I’m working on a **universal cable tester project** using an **ESP32 DevKit V1**, a **MCP23017 (I2C)** expander, a **ST7735 TFT display (128×160)**, and a **rotary encoder**.
My goal is to detect cable connections (40 Pins tester) by scanning continuity between the pins (GPA ↔ GPB). I start with 8 pin so with only one MCP for test
Here is my **current wiring setup** on the breadboard:
* **ESP32 to TFT ST7735:**
* CS → GPIO27
* DC → GPIO26
* RST → GPIO25
* MOSI → GPIO13
* SCLK → GPIO14
* VCC → 3.3V
* GND → common ground
* **ESP32 to MCP23017 (I2C):**
* VDD → 3.3V
* VSS → GND
* SDA → GPIO21
* SCL → GPIO22
* A0, A1, A2 → GND (→ I2C address = 0x20)
* RESET → 3.3V through 10 kΩ resistor
* 0.1 µF capacitor between VDD and GND (close to the chip)
* **GPB0–GPB7 connected to GPA0–GPA7** (simulating cable links)
* 10 kΩ pull-ups from each GPB pin to 3.3V
* **Rotary encoder:**
* A → GPIO4
* B → GPIO2
* SW → GPIO15
* C → GND
* The last Pin → GND
All components are powered from **the ESP32’s 3.3 V rail**.
The wiring has been double-checked and there are no shorts.
I tried several sketches, including the following **I2C + MCP23017 diagnostic code** (see below).
It initializes I2C on GPIO 21/22, scans the bus, and attempts a raw I2C read from address 0x20 before running Adafruit’s MCP23017 library.
However, the scan always returns:
*** NO DEVICES FOUND! ***
Check: Pull-ups, address pins, RESET, power, etc.
I2C errors such as
`I2C hardware NACK detected`
also appear repeatedly in the serial monitor.
I’ve verified wiring, used external 4.7 kΩ pull-ups on SDA/SCL, and tried 100 kHz I2C clock speed. Still nothing is detected.
Here’s the **sketch I used**:
#include <Arduino.h>
#include <Wire.h>
#include <Adafruit_MCP23X17.h>
Adafruit_MCP23X17 mcp;
const uint8_t MCP_ADDR = 0x20; // A0=A1=A2=GND
delay(500);
Serial.println("\n\n========== I2C DIAGNOSTIC START ==========");
Wire.begin(21, 22);
Wire.setClock(100000);
delay(100);
int found_count = 0;
for (uint8_t addr = 1; addr < 127; addr++) {
Wire.beginTransmission(addr);
byte error = Wire.endTransmission();
if (error == 0) {
found_count++;
Serial.printf("Found device at 0x%02X\n", addr);
if (found_count == 0) {
Serial.println("*** NO DEVICES FOUND! ***");
while (1) delay(1000);
if (!mcp.begin_I2C(MCP_ADDR)) {
Serial.println("*** LIBRARY INIT FAILED @0x20 ***");
Serial.println("MCP23017 OK!");
void loop() {}
Does anyone have an idea why the MCP23017 isn’t detected at all on the I2C bus?
The next step, once it's working, is to multiply the MCP23017 to create sides A and B with 40 pins on each, and to be able to make a universal tester in which we will create adapters by making breakboards
Thank you!
