[SP32 P4] tiny_usb handler never called when device is dettached
jared_s
Postby jared_s » Fri Oct 31, 2025 3:09 pm
I configured my USB OTG port to CDC+MIDI, registered handler in:
 tinyusb_config_t tusb_cfg = TINYUSB_DEFAULT_CONFIG(device_event_handler, this);
handler:
void device_event_handler(tinyusb_event_t *event, void *arg)
device_event_handler is called when device is attached only (when I plug USB cable from host to the OTG USB on ESP board)
but it is never called when I unplug the cable.
I tried als check the status uf the tiny_usb in loop using:
bool isConnected = tud_connected() && tud_mounted();
but tud_connected() or tud_mounted() are always TRUE even the cable is unplugged.
Is this a bug or I missed something?
Thanks,
J.
## IDF Component Manager Manifest File
dependencies:
  idf: ">=5.2.0"
  # TinyUSB wrapper and core:
  espressif/esp_tinyusb: "~2.0.1"
  espressif/tinyusb: ">=0.17.0"
Users browsing this forum: Baidu [Spider], burtrum, Bytespider, Google [Bot] and 3 guests
