What is the proper way to use Cache_Start_L2_Cache_Preload()
from esp-idf-v5.5\components\esp_rom\esp32p4\include\esp32p4\rom\cache.h
on ESP32-P4 from application code? The function returns
instantly (2-7 μs for 128 KB) and shows unrealistic bandwidth.
Can you provide:
1. Correct usage example
2. Expected behavior/timing
3. Or confirm if it's only for bootloader internal use?
boumedine billal
MicroController
Re: What is the proper way to use Cache_Start_L2_Cache_Preload
From the name of the function and it's documentation, and from the way the cache is controlled on other ESP32s, you'd expect it to start the cache operation and then return. The cache does the loading asynchronously while the CPU can keep doing other things. (Synchronously waiting for the preload to finish would defeat its whole purpose.) As long as the cache operation is taking place, Cache_L2_Cache_Preload_Done() will return 0.
The full workflow to use the functions could be like
Notice that the ROM cache functions may not be thread-safe, which is probably why they say "Please do not call this function in your SDK application."
uint32_t restoreAutoPreload = 0;
if (Cache_L2_Cache_Preload_Done()) {
// Only start new preload if none already running.
restoreAutoPreload = Cache_Start_L2_Cache_Preload(start, size, order);
// ... do other things ...
// Finally:
if(restoreAutoPreload) {
while(!Cache_L2_Cache_Preload_Done()) {
// Wait for manual preload to finish.
// Reenable auto preload:
Cache_End_L2_Cache_Preload(restoreAutoPreload);
boumedine billal
ESP32-P4 Cache Preload API Test Results
Summary
Thank you MicroController for the suggestion to use the asynchronous pattern. I implemented your recommended approach and compared it against optimized CPU copy as a baseline. Unfortunately, the results confirm that Cache_Start_L2_Cache_Preload() does not perform actual PSRAM data transfer.
Test Setup
main/app_main.cpp
main/dl_esp32p4_memcpy.S
Optimized RISC-V assembly using ESP32-P4 SIMD extensions (from ESP-DL library):
main/CMakeLists.txt
Test Results
Analysis
Key Findings:
For a real PSRAM transfer at 200 MHz (Octal SPI):
Thread Safety Note:
The cache.h header states:
For now, software cache warming provides predictable results:
This achieves ~187 MB/s (matching hardware limits) and loads data into L1/L2 cache predictably.
Thank you for your help investigating this issue. I hope Espressif can clarify the intended usage of these ROM functions.
Summary
Test Setup
- Hardware: ESP32-P4
- ESP-IDF: v5.5
- Buffer Size: 128 KB in PSRAM
- Eviction Buffer: 256 KB (to ensure cold cache)
- Iterations: 10
- Cache Configuration: L2 256 KB, line size 128B
main/app_main.cpp
#include <stdio.h>
#include <stdint.h>
#include "freertos/task.h"
#include "esp_heap_caps.h"
#include "esp_timer.h"
#include "rom/cache.h"
extern "C" {
void dl_esp32p4_memcpy(void *dst, const void *src, const size_t n);
#define BUFFER_SIZE (128 * 1024)
#define EVICT_SIZE (256 * 1024)
#define ALIGNMENT 128
#define NUM_ITERATIONS 10
#define OUTPUT_SIZE (8 * 1024)
static volatile uint64_t g_prevent_optimization = 0;
static void force_cache_eviction(volatile uint8_t *evict_buf)
volatile uint64_t sum = 0;
for (size_t i = 0; i < EVICT_SIZE; i += 64) {
sum += evict_buf[i];
g_prevent_optimization += sum;
asm volatile("fence" ::: "memory");
static void test_comparison()
char *output = (char *)heap_caps_malloc(OUTPUT_SIZE, MALLOC_CAP_INTERNAL);
if (!output) {
printf("ERROR: Cannot allocate output buffer\n");
return;
int pos = 0;
pos += snprintf(output + pos, OUTPUT_SIZE - pos,
"\n========================================\n"
"ESP32-P4 Cache Preload vs CPU Copy Test\n"
"========================================\n"
"Buffer: 128 KB PSRAM\n"
"Iterations: %d\n"
"PSRAM theoretical max: ~400 MB/s\n\n", NUM_ITERATIONS);
volatile uint8_t *psram_src = (volatile uint8_t *)heap_caps_aligned_alloc(
ALIGNMENT, BUFFER_SIZE, MALLOC_CAP_SPIRAM);
uint8_t *internal_dst = (uint8_t *)heap_caps_aligned_alloc(
ALIGNMENT, BUFFER_SIZE, MALLOC_CAP_INTERNAL);
volatile uint8_t *evict_buf = (volatile uint8_t *)heap_caps_aligned_alloc(
ALIGNMENT, EVICT_SIZE, MALLOC_CAP_SPIRAM);
if (!psram_src || !internal_dst || !evict_buf) {
pos += snprintf(output + pos, OUTPUT_SIZE - pos, "ERROR: Allocation failed\n");
printf("%s", output);
heap_caps_free(output);
return;
for (size_t i = 0; i < BUFFER_SIZE; i++) {
psram_src[i] = (uint8_t)(i & 0xFF);
for (size_t i = 0; i < EVICT_SIZE; i++) {
evict_buf[i] = (uint8_t)(i & 0xFF);
// TEST 1: Hardware Preload API (following async pattern)
"TEST 1: Hardware Preload API\n"
"=============================\n");
uint64_t total_preload_us = 0;
uint32_t total_polls = 0;
for (int i = 0; i < NUM_ITERATIONS; i++) {
force_cache_eviction(evict_buf);
Cache_Invalidate_Addr(CACHE_MAP_L2_CACHE, (uint32_t)psram_src, BUFFER_SIZE);
vTaskDelay(pdMS_TO_TICKS(10));
uint32_t restore = 0;
int64_t start = esp_timer_get_time();
restore = Cache_Start_L2_Cache_Preload((uint32_t)psram_src, BUFFER_SIZE, 0);
uint32_t polls = 0;
while (!Cache_L2_Cache_Preload_Done()) {
polls++;
int64_t end = esp_timer_get_time();
if (restore) {
Cache_End_L2_Cache_Preload(restore);
volatile uint64_t check = 0;
for (size_t j = 0; j < BUFFER_SIZE; j += 64) {
check += psram_src[j];
g_prevent_optimization += check;
total_preload_us += (end - start);
total_polls += polls;
float avg_preload_us = (float)total_preload_us / NUM_ITERATIONS;
float preload_bw = (BUFFER_SIZE / (1024.0f * 1024.0f)) / (avg_preload_us / 1e6f);
float avg_polls = (float)total_polls / NUM_ITERATIONS;
"Average time: %.1f us\n"
"Average polls: %.0f\n"
"Bandwidth: %.1f MB/s\n\n",
avg_preload_us, avg_polls, preload_bw);
// TEST 2: Optimized CPU Copy (baseline)
"TEST 2: Optimized CPU Copy (PSRAM→RAM)\n"
"=======================================\n");
uint64_t total_cpu_us = 0;
dl_esp32p4_memcpy(internal_dst, (const void *)psram_src, BUFFER_SIZE);
check += internal_dst[j];
total_cpu_us += (end - start);
float avg_cpu_us = (float)total_cpu_us / NUM_ITERATIONS;
float cpu_bw = (BUFFER_SIZE / (1024.0f * 1024.0f)) / (avg_cpu_us / 1e6f);
avg_cpu_us, cpu_bw);
"COMPARISON\n"
"==========\n"
"Expected for real PSRAM preload:\n"
" - Time: 320-640 us\n"
" - Bandwidth: 200-400 MB/s\n"
" - Polls: 1000+ (if hardware fetching)\n\n"
"Actual results:\n"
" Hardware preload: %.1f us, %.1f MB/s, %.0f polls\n"
" Optimized CPU: %.1f us, %.1f MB/s\n\n",
avg_preload_us, preload_bw, avg_polls,
if (avg_preload_us < 100.0f && avg_polls < 10.0f) {
"CONCLUSION:\n"
"-----------\n"
"Hardware preload completes instantly without\n"
"fetching from PSRAM.\n\n"
"Optimized CPU copy shows real PSRAM bandwidth\n"
"of %.0f MB/s, which matches hardware specs.\n",
cpu_bw);
"CONCLUSION:\n"
"-----------\n"
"Hardware preload is working correctly.\n");
"\nPrevent optimization: %llu\n"
"========================================\n",
g_prevent_optimization);
heap_caps_free((void *)psram_src);
heap_caps_free(internal_dst);
heap_caps_free((void *)evict_buf);
extern "C" void app_main(void)
vTaskDelay(pdMS_TO_TICKS(100));
test_comparison();
.text
.align 2
.global dl_esp32p4_memcpy
.type dl_esp32p4_memcpy, @function
.balign 4
.option norvc
dl_esp32p4_memcpy:
esp.ld.128.usar.ip q0, a1, 0
esp.movx.r.sar.bytes t6
esp.ld.128.usar.ip q1, a0, 0
esp.movx.r.sar.bytes t4
li a6, 16
sub a6, a6, t4
li t0, 16
beq a6, t0, 13f
blt a6, a2, dl_esp32p4_memcpy_done_min
mv a6, a2
dl_esp32p4_memcpy_done_min:
srli t6, a6, 2
slli a7, t6, 2
sub a7, a6, a7
mv t0, t6
blez t0, 10f
9:
lw a3, 0(a1)
addi a1, a1, 4
sw a3, 0(a0)
addi a0, a0, 4
addi t0, t0, -1
bgtz t0, 9b
10:
mv t0, a7
blez t0, 12f
11:
lbu a3, 0(a1)
addi a1, a1, 1
sb a3, 0(a0)
addi a0, a0, 1
addi t0, t0, -1
bgtz t0, 11b
12:
sub a2, a2, a6
13:
beqz t6, 1f
srli a3, a2, 4
slli a4, a3, 4
sub a4, a2, a4
srli a5, a3, 1
slli t3, a5, 1
sub t3, a3, t3
srli t4, a4, 2
slli t5, t4, 2
sub t5, a4, t5
mv t0, a5
blez t0, 15f
14:
esp.ld.128.usar.ip q0, a1, 16
esp.ld.128.usar.ip q1, a1, 16
esp.ld.128.usar.ip q2, a1, 0
esp.src.q q0, q0, q1
esp.src.q q1, q1, q2
esp.vst.128.ip q0, a0, 16
esp.vst.128.ip q1, a0, 16
addi t0, t0, -1
bgtz t0, 14b
15:
beqz t3, 4f
esp.ld.128.usar.ip q1, a1, 0
bnez t3, 4f
1:
srli a3, a2, 4
slli a4, a3, 4
sub a4, a2, a4
srli a5, a3, 1
slli t3, a5, 1
sub t3, a3, t3
srli t4, a4, 2
slli t5, t4, 2
sub t5, a4, t5
mv t0, a5
blez t0, 3f
2:
esp.vld.128.ip q0, a1, 16
esp.vld.128.ip q1, a1, 16
addi t0, t0, -1
bgtz t0, 2b
3:
beqz t3, 4f
4:
mv t0, t4
blez t0, 6f
5:
lw a3, 0(a1)
addi a1, a1, 4
sw a3, 0(a0)
addi a0, a0, 4
addi t0, t0, -1
bgtz t0, 5b
6:
mv t0, t5
blez t0, 8f
7:
lbu a3, 0(a1)
addi a1, a1, 1
sb a3, 0(a0)
addi a0, a0, 1
addi t0, t0, -1
bgtz t0, 7b
8:
ret
set(srcs "app_main.cpp"
"dl_esp32p4_memcpy.S")
idf_component_register(
SRCS ${srcs}
REQUIRES esp_timer
Iterations: 10
Average time: 1.5 us
Average polls: 0
Bandwidth: 83333.3 MB/s
Average time: 669.2 us
Bandwidth: 186.8 MB/s
COMPARISON
- Time: 320-640 us
Actual results:
Hardware preload: 1.5 us, 83333.3 MB/s, 0 polls
Optimized CPU: 669.2 us, 186.8 MB/s
CONCLUSION:
of 187 MB/s, which matches hardware specs.
Key Findings:
- Hardware Preload API:
- Completes in 1.5 μs for 128 KB
- Shows 0 polls (immediate completion)
- Reports 83,333 MB/s (physically impossible)
- 446× faster than actual PSRAM speed - Optimized CPU Copy:
- Takes 669 μs for 128 KB
- Achieves 187 MB/s bandwidth
- Matches expected PSRAM @ 200 MHz performance
- 47% efficiency (typical for real hardware)
- Theoretical max: 8 lines × 200 MHz × 2 (DDR) = 400 MB/s
- Real-world: ~180-200 MB/s (accounting for protocol overhead)
- Expected time for 128 KB: 640-700 μs
- Time: 1.5 μs (446× faster than physical limit)
- Polls: 0 (no wait for hardware operation)
- Bandwidth: 83 GB/s (208× faster than theoretical maximum)
Thread Safety Note:
Combined with the test results, this suggests the API is:/**
* Please do not call this function in your SDK application.
uint32_t Cache_Start_L2_Cache_Preload(...);
- Intended for ROM bootloader internal use only
- Not designed for application-level PSRAM bandwidth optimization
- Possibly just manipulates cache metadata without DMA
- Is Cache_Start_L2_Cache_Preload() intended for application use on ESP32-P4?
- If yes, what is the correct usage pattern to achieve actual PSRAM preloading?
- If no, what is the recommended approach for optimizing PSRAM access patterns?
- Should ESP-DL (Espressif's ML framework) implement P4 preload, as it does for S3?
void software_preload(volatile uint8_t *addr, size_t size) {
for (size_t i = 0; i < size; i += 64) { // 64B cache line
sum += addr[i];
asm volatile("" : "+r"(sum) :: "memory");
MicroController
Hmm. In theory, this may fail to start any cache operation; namely if another cache operation is still running. In that case, you won't time what you want to.Code: Select all
if (Cache_L2_Cache_Preload_Done()) { restore = Cache_Start_L2_Cache_Preload((uint32_t)psram_src, BUFFER_SIZE, 0); }
Maybe try spin-waiting for Preload_Done before starting the benchmark.
Btw: https://github.com/espressif/esp-idf/bl ... rgb.c#L916
And for invalidating the cache, the Memory Synchronization API may be useful.
