ESP32 LCD/TFT LTDC Support
sairfan06
Postby sairfan06 » Tue Oct 28, 2025 9:07 pm
Hi I wanted to know does ESP32 support LTDC, to interface LCD?
Re: ESP32 LCD/TFT LTDC Support
Postby Sprite » Tue Oct 28, 2025 11:50 pm
LTDC is a STM32 peripheral, not a LCD interface. If you can tell us roughly what type of LCD you want to interface, we can tell you which peripheral may be able to do that.
sairfan06
Postby sairfan06 » Wed Oct 29, 2025 3:41 pm
Sorry I was not clear enough in my question, actually i meant, is there LTDC equalent LCD support available in ESP? ie. using frame/window buffer, DMA external memory (RAM) etc. I want to use ILI9488 driver with ESP,
here I would also like to ask is there some LCD/TFT driver library for ESP? I saw ESP-IDF example using LVGL there are only two drivers available int it, as ESP32 is widely used I was thinking there must be some library with collection of different LCD drivers. just like esp-idf-lib on git hub which mostly have sensor drivers.
Postby Sprite » Sat Nov 01, 2025 3:15 am
There's no direct equivalent; for SPI we have the standard SPI master driver, for parallel display we have the LCD mode of the I2S channels (ESP32), the LCD/camera controller (ESP32S3) and/or the parallel IO controller (e.g. ESP32C6).
nopnop2002
Contact:
Postby nopnop2002 » Mon Nov 24, 2025 6:22 am
Users browsing this forum: PerplexityBot and 5 guests
