ESP32 LCD/TFT LTDC Support
Posted: Tue Oct 28, 2025 9:07 pm
by sairfan06
Hi I wanted to know does ESP32 support LTDC, to interface LCD?
Re: ESP32 LCD/TFT LTDC Support
Posted: Tue Oct 28, 2025 11:50 pm
by Sprite
LTDC is a STM32 peripheral, not a LCD interface. If you can tell us roughly what type of LCD you want to interface, we can tell you which peripheral may be able to do that.
Posted: Wed Oct 29, 2025 3:41 pm
by sairfan06
Sorry I was not clear enough in my question, actually i meant, is there LTDC equalent LCD support available in ESP? ie. using frame/window buffer, DMA external memory (RAM) etc. I want to use ILI9488 driver with ESP,
here I would also like to ask is there some LCD/TFT driver library for ESP? I saw ESP-IDF example using LVGL there are only two drivers available int it, as ESP32 is widely used I was thinking there must be some library with collection of different LCD drivers. just like esp-idf-lib on git hub which mostly have sensor drivers.
Posted: Sat Nov 01, 2025 3:15 am
by Sprite
There's no direct equivalent; for SPI we have the standard SPI master driver, for parallel display we have the LCD mode of the I2S channels (ESP32), the LCD/camera controller (ESP32S3) and/or the parallel IO controller (e.g. ESP32C6).
Posted: Mon Nov 24, 2025 6:22 am
by nopnop2002
