Using the M10 blacksheep GPS with esp32
dizfunc
Postby dizfunc » Sat Oct 25, 2025 8:23 pm
Hello, as a beginner in this field, I would like to get a guide on how to receive data from a M10 blacksheep gps module and transmit it to an esp32.
To be more precise, in a futur application, I would need to use a XIAO esp32C3. If I could get a guide on how to do this with a default esp32 and a XIAO esp32C3, it would help greatly.
Thank you.
Minatel
Re: Using the M10 blacksheep GPS with esp32
Postby Minatel » Mon Oct 27, 2025 11:31 am
Check if the GPS/GNSS you want to use has the NMEA protocol. You can use this component to read the data from the GNSS module.
MicroController
Postby MicroController » Tue Oct 28, 2025 11:43 am
The BlackSheep M10 says "Input Voltage - 5V" - if it also outputs 5V signals you will need a voltage divider to 3.3V when connecting to an ESP32.
Users browsing this forum: Perplexity-User, Qwantbot and 3 guests
