define DRV_GPIO_CMOS_PIN_Y4          GPIO_NUM_35       // Y4
#define DRV_GPIO_CMOS_PIN_Y5          GPIO_NUM_34       // Y5
#define DRV_GPIO_CMOS_PIN_Y6          GPIO_NUM_33       // Y6
#define DRV_GPIO_CMOS_PIN_Y7          GPIO_NUM_18       // Y7
#define DRV_GPIO_CMOS_PIN_Y8          GPIO_NUM_17       // Y8
#define DRV_GPIO_CMOS_PIN_Y9          GPIO_NUM_45       // Y9
#define DRV_GPIO_CMOS_PIN_VSYNC       GPIO_NUM_42       // VSYNC
#define DRV_GPIO_CMOS_PIN_HREF        GPIO_NUM_41       // HREF
#define DRV_GPIO_CMOS_PIN_PCLK        GPIO_NUM_13       // PCLK
// button
#define DRV_GPIO_BUTTON_ADC_PIN             GPIO_NUM_1       // up/down/enter/return
// LED
#define DRV_GPIO_LED_1_PIN             GPIO_NUM_48       // high is on
// BUZZER
#define DRV_GPIO_BUZZER_PIN             GPIO_NUM_47       // high is on
// 4G INT
#define DRV_GPIO_4G_INT_PIN             GPIO_NUM_21       // high is on
#define DRV_GPIO_4G_PWR_PIN             GPIO_NUM_26       // high is on
// UART_4G_COM
#define DRV_GPIO_UART_4G_COM_TXD_PIN             GPIO_NUM_20       // TX
#define DRV_GPIO_UART_4G_COM_RXD_PIN             GPIO_NUM_19       // RX
// 2x CDS ADC
#define DRV_GPIO_CDS_1_ADC_PIN             GPIO_NUM_8       // adc input
#define DRV_GPIO_CDS_2_ADC_PIN             GPIO_NUM_9       // adc input
#define DRV_GPIO_CDS_EN_PIN             GPIO_NUM_10       // high for enable
// 940nm LED PWR
#define DRV_GPIO_940nm_LED_PWR_PIN             GPIO_NUM_7       // high for on
// TAMPER buttons
#define DRV_GPIO_INNER_TAMPER_INT_PIN             GPIO_NUM_2       // pull none, default high, low for trigger
#define DRV_GPIO_OUTER_TAMPER_INT_PIN             GPIO_NUM_3       // pull none, default high, low for trigger
// Battery read
#define DRV_GPIO_BATTERY_READ_PIN             GPIO_NUM_6       // a ADC input, read voltage
// Main power enable
#define DRV_GPIO_MAIN_PWR_EN_PIN             GPIO_NUM_0       // weak pull up, default high
// UART_DEBUG
#define DRV_GPIO_UART_DEBUG_TXD_PIN             GPIO_NUM_43       // TX
#define DRV_GPIO_UART_DEBUG_RXD_PIN             GPIO_NUM_44       // RX
// LCD
#define DRV_GPIO_LCD_RESET_PIN             GPIO_NUM_11       // high for on
// 433Mhz Module
#define DRV_GPIO_433M_DAT_PIN             GPIO_NUM_12       // high for on
rogerlin
Re: 求助:ESP32S3 CMOS应用 用错了引脚导致I2C工作不正常
Postby rogerlin » Mon Oct 20, 2025 12:56 pm
我补贴一个更紧凑的版本,这样看起来容易看一下。不知还用到了哪些不该用的引脚,导致出了 I2C 不能正常工作的问题。
// CMOS GPIO
rogerlin
Postby rogerlin » Tue Oct 21, 2025 1:46 pm
事情已经完美解决!!哈哈
Users browsing this forum: Applebot, Bing [Bot] and 1 guest
