Help for cable tester
Posted: Wed Oct 29, 2025 12:26 pm
by Honzaa
Hello everyone,
I’m working on a **universal cable tester project** using an **ESP32 DevKit V1**, a **MCP23017 (I2C)** expander, a **ST7735 TFT display (128×160)**, and a **rotary encoder**.
My goal is to detect cable connections (40 Pins tester) by scanning continuity between the pins (GPA ↔ GPB). I start with 8 pin so with only one MCP for test
Here is my **current wiring setup** on the breadboard:
* **ESP32 to TFT ST7735:**
* CS → GPIO27
* DC → GPIO26
* RST → GPIO25
* MOSI → GPIO13
* SCLK → GPIO14
* VCC → 3.3V
* GND → common ground
* **ESP32 to MCP23017 (I2C):**
* VDD → 3.3V
* VSS → GND
* SDA → GPIO21
* SCL → GPIO22
* A0, A1, A2 → GND (→ I2C address = 0x20)
* RESET → 3.3V through 10 kΩ resistor
* 0.1 µF capacitor between VDD and GND (close to the chip)
* **GPB0–GPB7 connected to GPA0–GPA7** (simulating cable links)
* 10 kΩ pull-ups from each GPB pin to 3.3V
* **Rotary encoder:**
* A → GPIO4
* B → GPIO2
* SW → GPIO15
* C → GND
* The last Pin → GND
All components are powered from **the ESP32’s 3.3 V rail**.
The wiring has been double-checked and there are no shorts.
I tried several sketches, including the following **I2C + MCP23017 diagnostic code** (see below).
It initializes I2C on GPIO 21/22, scans the bus, and attempts a raw I2C read from address 0x20 before running Adafruit’s MCP23017 library.
However, the scan always returns:
*** NO DEVICES FOUND! ***
Check: Pull-ups, address pins, RESET, power, etc.
I2C errors such as
`I2C hardware NACK detected`
also appear repeatedly in the serial monitor.
I’ve verified wiring, used external 4.7 kΩ pull-ups on SDA/SCL, and tried 100 kHz I2C clock speed. Still nothing is detected.
Here’s the **sketch I used**:
#include <Arduino.h>
#include <Wire.h>
#include <Adafruit_MCP23X17.h>
Adafruit_MCP23X17 mcp;
const uint8_t MCP_ADDR = 0x20; // A0=A1=A2=GND
void setup() {
Serial.begin(115200);
delay(500);
Serial.println("\n\n========== I2C DIAGNOSTIC START ==========");
Wire.begin(21, 22);
Wire.setClock(100000);
delay(100);
int found_count = 0;
for (uint8_t addr = 1; addr < 127; addr++) {
Wire.beginTransmission(addr);
byte error = Wire.endTransmission();
if (error == 0) {
found_count++;
Serial.printf("Found device at 0x%02X\n", addr);
if (found_count == 0) {
Serial.println("*** NO DEVICES FOUND! ***");
while (1) delay(1000);
if (!mcp.begin_I2C(MCP_ADDR)) {
Serial.println("*** LIBRARY INIT FAILED @0x20 ***");
Serial.println("MCP23017 OK!");
void loop() {}
Does anyone have an idea why the MCP23017 isn’t detected at all on the I2C bus?
The next step, once it's working, is to multiply the MCP23017 to create sides A and B with 40 pins on each, and to be able to make a universal tester in which we will create adapters by making breakboards
Thank you! 🙏
Re: Help for cable tester
Posted: Thu Oct 30, 2025 3:08 am
by Sprite
Perhaps use an I2C scanner sketch to see if there's anything at all on the I2C bus? If memory serves, that chip has multiple variants that can be at different I2C addresses.
Posted: Thu Oct 30, 2025 5:05 am
by ESP32_kid
Exactly, start with a bus scanner. Once that get's green-light, go to next part of programming.
Always dbl-tripl check wiring for routing and contact, sometime breadboarding is not 100%.
https://randomnerdtutorials.com/esp32-i ... r-arduino/
